06-24-2023, 05:18 PM | #287 | |
Rep 7,527
Proof: Additionally: https://autocouturemotoring.com/prod...nt-plate-cover Hmm guess I do know what I'm talking about, can't say the same about you though.... You should probably stop talking before you continue to humiliate yourself.
06-24-2023, 05:21 PM | #288 | |
Rep 7,527
Check your settings in ISTA and ensure it's configured for a wired or wireless connection (whatever you have).
06-24-2023, 05:37 PM | #289 | |
Rep 1,401
I don't want to imagine if you run out of internet for a month, you must have a heart attack |
06-24-2023, 05:53 PM | #290 | |
Rep 7,527
Also Google red herring fallacy, because that's what you're doing right now.
06-24-2023, 06:57 PM | #291 | |
Rep 7,527
But I disagree with this, the clutch pack friction material isn't all MoS2, I don't even know if it is used in clutches to begin with, as I could only find this being used as a lubricant or friction reducer in fluids and additives, but not in clutches. According to friction materials:https://www.frictionmaterials.com/cl...0in%20clutches. Clutches are generally composed of: Ceramic, copper, steel, iron, mineral, cellulose, aramid, chopped glass, rubber and brass fivers are all used in the creation of composite materials used in clutches. And iron is absolutely magnetic. This is where all the black gunk comes from on differential magnetic drain bolts. Also, Iron as an additive in oil is barely present (at most 1-2 ppm) and that is not going to be enough to account of all the black debris on drain plugs. Iron also isn't going to be the main anti-oxident agent in oil, ZDDP (zinc) is one of the most potent anti oxidants in oil and it is always present in way higher levels than iron is. SAPS are also common antioxidative additives, and these again are present in very high amounts in oil (even more than ZDDP). But iron is never really relied upon as an antioxidant, nor as a detergent (that is what the other additives are for, iron is so sparsly present in oil that is is probably the least useful additive in oil). Here is a paper talking about it: https://www.lubesngreases.com/magazi...n-engine-oils/ and also talking about potential alternatives to ZDDP as oil compositions change to meet more evironmentally friendly targets.
06-25-2023, 06:17 AM | #292 |
Rep 432
Drives: F87 M2 DCT, F15 X5
Aside from the benchmarking we did at my work on the axle, BMW even says it’s Moly based in the technical documents. The clutch plates themselves are steel, and they are coated in MoS2 to reduce friction. I’ve seen the scanning electron microscope element measurement plots!
Never heard of iron being used as an additive. I’m familiar with its role as a wear particle and an oxidizer. |
F87source7356.50 |
06-26-2023, 01:13 AM | #295 |
Rep 7,527
I would stick with genuine bmw, and since you're in the UK you most likely can get MSP/A. North America has switched to SAF-XJ now.
06-26-2023, 01:33 AM | #296 |
Rep 7,527
So for the diff get this:
For the 6mt get redline dctf or motul dctf high torque, because the gear box seems to not be too picky about what oil it takes, and the stock fluid seems to degrade too quickly and these aftermarket fluids noticably improve shift feel.
06-26-2023, 02:40 AM | #297 | |
Rep 8,972
I noticed the MTF-LT5 oil spec brings up various DCTFs which advertise as Dual Clutch Transmission Fluids? They say for Dual clutch boxes, but they also list MTF-LT5 as an approval... I suppose gears are gears and as long is it doesn't upset wet clutches in wet DCTs it will do DCT or Manual versions. I noticed the regular Motul DCTF has MTF-LT5 approval, but the Hi Torque version does not? I an get redline DCTF for same price as Motul Hi Torque and redline is full syn and lists MTF-LT5 Last edited by doughboy; 06-26-2023 at 02:58 AM.. |
06-26-2023, 03:05 AM | #298 | |
Rep 7,527
Yes, because MTF-LT5 is actually a low viscosity DCTF, hence why DCTF fluid satisfies the requirements to be MTF-LT5. I remember chris719 talked to motul and they said their Hi torque version should be MTF-LT5 compatible. But the reason why you should get Hi Torque over regular motul dctf is because it is a better base stock oil. But redline dctf is just as good if not better imo (and alot of guys on the forum are using it with great success), so get whatever is easiest/cheapest. If it were me I would get the redline dctf - which I am planning to do later this year or next year.
06-26-2023, 03:12 AM | #299 |
Rep 8,972
Great thanks, I'll get the red line then.
I use an independant workshop, but I buy all the fluids myself in advance and take them along and they just use them so I know exactly what's going in. Also be sending samples away for analysis as its 5yo now, make sure there's nothing in the oil that shouldn't be there. |
06-26-2023, 03:23 AM | #300 | |
Rep 7,527
Don't forget to buy new drain and fill bolts for the diff.
06-26-2023, 08:37 AM | #302 |
Rep 7,527
No it doesn't, it doesn't have a drain or fill washer either.
06-26-2023, 08:52 AM | #303 |
Rep 8,972
Yeah I noticed gearbox plugs have no o-ring or washer, but the diff ones do.
Suppose "officially" the gearbox is sealed for life so of course no one will ever need to remove the plugs... |
06-26-2023, 01:41 PM | #304 | |
Rep 7,527
But strangely the gear box seals well without the washers or o-rings.
07-02-2023, 10:05 AM | #305 |
Rep 882
According to Motul's website they recommend DCTF for the MT and DCTF High Torque for the DCT. But I'm sure the High Torque works as well. I use the regular Motul DCTF in my car and it works just as well as with the stock oil.
BMW M2 LCI -18 | BMW 520DA Touring M-Sport -12
| BMW Z4 M Coupe -06 | BMW M3 -02 | BMW Z3 Coupe -99 | BMW 740i/6 -96 | BMW M5 3.8 -92 | BMW M535i -87 |
07-02-2023, 10:07 AM | #306 |
Rep 882
You can re-use the diff plugs as well as long as the o-ring sits proud, if it doesn't you can always change the o-ring only.
07-02-2023, 03:13 PM | #307 | |
Rep 8,972
Easier than hunting for an o-ring on the day. |
07-02-2023, 03:45 PM | #308 | |
Rep 7,527
chris7197389.00 |
