12-17-2020, 12:05 AM | #1 |
Rep 11
F87 M2 Comp Mirrors Retrofit - getbmwparts
Hi - did anyone install these M2C retro fit mirrors from getbmwparts.com on their OG M2?
https://www.getbmwparts.com/p-f87-m2...kf87m2cmirrors Want to buy the mirrors for my 2017 M2 but wonder whether they require any other changes on the mirror’s base, electrics or modules of the car? Or whether no other parts are needed to get them installed? I already checked with getbmwparts.com but they referred me back to the forum to confirm.. Thanks for any pointers |
12-17-2020, 12:46 AM | #2 | |
Rep 1,609
Check out JB Speed. A lot cheaper, and they look great, but ... be warned, they are a pain to put on. I had to get my mechanic to help me install them. |
12-17-2020, 03:11 AM | #3 | |
Rep 11
I do prefer the non-carbon version of getbmwparts.com though.. hopefully they're easy to install mirrors w/o having to go a mechanic. |
12-17-2020, 08:04 AM | #5 |
Rep 177
I bought / installed the M2C retro fit mirror kit from getbmwparts. You get everything you need to install.
You will have to have the caps painted or get the carbon fiber ones. |
12-17-2020, 08:45 AM | #6 |
Rep 11
12-17-2020, 09:13 AM | #7 |
Rep 406
Drives: BMW 328xi BMW X5 F15 BMW M2
12-17-2020, 09:37 AM | #8 |
Rep 1,899
not everyone wants a fake housing. Some people want the real deal for the bigger mirror glass and the unique LED
12-17-2020, 10:55 AM | #9 | |
Private NumNuts
522
Rep 321
Anyways, to answer your question they're a direct fit but require you to remove the door panels for installation.
12-17-2020, 11:06 AM | #10 | |
Rep 6,635
12-17-2020, 12:12 PM | #11 | |
Rep 1,968
I already had the euro/wide angle mirrors and I didn't think it was worth $2K (with paint) for the genuine ones (although it does transform the look and should have been standard on the OG). |
12-17-2020, 01:33 PM | #12 |
6634
Rep 4,145
Drives: '18 M2 6MT
Absolutely happy with my AutoID mirror assemblies. Same as the ones sold by IND.
annabellapizza234.50 |
12-17-2020, 04:10 PM | #13 |
Rep 6,934
Drives: 2018 M2 AW DCT
I went the easy way with these IND mirror caps: https://ind-distribution.com/collect...rror-cover-set
12-17-2020, 04:38 PM | #14 | ||
Rep 478
https://f87.bimmerpost.com/forums/sh...ghlight=mirror https://f87.bimmerpost.com/forums/sh...ghlight=mirror Incorrect. If you go to the Cosmetic Modification Forum there are several threads on retrofitting the M2C mirrors to the OG M2. https://f87.bimmerpost.com/forums/sh....php?t=1557865 https://f87.bimmerpost.com/forums/sh....php?t=1561537 https://f87.bimmerpost.com/forums/sh...ghlight=mirror Quote:
12-18-2020, 02:13 AM | #16 |
Rep 757
I think they are pretty easy to install but it's good to have a second set of hands to hold the mirror because once you remove the last bolt (3 total) it will fall off and, of course, could damage the paint on the door or the door itself.
Getting the 'door card' off is pretty easy, 5 torque head screws (2 on the bottom, 2 inside the handle under the CF cover and 1 behind the cover of the opening handle) and a bunch of button clips. Start on the bottom inside corner with a plastic tool and work it until you hear a couple pop and then you should be able to get your fingers under it. The top along the window has a bunch of clips but you should have all the rest loose at this point and just pull straight out starting on the inside. There are 3 electrical connects inside the doors plus the cable running to the door lock. The driver's door has a lever style connector (push down the clip, rotate the lever about 70 degrees to remove the connector) for the control panel, the passengers side is a simple push on. The hard part is getting the insulation and little speaker off as you need to get behind them to get to the bolts. Top Gear Top Tip, take some photos of this area and how the wiring runs to help reinstall it. The replacement mirror housing fits exactly when original one used to be but check the bolt holes on the new mirror housing. Not sure about all but mine didn't have screw threads cut in them and the bolts were not self tapping. Maybe this 'kit' will come with self tapping bolt or with the thread already cut but I ended up running a tap into them before putting them on the car. I didn't have the right tap for captive holes so I just use the tap I had to cut a few threads at the top of the hole to allow the bolt to thread and then used the bolt to cut the rest as it went down. This makes it hard to judge how tight to torque the bolts but when you think you have them all tight, check if the housing is loose. I tightened each bolt a turn at a time. The mirror caps come in primer gray so you'll have to have them painted before doing the install. I have no problem with anyone going the cover only route but the real deal are the real deal for a reason! Enjoy
'17 M2 DCT Long Beach Blue
12-18-2020, 08:30 AM | #17 |
Rep 4,551
Drives: 2015 328d xDrive
12-18-2020, 09:16 AM | #18 | |
Private NumNuts
522
Rep 321
You did get a much better deal on the housings at 384.20€ ($470.45) each whereas I paid $585. The other items aren't comparable.
12-18-2020, 09:27 AM | #19 | |
Rep 4,551
True, but I wouldn't be able to justify paying twice as much just for the carbon caps. |
NYC Bimmer259.50 |
12-18-2020, 09:30 AM | #20 | |
Private NumNuts
522
Rep 321
https://bmwrecambios.es/Mirror-glas-...83-51168065297 Either way, the Euro mirrors are awesome and I'm glad you got them. Anyone following this thread who goes either route will love them.
12-18-2020, 09:34 AM | #21 |
Rep 4,551
Yup, 100% sure. Mirror goes from silver to blue in the specific lighting circumstances that trigger it.
Yes, they are great! Huge difference in blindspot visibility. |
NYC Bimmer259.50 nothingman522.00 |
12-20-2020, 07:33 PM | #22 | |
Rep 11
dtmurf481.50 |
