03-31-2022, 10:05 PM | #67 |
Rep 4,255
This is hilarious. If you were to send your torque spec to the moon with a piggyback why wouldn't you install at least a crank hub capture plate? It makes no sense to me. This whole kickdown thing is irrelevant as well. This is a torque issue. BMW for whatever reason used a part here that, in the best of scenarios, handles the stock torque and that's about it.
Kudos on not trying to weasel into a warranty situation. Btw I suspect since your timing was so off that it had slipped slightly in the past and your startup just was the FNITC. One more thing. To those saying "well that's weird I live in (sea level country) and I've never seen a spun crank hub", consider that, at altitude, these motors run a nontrivial amount of increased boost to compensate. Could be why you hear about it more in some places versus others. Anyway enjoy your new build! As far as M motors go, the fact there is only one relatively simple failure point is a blessing. No water pump or rod bearings on the s55 edit: I have rethought this, and the capture plate makes no sense. Doesn't change the sprockets from spinning and unequal rates. That's what affects timing and can lead to failure. I have also concluded that one way or another the crank hub setup on these cars is just bad. It "should be fine" but why it isn't keyed is beyond weird.
///M Power
beezyM2C13.50 |
04-01-2022, 01:55 AM | #68 | |
Rep 416
Every good shop I know nowadays recommends people to avoid this capture plate and go straight to the one piece crankhub solution |
04-16-2022, 04:54 AM | #69 | |
S0THPAW
8733
Rep 7,847
Cheers Robin |
06-15-2022, 03:19 PM | #70 | |
Rep 57
CBC does nothing after the fact of get the hub properly done
2020 M2C 560/540 f80 paul stock turbos,
7??/6?? Kratos EVOS |
chris7197363.50 |
06-15-2022, 03:32 PM | #71 |
Rep 8,972
Respectfully you guys are not thinking what torque is and how its equally about torque reaction as about torque action..
Think about it. If you have a 1000lbft engine, if it is turning a small load (say a water pump) with a max torque reaction of 25lbft then the max torque that the 1000lbft motor can ever apply to the water pump is 25lbft. The torque reaction from the s55 valve train is constant over rev range and pretty small, regardless of how much torque the engine can put out at max load. The maximum torque possible (thus acceleration) to the valve train is either free revving in neutral or during aggressive kickdown or bad MT downshift, neither of which are related to tuned max load torque output. The engine could never apply its max torque to the valve train. The torque reaction from the gearbox is overwhelmingly more than the valve train so the tuned engine torque will only ever over load transmission etc, the valve train will not be affected during driving by crank torque. Only overaccelerating or over revving the valve train will result in higher torque values that may causd CH spin and this can be done with any standard engine easily if driven badly enough. Last edited by doughboy; 06-15-2022 at 03:56 PM.. |
JoanLluch31.00 |
06-22-2022, 02:41 PM | #72 | |
Rep 170
06-25-2022, 07:13 PM | #73 |
Rep 179
I've seen them spin bone stock. It's that flimsy friction disc BMW puts between the sprockets to keep them from jumping time. That why solid one piece hubs are the best in my opinion.
06-25-2022, 07:46 PM | #74 |
/M Enthusiast
1603
Rep 1,619
I’m reading this and thinking it’s a crap shoot.
I had a 2015 M4 6mt that I tracked for over 3,500 miles on BPM stage 1. I have a 2019 M4 DCT that I have tracked over 3,500 miles BM3 stage 1. 24k miles on the car. I have a 2019 M2c DCT that has over to 6,000 track miles on it BM3 stage 1 and stage 2 E85. 14k miles on the car. The S55 is damn reliable.
2019 M2 Comp, Alpine White, DCT, track car build, 1/2 cage, AP Racing Brakes & Nitron Coilovers, BM3 Stage 1 93 Oct.
2018 Porsche Cayman GTS, Night Blue Metalic, PDK, COBB tuned 93 Oct. 2004 Audi A4 Avant USP 6mt, RS4 clutch, built motor, Garrett GT3071r "Big Ass Turbo" Motoza Tune |
06-25-2022, 09:17 PM | #75 | |
Rep 7,318
06-26-2022, 01:34 AM | #76 | |
Rep 42
So if that's the case, it ultimately looks that it may depend on the driving style whether this will happen or not. |
06-26-2022, 02:51 AM | #77 | |
Rep 7,318
06-26-2022, 04:07 AM | #78 | |
Rep 42
I mean I believe that the same kind of 'abuse' on a stock car might actually cause exactly the same issues because that's when excessive torque -beyond the linear one produced by a Stage 2- is actually supported by the transmission |
06-26-2022, 03:18 PM | #79 | |
Rep 7,318
