12-17-2018, 05:10 PM | #1 |
Rep 456
What size wheels for track days - 18" or 19"?
Hi all,
I have bought a set of 763M performance wheels with Cup 2 tyres for track day use for when I get my M2C in April. However, I have only just started questioning whether I should have bought a set of smaller 18" wheels instead of the 19" 763M's. For a novice track day person like myself I am sure they will be amazing, especially with the Cup 2's (I have heard amazing things about them in dry conditions), but it would be good to hear other people's thoughts on what size wheels they use? Cheers as always, Karlos
2019 HS DCT M2 Competition with Essex AP Racing Radical Pro5000r front and rear BBKs, Bilstein B16s and 763M wheels with Cup 2s
12-18-2018, 04:37 PM | #2 |
3513
Rep 6,744
Congrats on the car! If you ordered the optional larger brakes, your M2C will require 19" wheels. If you opted for the standard brakes, read on, as you'll have many factors to consider!
Everyone has their own priority list, so these factors mean different things to different people. To break things down a bit: Performance
Saftey For every legitimately engineered, tested, and properly rated wheel out there, there are 10 that aren't. It is important to make sure your track (and street) wheels carry a sufficient load rating to cope with the demands of track use such as sitckier-than-stock tires, increased power, additional downforce modifications, and more aggressive brake compounds. All these factors can 10x the amount of stress placed on a wheel, and you should make sure they are up to the task. Aesthetics Do you want the lightest possible setup? Or do you want to make sure you close that wheel gap just right? For some, track days and HPDEs are just something fun to do every now and then, while others are out there chasing tenths of a second. Cost Smaller wheels cost less. Smaller tires also cost less. Wheels & tires become consumables when used on track regularly. Get where we're going? With all that said, the 763M wheels are a fantastic choice for track use, and are surprisingly light for OEM wheels. Our only hesitation would be the risk of damage, in which case they are quite costly to replace. Aside from that, they'll look phenomenal and should serve you well! --Dylan
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers Last edited by Expert@ApexWheels; 12-18-2018 at 04:58 PM.. |
r121444.00 |
