07-12-2020, 02:07 PM | #1 |
460
Rep 471
Front license plate "solution"
Obviously, many of us want to avoid drilling into the front bumper. Now, I realize this topic has been beat to death and yes, I pretty much looked through all the current solutions offered, such as carbonio, sto n sho, magnets behind the bumper, etc.
However, I prefer simpler solutions, which is why I narrowed it down to double-sided tape. From a lot of the reading I've done in the last week or so, it appears that 3M double-sided tape should do the trick. After all, that's what BMW uses to attach EU delivery plates and those suckers are on there tight. I was thinking about pairing it with the 3M adhesive promoter, as is recommended by 3M. Several people said that it will be impossible to remove without damaging the paint, but if it's anything like spoiler/emblem removal, then I don't think it should be a problem. In my experience, fishing line or dental floss does the trick paired with goo gone. I narrowed it down to this tape, but I'm open to other recommendations: https://www.autogeek.net/3m-auto-tape.html The only thing I'm concerned about is whether there will be enough backing support to hold the US plate securely in place due to that part of the bumper not having enough surface area. This is where the EU plates have an advantage. They are wider, but shorter. I hope people don't mind me borrowing their photos for the purpose of illustrating what I meant: Last edited by 19x; 07-12-2020 at 02:37 PM.. |
07-12-2020, 02:49 PM | #2 |
this is the way
18148
Rep 8,525
You don't need adhesive promoter. 3M makes different hold ratings of double sided tape, 5-lbs, 15-lbs, etc. Obviously the higher the weight the more holding power. The paint needs to be prepped by removing any wax/sealant for optimal adhesion. FYI, STO N SHO uses double sided tape and they don't fall off.
07-12-2020, 03:52 PM | #3 | |
460
Rep 471
Also, as far as I know, sto n sho still requires one to drill a hole underneath the bumper. I’d like to avoid any holes. I don’t see how their mount can be attached safely from the bottom using just that tiny strip of tape they provide. |
07-12-2020, 04:14 PM | #4 | |
this is the way
18148
Rep 8,525
07-12-2020, 04:28 PM | #5 | |
460
Rep 471
I think you misunderstood what I meant about the surface area. I’m saying that if you want to attach the US plate directly to the front m2 comp bumper with double-sided tape, only about 1/3 of the plate’s surface area will actually Be fastened to the bumper. The Euro plate is shorter and as you can see in the photo, half of it adheres to the bumper. |
07-12-2020, 05:30 PM | #7 |
460
Rep 471
Unfortunately, that’s not an option for me. It will get you a no-front-plate parking ticket in most states, I guarantee it. Also, many states don’t let you “fix it”. In short, I don’t want to deal with getting harassed by police and meter maids over not having a front plate mounted. I’ve gotten nailed for it so many times throughout the years, I lost count.
07-12-2020, 05:49 PM | #8 |
Flavor of the month
888
Rep 716
Drives: BMW F87 M2C
My solution is to not use a front plate. Boom, your welcome.
Samuel of the Internet
2023 F98 X4M Comp 2023 F95 X5M Comp 2020 F87 M2 Comp |
07-12-2020, 05:50 PM | #9 | |
Rep 1,968
I wonder why they show using 3M tape *and* securing with a screw. Perhaps many folks get away without the screw. When I first looked at the Sto n Sho, I thought it was dumb because I don't want to drill a hole in the underside of the bumper either! I find it a little disingenuous to say: "Never requires holes to be drilled into the front of your bumper" |
07-12-2020, 05:54 PM | #10 | |
460
Rep 471
07-12-2020, 05:58 PM | #12 | |
Rep 2,067
I'm 27 and I've never even heard of anyone around me or in my life getting that ticket |
07-12-2020, 06:01 PM | #13 |
460
Rep 471
I wish it was that easy around here. I’m in IL and like I mentioned before, I’ve gotten nailed for it more times than I can remember. I’ve spent thousands on parking tickets due to not having a front plate. I’ve been pulled over for it many times, as well.
07-12-2020, 06:03 PM | #14 |
460
Rep 471
07-12-2020, 07:35 PM | #16 |
460
Rep 471
I had the tow hook mounted front plate for a few years on my other BMW's, but I always secretly despised that look. It looks like crap IMO. I'd rather just drill the damn holes and mount the OE bracket in the center. I prefer symmetrical solutions, which is why double-sided tape is the only clean OE-like option I could think of that doesn't involve drilling.
bubsterino171.00 jkoral1023.00 |
07-12-2020, 07:41 PM | #17 |
Rep 786
i guess thats fair. I just run without a plate even though i'm in CA and its required. I havent had an issue so far though in the 5 years ive run all my cars without front plate. But i also dont drive like a hooligan so i think that helps
Brandt51887.50 |
07-12-2020, 07:46 PM | #18 |
171
Rep 436
same here. In DC or VA you will get a ticket more times than not when street parking.
07-12-2020, 07:47 PM | #20 | |
171
Rep 436
realize you said you researched this, but i went with carbonio and have had zero issues. https://carbonio.com/products/bmw-m2...se-plate-mount |
19x459.50 |
07-12-2020, 07:50 PM | #21 | |
Rep 308
If you live in the city, proper, you'll get a parking ticket for something at least 3-4 times per year. They'll get the f*cking ruler out and ticket you if 1 wheel is more than 6" away if it's a slow night... No plate and parked, even in OHare or Midway garages, and you might as well put a red flashing light on your car. Suburbs are much more lenient. I'm sure to get 1 tomorrow now that I'm tempting fate, but I've been pulled over once in Bartlett (let me go w/a "warning"), and once in Schaumburg ~15 years ago. Other than that, no probs. When I go to the city in the Audi, I use the tow-hook plate mount. It works if it's more of a parking issue. Also, what color is your car? The all black Sox plate on a black car is actually really low-key and almost cool looking. That's all I got... Now prepping for my ticket tomorrow |
19x459.50 bubsterino171.00 |
07-12-2020, 08:13 PM | #22 | |
Rep 3,291
