06-15-2022, 04:35 AM | #1 |
Rep 660
Stuttering at 6500+ RPM (Pure Stage 2)
Hey all,
Before I go running off to buy a set of upgraded coils (most likely the B58 coils + nesys mounting kit), I'm wondering if anyone is familiar with what would cause what is shown in the log? https://www.bootmod3.net/log?id=62a7...729b049521b434 Mod List: - Upgraded CP, BP, 200 Cell DP, MST Inlet, 5" Intercooler - Dorch Stage 2 HPFP - 3.5 bar TMAP (although I feel like maybe I got sent the wrong one because there seems to be a large delta between boost pre-throttle and the MAP sensor after the turbo spools up lol, P/N checks out though) - Pure Stage 2 Turbo /w VR11 BOV - BM3 Stage 2+ E30 OTS Map with flex fuel (running E46 in the log) - New N55 coils and 1-step colder NGK spark plugs gapped to ~0.023" (as recommended by bootmod3) Right about 6500 RPM in the 3rd gear run you can see the RPM start fluctuating wildly and the car feels like it almost hits a soft limiter - I assume this is a some sort of misfire and/or the flame being blown out by my E46 mix (no codes, though)? I'm guessing this may be remedied by gapping even smaller, but I hear that can lead to rough idling and less efficient combustion, so that is not my preferred route. HPFP looks good so I don't think it could be fueling related - would the LPFP not being able to keep up also result in this issue even if HPFP is holding pressure? I had another run with E32 which didn't seem to have the stumbling at 6500+ RPM: https://www.bootmod3.net/log?id=62a9...90c60d16821337 However, I'm not sure if it's a 1-to-1 comparison since the octane is much lower (due to less E, plus bad CA gas) and IATs ~10 degrees hotter so the car pulled much more timing which may have prevented the engine from reaching the same levels as in the first log. Perhaps the most efficient way would be to try gapping to around 0.02" and see how that affects the car and see if it resolves the issue at the top end? Sorry for the long winded post, but if anyone has any ideas and has run into this before, any input would be greatly appreciated! TIA! Last edited by eeyang92; 06-15-2022 at 02:41 PM.. |
06-15-2022, 07:41 AM | #2 |
Rep 643
the log you posted doesn't show any issues.
1. if you changed the tmap sensor, did you ensure you made the change in tune configuration and flash? looking at your log, it is common in bm3 tunes to overshoot boost target at spool, then the throttle plate is used to correct. the tmap will show a higher boost (pre throttle plate) vs the map which is post throttle plate. so overall, the tmap behavior in your log is normal for this tune. 2. the title of your log is multimap stage 2+, not per your description of stage 2+ e30.. 3. your spark plug gap is off by a decimal point... are you sure you are at .0023" and not .023"? stock gap is ~.031"
M235i rwd 6mt
eeyang92318.50 |
06-15-2022, 12:52 PM | #3 | |
Rep 660
1. Yes, it is set to 3.5 bar - and I'm glad to hear it's fairly normal to overshoot at spool. So in general, MAP is the more relevant value to be looking at and not the pre-throttle boost? 2. Ah sorry, yes my mistake - to clarify it is indeed the multimap stage 2+ on the E30 map (map 1) with flex fuel enabled 3. Indeed it should be 0.023" - that's what I get for posting at 3am my time Regarding the issue of the top end of the first log I posted (https://www.bootmod3.net/log?id=62a7...729b049521b434) - I think I can see the engine pretty much sputtering 6500+ RPM, and I can definitely feel the engine stop pulling (at which point I got off the throttle since I don't want to cause damage). Last edited by eeyang92; 06-15-2022 at 01:08 PM.. |
06-15-2022, 01:22 PM | #4 | |
Rep 643
M235i rwd 6mt
06-15-2022, 01:42 PM | #5 |
Rep 643
after reviewing the right log, i can see the issue now. you have throttle closure to 75% at 6500rpm (adds to the sensation of misfire), but unknown what caused it. lambda is non typical after 5700 rpm. the load actual is also strange after 5700 rpm.
i'm inclined to agree this might be a fuel issue, however, gapping tighter is free and at one point when i was as tight as .018, my idle and mpg was fine.
M235i rwd 6mt
eeyang92318.50 |
06-15-2022, 02:02 PM | #6 | |
Rep 660
Thanks for the suggestion, I'll try going down to 0.02" and then 0.018" if the issue still persists. I haven't heard much of a need to upgrade the LPFP but perhaps it may be needed here (and maybe fix the low fuel pickup issue at the same time). Dorch Stage 2 should be good for ~550 WHP on E50 (taking a conservative average of their claims from their site: https://dorchengineering.com/product...-hpfp-upgrade/), and I'm pretty sure my car is not making anywhere near that, so I don't think I'll need to get their Lift Kit. |
06-15-2022, 03:53 PM | #7 |
Rep 3,699
Kinda similar issue here with a tuned PS2 setup. Maybe there’s some kind of limit in the OTS maps that you guys are hitting?
https://f30.bimmerpost.com/forums/sh....php?t=1922739 Worth an ask to PTF. |
eeyang92318.50 |
06-15-2022, 05:26 PM | #8 | |
Rep 660
I also did get in contact with Halim and he pointed out similarly how the AFR was not normal, and it is potentially the coils/plugs. But if not, I will try the LPFP after that. I'm only targeting E50 at most so if I don't have to upgrade the LPFP that would be preferrable, but perhaps it may have to be the case. |
07-21-2022, 08:48 AM | #9 | |
Rep 83
2020 MW M340i
07-21-2022, 12:52 PM | #10 |
Rep 660
