03-01-2021, 01:56 PM | #1 |
Rep 8
Dealer claims MPE will invalidate my warranty?
Hi. I am new to the forum but had BMW’s for years including two E46’s and an E92. I appreciate any help on this weird one as I am 2 weeks away from fitting the MPE !!
I went to buy an exhaust clamp from my local dealer to fit the MPE to my LCI N55 M2. The dealer told me the MPE was not showing as an option for my car and hence it would not work but would also invalidate my warranty. As far as I know buying a (second hand ) MPE meant it would not invalidate any warranty as it is a BMW part? My car is a September 2017. Has anyone else heard this before ? Thanks |
03-01-2021, 03:28 PM | #2 |
Rep 2,526
Find another dealer. Yours is full of shit.
First off, fitting an exhaust isn't going to "void your warranty" unless they can prove the exhaust was the cause of any kind of warranty claim. Second, the MPE is a port install option on the M2. My M2 is fitted with the MPE, and my dealership even replaced the muffler under warranty due to a rattling issue. |
BrettKA7566.50 |
03-02-2021, 05:30 AM | #3 | |
Rep 9,709
To the OP, your car is probably included in the time batch where it was no longer legal to change exhausts and that why computer says no. It's not to say the exhaust won't fit, just was never sanctioned by BMW. Warranty wise is a tricky one. They are BMW parts, and I doubt any dealership will be sharp on the dates where you could or couldn't have one fitted, if there was a problem. Probably safe to say the actual exhaust won't be covered under warranty. It is easy enough to swap back to the standard back section if needed. Less easy is the electronic module that integrates the MPE. Another less costly option is to have the back box opened up and the perforated pipe changed for solid. Pretty much turns the stock box into something MPE like. |
M2Minerals0.00 |
03-02-2021, 08:12 AM | #4 | |
Rep 2,526
My bad, ignore me |
M2Minerals0.00 JustChris17483.00 |
03-03-2021, 03:16 AM | #5 | |
Rep 8
This is the conversation that I am having with BMW as I cant see how the exhaust, (which produces no extra power) should impact the rest of the car warranty. It would be interesting to find out what the cut off date is as I don't think my car was within the timeframe. Hopefully BMW UK will come back with a sensible solution. Thanks for the advice. |
03-08-2021, 03:37 PM | #6 | |
Rep 8,972
You can't "void" the whole car warranty by fitting an exhaust or any other part for that matter. Any failures proven to be linked to an authorised part may not be covered, but nothing else. Note the word "proven", they have to prove it, the onus is on them not you. Real oem which mirrors the BMW ETK parts system (see link below) lists the MPE exhaust for June 2017 UK M2 with no restrictions. It also says June 17 is the last month of M2 production, what is your production date? Maybe it was registered late? Production date is under bonnet. https://www.realoem.com/bmw/enUS/sho...diagId=03_4010 Last edited by doughboy; 03-08-2021 at 03:45 PM.. |
03-09-2021, 05:34 AM | #7 | ||
Rep 9,709
03-09-2021, 08:36 AM | #8 | ||
Rep 8
03-09-2021, 10:14 AM | #9 | |||
Rep 9,709
But in any case, I understand you only needed the sleeve from them? |
03-13-2021, 04:26 PM | #10 | |
Rep 8,972
What's the build date on the sticker under the bonnet? That's the accurate one! |
03-13-2021, 04:31 PM | #11 |
Rep 8,972
