M2 Technical Topics > Cosmetic Modifications > Tips for swapping front kidney grills?
      11-06-2018, 10:25 PM   #1
ecitizen
Drives: 2013 328i
Is it possible to swap the factory front kidney grills without unscrewing the front top of the bumper and just using your hands and a tool to pry it off the front by reaching through the slats?
      11-07-2018, 02:01 AM   #2
Fedorov
Fedorov's Avatar
162
Drives: BMW 330i G20
I guess it's possible but you'd need the right tools and I'd estimate that it's easier, however painful it can be, to unscrew the top instead...
Especially once you get the first one off you can remove the other one muuuch easier by accessing it via the "space" from the removed one...
      11-07-2018, 09:44 PM   #3
heavyD^2
heavyD^2's Avatar
3689
Drives: X3M Competition
Popping out the top of the bumper cover isn't a big deal. It all goes back perfect and won't be noticeable after.
      11-18-2018, 10:47 PM   #4
codylikerice
69
I dunno but even unscrewing the top bumper it's still a pain in the ass. It's really quick to unscrew the bumper and remove the rubber seal, so I wouldn't worry about it.
      11-19-2018, 01:36 PM   #5
M Fifty
844
Drives: M2 & 330CI
It's very possible. You just need an appropriately shaped tool.
      11-20-2018, 10:43 AM   #6
McPurrs
The deuce gets loose
290
Drives: '17 M2 BSM 6MT
Move the rubber, take the screws out.. I was able to get the top clips to release with a screwdriver, and a quick tug pulled the rest out.
      01-08-2021, 05:36 PM   #7
3t3p
New Zealand
455
Coathanger with ball type end on the hook.
You can depress the remaining tabs you can't get to with your hands.
Don't need to take front bumper off.
      01-08-2021, 05:42 PM   #8
TargaM2
M///modifyer
TargaM2's Avatar
2489
2015 Renault RS275R  [9.50]
2019 Renault RS280  [10.00]
2017 BMW M2  [10.00]
2018 Audi Q2  [5.50]
Remove the rubber seal, Unscrew the 6 torx screws, pull the bumper section forward, stuff your hand in there & depress the clips, pop the grill out, done.
Pulled grill out again last night to fit the AFE intake duct, took me literally 20 minutes from start to finish & that included fitting the duct. Simple job.
www.tarmacperformance.com
Best Modified BMW - BMW Nationals 2022
      01-08-2021, 05:50 PM   #9
Mosely
Mosely's Avatar
594
Drives: '18 M2 | '20 X5 | '07 E92
I've done mine several times. Never popped off the bumper cover. You can release the tabs with your fingers through the front. As you get each one loose, just keep pressure so it doesn't snap back into place. Just did it again recently when installing part of an intake and it took 5 minutes. There is one awkward clip (for my hands at least) in the bottom middle part of the grill that takes some creative positioning. The rest were easy.
IG Photo Gallery:
instagram.com/dr_m2sko/
