11-14-2018, 09:15 PM | #47 |
Rep 16
Drives: 2019 M2 Competition
My owner's manual has tire specs for an M2C for 235/40R 18"...is anyone running an 18" setup on an M2C? (p213)
Granted, this was specially for an all season tire. |
11-18-2018, 06:13 PM | #48 |
Rep 1,124
I'm running four 245/40R-18 MICHELIN PILOT ALPIN PA4 XL on 18"x 9" ET 40 wheels all around. No rub and awesome traction in the snow.
11-18-2018, 06:49 PM | #49 |
756
Rep 2,149
I just ordered 265/35 and 285/35 Scottzero 3 tires for the stock 437m wheels because that's what I normally run in summer.
I went opposite of everyone and went wider than stock for winter. I don't believe narrower would be beneficial for the type of driving I do. I work from home and can wait for the roads to clear before leaving, so there won't be any snow I need to cut through. I also think wider tires will give me more lateral grip, for situations when I'm stepping on the brake with the wheels turned, but the car is still going straight cause there is no traction. I don't know. Just seems like narrower tires would only be good for plowing through snow. But the way I drive isn't mainly plowing through snow. I don't think a narrow tire is gonna help when you're going up hill and there is ice on the road that is too solid to cut through. etc. |
11-22-2018, 07:09 AM | #50 |
Rep 3,291
Not with the big brakes that we all got in the US. No 18's for us. 18's fit over the smaller blue-caliper brakes that are stock in other lands. The 19" 641's barely fit (just put my winter set on yesterday).
11-22-2018, 11:14 PM | #51 |
Rep 1,092
put these on today
18x9 ET30, 245/40/18
The wheels are 720Form GT2, 19lbs flow formed, super cheap - $250 Canadian so probably under 200 USD The front is not quite flush with 7.5mm spacer but the rear is ok with 10mm. Last edited by mr_lab_rat; 11-25-2018 at 08:58 PM.. |
11-24-2018, 08:52 AM | #52 |
Rep 43
11-25-2018, 09:40 AM | #55 |
Rep 43
^ Looks great - thanks for posting. I was torn but decided to go with a slightly used set of black 788’s for my winter set up - will probably pair with PA4’s.
11-25-2018, 11:40 PM | #57 |
Rep 43
Ok - so trying to decide which winter tires to go with on OEM 19" wheels. Not planning to drive the car with any snow on the ground - will drive the beater SUV - but cold temp performance is important (and would be nice to have something that could handle some inclement weather in a pinch if need be). The options I'm considering:
1) Pirelli Sottozero Serie II in stock sizes (245 front / 265 rear) 2) Michelin Pilot Alpin PA4 - 245 front / 255 rear (I assume this would fit ok) 3) Continental ExtremeContact DWS 06 (high performance all seasons) in either stock sizes or 255/275 Thoughts? I like the idea of the PA4s but the sizing isn't optimal (although could be perfectly fine in those sizes). Pirelli's seem ok although maybe not much better than the (less expensive) Conti all seasons. Anything else I should consider? |
11-26-2018, 12:39 AM | #58 | |
Rep 7,297
eddie_yvp28.50 |
11-26-2018, 06:43 PM | #59 | |
Rep 43
Edit - did some further research on the Conti DWS and the Michelin AS. Both seem to be highly regarded for what they are (a compromise) - with the Conti's rating better in the snow and the Michelin's a little better in the summer/dry/wet. So for my winter driving needs, the Conti's seem to be the way to go. Now just need to decide if I want to get them in the stock 245/265 or go a bit more aggressive with a 255/275 setup... Last edited by eddie_yvp; 11-26-2018 at 10:22 PM.. |
11-27-2018, 12:10 AM | #60 | |
Rep 7,297
The compounds of performance winter tires are actually quite similar to all seasons from what I can gather based on comments in some of the German and UK tire reviews. True winter tires like the WS80 and Xi3 are quite different, but I don't think you were considering those anyway. |
eddie_yvp28.50 |
11-27-2018, 05:55 AM | #61 | |
Rep 114
_________________
2024 M240xi Mineral White, HK, Premium Pkg, Xpel PPF, Xpel Plus 55% tint Sold - 2017 M240xi Mineral White, HK, OEMConcept 437M wheels, Curtis hitch for bike rack, MPE, Painted rear diffuser, Dinan Elite Stage 1 |
eddie_yvp28.50 |
11-27-2018, 09:16 AM | #62 |
Rep 4,516
Do you guys stateside get Michelin Cross Climate + ? 245/40/18 - gets good reviews...
Current '22 X3M LCI.. |
11-30-2018, 03:51 AM | #65 |
Rep 89
Just fitted a set of 18 x 8.5" ET30 Alutec Pearl with 235/40 Alpin PA4. Really happy with how they look and drive, not as big a compromise as I was expecting and they're a touch comfier which makes a nice change.
2+3=5285.00 Ultimateone172.50 |
11-30-2018, 06:32 AM | #66 |
Rep 632
