04-21-2021, 10:13 PM | #45 | |
Rep 6,734
Drives: 'E46 M3 Race Car, '23 X7
In my opinion a HAS kit is no better than a lowering spring, and in fact opens up the potential to be worse. The HAS allows you to lower the car even further than a typical lowering spring. Thereby further reducing suspension travel and often taking it to the point of riding on the bump stops. The only real advantages to a HAS kit is that it allows you to dial in your desired ride height and corner balance. However, they add complications. Going too low is a problem and they reduce inner wheel clearance. I would seek a lowering spring that is in the height range that I like, a spring rate that is decently matched to the shocks and isn't so low that it rides on bump stops. I have repeatedly seen people slamming their car with HAS kits causing more damage to the dampers than any lowering spring.
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M |
04-22-2021, 01:22 AM | #46 | |
Rep 1,125
04-22-2021, 11:52 AM | #47 | |
We've landed on the moon!
1449
Rep 906
Drives: 2011 1M (AW)
04-22-2021, 03:02 PM | #48 | ||
Rep 6,734
I will be testing a few different coilovers kits: Ohlins R&T standard Ohlins R&T with custom springs Moton 2-way Ohlins TTX 2-way That being said I have had great results with HR springs on my daily drivers. Currently have them on my X3M and previously used them on my F31 330i with good results on both.
'23 X7
michaeldorian237.50 |
04-22-2021, 03:03 PM | #49 | ||
Rep 6,734
'23 X7
04-22-2021, 03:36 PM | #50 | |
Senior 1Addict
5161
Rep 2,426
Drives: BMW iX, Porsche GT4 RS
Davil6511.00 |
04-22-2021, 03:45 PM | #51 | ||
Rep 6,734
'23 X7
04-22-2021, 05:17 PM | #52 | ||
Rep 534
cptobvious2531.50 Wah2778.50 |
04-22-2021, 06:17 PM | #53 | |
Senior 1Addict
5161
Rep 2,426
I personally have no desire to find out if it does or doesn't, and will be leaving my car stock. Not tracking my car either, its meant as a backroads car. |
04-29-2021, 03:13 PM | #54 |
Rep 1,125
What are ya'll thoughts on doing just something modest like 10mm-15m using something like this...
MSS F87 M2 Height Adjustable Spring Kit https://ind-distribution.com/product...ble-spring-kit Thoughts on the MSS stuff?
04-29-2021, 03:45 PM | #55 | |
Rep 550
04-29-2021, 07:20 PM | #57 |
Rep 1,125
Looks like H&R 28802-1 is for M3, M4. and M2 Adaptive Suspension and 28802-5 is for M2, M2C standard...
But oddly 28802-1 is listed as a Super Sport Spring for the M3 and M4 Lowering Specs: Front - 1.6" Rear - 1.0" but Sport Spring for M2 CS F87 M2 Competition Lowering Specs: Front - 1.0" Rear - 0.8" https://www.hrsprings.com/applicatio...e/4/Suspension
04-29-2021, 07:55 PM | #58 | |
Rep 900
Drives: 2018 M3 Competition
It makes it look just right, any lower and I'd surely be scraping out of my driveway. |
04-29-2021, 08:00 PM | #59 | |
Rep 550
identical to the M2 C F87 M2 Competition Lowering Specs: Front - 1.0" Rear - 0.8" |
06-01-2021, 12:45 PM | #60 |
Rep 1,125
According to this thread. the M2 CS spring part numbers are exactly the same as the M2C.
https://f87.bimmerpost.com/forums/sh...90&postcount=1 The coil spring part # for the the M2 CS, Spring Front: 31337853271, shared with M2/M2 LCI/M2 Competition Spring Rear: 33537853275, shared with M2/M2 LCI/M2 Competition And of course EDC are carried over from the F80/82/83, albiet having a different tuning, Spring strut, EDC, front left : 31318008627 Spring strut, EDC, front right : 31318008628 Shock absorber for EDC, rear left: 33528008629 Shock absorber for EDC, rear right: 33528008630
Ilikemike250.50 |
06-01-2021, 01:03 PM | #62 |
Rep 1,125
Ha. Yeah, looking just for 10mm / 1cm.
06-20-2021, 08:08 AM | #63 |
Rep 4,663
Is anyone that's lowering their stance using a "diff lift" kit. I was watching a video by Misha charoudin. They modified their OG M2. They should this kit and the logic made sense to me. It seems to correct the geometry from lowering. They also slid mounted the diff etc. I wonder if the CSR has this?
https://f87.bimmerpost.com/forums/sh....php?t=1834869 Last edited by medphysdave; 06-20-2021 at 10:42 AM.. |
2taCoS279.00 |
07-06-2021, 12:05 AM | #64 | |
Rep 7,294
The engineers didn't deliver the car like that from the factory for a reason. I don't think BMW is always perfect, but I do think without knowledge of the reasons that went into their decisions it is sometimes difficult to say what is a good idea and what is not. In this case, it's fairly standard to assume the overall impact is slightly negative and could wear the dampers faster. Lowering springs always take the system out of the range it was designed for. Not a big deal, but I'm sure it's worse than stock over really bad surfaces. |
07-06-2021, 01:55 PM | #65 | |
Rep 1,657
I'm just guessing but the kinematics on BMW Motorsport cars are totally different and wouldn't need an after market diff lift kit.
1995 LTW: Modified by BMW NA Factory team from new
M2 CS: CF Buckets & more (track toy) |
07-06-2021, 01:59 PM | #66 | |
Rep 4,663
ptgltw3777.50 |
