06-27-2020, 09:25 PM | #1 |
Rep 81
trouble after disconnecting the battery
I just upgraded my steering wheel and in the process needed to disconnect the battery, after reinstalling the new wheel assembly and reconnecting the battery I noticed two things, 1. the windows don't drop when closing the door, 2. There is a new light "DSC OFF" that is lit up on the dashboard in the tachometer gauge. Do I need to do something to reset some settings, any ideas?
06-27-2020, 09:47 PM | #2 |
Rep 81
ok i managed to reset the windows, any ideas on the DSC OFF light,
What does this mean? The little icon of the car skidding does NOT light up, is this different? Last edited by m2compred5; 06-27-2020 at 09:49 PM.. Reason: adding pic |
06-27-2020, 10:33 PM | #3 |
Rep 1,977
Drives: 2020 M2C HS & Ferrari Roma
Have you tried turning the steering wheel all the way to the left and then all the way to the right?
2020 M2 Competition | Hockenheim Silver | 437M Wheels / 763M Wheels | RHD | 2NH Brakes OEM M2 CS Steering Wheel | MP Carbon Steering Wheel Trim | MP Pedals | MP Dash | MP Interior Kit OEM M2 CS Bonnet | M Performance Coilovers | MP Rear Spoiler | MP Rear Diffuser| Perl Carbon Front Lip | Remus Race Exhaust |
paradocs98398.50 |
06-28-2020, 05:33 AM | #4 | |
Rep 1,519
Re. the windows: I disconnected my battery and had to remove the steering wheel airbag module in order to swap out my M1 and M2 buttons for blue ones. I didn’t think to do this with the driver’s window down. When I was finished and reconnected the battery, I began to close the driver’s door and realized just in time that the window had inched up to the “door closed” position when the door was fully open. I almost slammed the top of the window into the edge of the roof.
Past: E46 330Ci, E60 545i, E60 M5, E90 M3
Present: 2020 M2 Competition, 2022 GT3 |
06-28-2020, 09:57 AM | #6 |
Rep 1,977
06-28-2020, 04:14 PM | #7 |
Rep 81
OK, i am afraid i screwed the pooch on this one.
When i had the wheel off i turned the disc that holds the female end of the plugs and must have wound the wire ribbon inside the hub, after reinstalling the new wheel, to reset the computer i turned the wheel all the way to the left and all the way to the right, when i went all the way to the right i could hear something clicking, and i think i damaged the internal wire or wire connection inside the hub. any idea how bad this will be to repair? Now none of my steering wheel controls work and i have a air bag malfunction light on. |
06-28-2020, 04:27 PM | #8 |
Rep 81
I think the part i need to replace or repair is the slip ring
Any ideas on how hard that is to replace? I doubt the dealer will cover this repair as i am the one who caused the issue by my F up moving the slip ring before re-istalling |
06-28-2020, 04:39 PM | #9 | |
Luxury at the redline :)
9108
Rep 7,563
There is a 50/50 chance they fix it, under the warranty or just tell you to go kick rocks.. Whatever, you might not get into Heaven but you would save a bunch of money on this current F-up.. You can break down the part numbers below, if you decide to DIY the repair.. https://www.realoem.com/bmw/enUS/select |
06-28-2020, 05:59 PM | #10 | |
Rep 81
Poochie9107.50 |
