10-01-2018, 08:31 AM | #1 |
Rep 2,526
18" Wheels for Track Day?
I plan on doing a handful of track days per year, nothing serious, just some fun at the track. I know its probably a good idea to get a set of dedicated track tires. Since I daily my M2, and live in a part of the world where this crazy white stuff falls out of the sky for a few months, I plan on getting a set of 18" snow tires/wheels.
My question is, can I repurpose the 18" wheels during the better months of the year to use as my track wheels? Obviously I'd swap out the snow tires for some proper track rubber, but I was more curious if 18" wheel/tire setup are common/advisable on the track? Would I be better off getting 19" snow tires instead? Thanks |
10-01-2018, 09:35 AM | #2 | |
Rep 2,526
I'll shoot you a message. |
10-01-2018, 09:37 AM | #3 | ||
Rep 796
10-01-2018, 09:50 AM | #4 |
Rep 2,526
ashburyn54624.50 |
10-01-2018, 12:24 PM | #6 |
Rep 582
I use 18x10 square for dedicated track wheels. There are more tire options in this size wheel which is why you will see most M2/M3/M4 track guys running 18s.
In your case, I would be more concerned with what winter tire you can find for an 18x9.5 or 18x10 wheel. I haven't looked myself so maybe that is not a problem. |
10-01-2018, 12:39 PM | #7 | |
Rep 2,526
I'm probably going to grab a set of 19" snow tires and swap them out with my streets for the winter, and get a dedicated set of track tires/wheels. Unsure on size yet, but nice to know that 18" is an option, and likely a bit cheaper as well. Will dig into this more when springtime gets closer. Its getting close to end of season here and I probably wont have time to get out to the track. |
10-01-2018, 06:57 PM | #8 |
381
Rep 731
Apex has a group buy going on now for 18" SM-10 and FL-5 which fit M2. Just pledged for a set of 18" FL-5 Square set-up for the track. SM-10 is available for Staggered set-up if desired. I bought a 18" square set-up last year for dedicated winter wheels and tires for winter driving. Went with 245 wide and they were well worth the money spent. IMHO its a waste of money and time mounting and dismounting tires on wheels every year. Not to mention damage to wheels from wheel changers.
10-10-2018, 05:07 PM | #9 | |
Rep 468
I've pledged for a set of EC7 18's which, like the OP, I plan to run as my winter and track setup... Apex assures me a square 18 setup won't cause any problems with traction control either at the track or during winter driving... but my local performance shop guy says otherwise. Can anyone shed light on this? |
10-10-2018, 07:03 PM | #10 | ||
3511
Rep 6,731
To answer the OP's question, 18s are perfectly fine, and actually preferred for both winter and track setups for the reasons mentioned in earlier posts - cost and weight. For a track setup, you typically want the smallest diameter possible that will clear the brakes. There isn't as much of a difference for a winter setup, but 18" tires are generally less expensive, and a slightly taller tire sidewall makes for much improved ride quality over rough roads. With that said, the M2 Competition will require 19" wheels due to the larger factory brakes, so that makes it an easier decision. We have compiled all of our recommendations in our fitment guide here: https://support.apexraceparts.com/hc...-Fitment-Guide Hope this helps! --Dylan
10-10-2018, 07:56 PM | #11 | |
381
Rep 731
dcmac438.50 |
10-13-2018, 09:53 PM | #12 | |
Rep 817
dcmac438.50 |
11-30-2018, 07:34 PM | #13 |
Rep 2,526
Bumping this thread again cause I have another question.
The Apex fitment guide recommends 18x9.5 ET28 wheels if you're running 265 35 18 track tires. In browsing around, it seems this is a really limiting offset. Is it possible to run a slightly higher offset, say ET35 and not have any issues? If I understand correctly, only lower offsets will run into clearance issues. Obviously I wouldn't want to deviate too much, but I figured 7mm difference isn't going to change a whole lot. I ordered a set of camber plates already, so that's out of the way. EDIT: is it worth bumping up to 275/35r18 at this point as well? I can always dial in a bit more camber if needed. How is that going to affect my stock wheels and tires on the street? |
12-01-2018, 08:55 AM | #14 |
Rep 2,526
Sorry, I think I had my offsets backwards. Looks like 35 offset would likely require at least 5mm spacers.
So let's go the other way, what about 25 offset? Those seem to be easier to find than the elusive 28 offset that Apex recommends. |
12-05-2018, 09:15 PM | #15 | |
Rep 468
