10-24-2018, 05:04 PM | #23 |
3517
Rep 6,758
We have a few options for the M2 Comp. It is such a new car so fitments are limited, I have listed them below. Please note that we have not tested the 19x8.5" ET35 on the M2C (as it is so new) so while we are fairly confident that this size will clear the brakes, we cannot guarantee it just yet.
Anyways, onto the recommendations: Front & Rear: 19x9" ET30 with 245/35-19 winter tires - M2C recommended fitment. - Direct fit. - Only available in the SM-10 design Front & Rear: 19x8.5 ET35 with 245/35-19 winter tires - Available in both the SM-10 and EC-7 Designs I hope this was helpful information! - Max
JTO245274.50 |
11-01-2018, 08:52 AM | #24 | |
never could compete with Lloyd Braun
5275
Rep 5,378
Thanks!
2022 G80 M3 6MT | Skyscraper Gray | Kyalami Orange
2018 F87 M2 6MT | Alpine White (sold) 2016 981 Cayman 6MT | Jet Black (sold) 2015 F80 M3 DCT | Tanzanite Blue | Gold Brown (sold) 2013 E92 M3 6MT | Mineral White | Fox Red/Black (sold) |
11-01-2018, 11:53 AM | #25 |
3517
Rep 6,758
You should have no issues running 255/35-19 tires all around. The SM-10 19x9" ET30 is scheduled to be in stock December. A little into the winter months, but we're trying to get them completed as soon as possible. They are currently on sale if you are interested.
11-02-2018, 12:01 PM | #26 | |
Rep 7,888
arn5552.00 |
11-07-2018, 06:46 PM | #27 |
Rep 462
How about going with some massive winters...? The 911 guys do it. I know it's contradictory to all the peak performance winter - narrow/square etc.
But how about 265/35/19 F | 285/35/19 R winters?
"... if he fails, at least he fails while daring greatly, so that his place shall never be with those cold and timid souls who knew neither victory nor defeat.” —Theodore Roosevelt
Instagram@particulardude |
11-08-2018, 10:00 AM | #29 |
Rep 860
I think you might have issues with this profile. I am running 255/35/19, and at half lock, I BARELY clear the inner fender liner.
"Anima sana in corpore sano"
11-08-2018, 07:20 PM | #30 |
Rep 979
Drives: 2024 M4 Comp X-Drive
I'm running Sparco Trofeo 18's with 245 square Blizzak MS80s from Tire Rack. (With TPMS)
[IMG][/IMG][IMG][/IMG]
2024 Dravit Grey M4 Competition X-Drive
11-10-2018, 02:38 PM | #31 |
Rep 88
Drives: 2018 BMW M2 | LBB | MT
640M Style OEM Winter Wheel Set
Winter Time!
Wheels: 640M Style, Front 8.5Jx18 ET27 / Rear 9Jx18 ET29 Tires: Michelin Pilot Alpin PA4 - Front 235/40R18 95V / Rear 255/35R18 94V Actually not too unhappy with how they look, although not winning a beauty contest with them. But these are the ones they use for testing in Sweden, so at least they should work well |
11-11-2018, 10:31 AM | #34 |
Rep 126
I just bought a square 235/40/18 tire setup (nokian R3) but I just realized it's smaller in diameter than oem summer of 3.4% in the rear and 1.6% in the front. Smaller of 1.2% than the recommended winter setup by bmw (245/40/18).
Would you guys have any concerns with that change ?! For your info I matched it with rtx graz wheels in 18x9'' ET40 with 17.5mm spacers all around. |
11-11-2018, 02:32 PM | #35 | |
Rep 14
11-11-2018, 02:47 PM | #36 |
Car Guy
38
Rep 115
So I sold the Hankook 255 40 19's and got myself on order some Gislaved 225 45 18's on a 18X8 rim. Hopefully will cut through the snow without any issues. Gislaved have always been good to me in the past.
11-11-2018, 11:07 PM | #37 | |
Rep 860
Not sure you're heading in the right direction. Your new set up (225/45/18) will be 6mm TALLER than the stock tires. Your new tires will be narrower, allowing greater clearance between the outer shoulder of the tire and the fender liner potentially, but it's impossible to know if you'll be OK, without knowing what offset your 18" wheels will be? Also, 225 is pretty narrow all around?
11-12-2018, 12:17 AM | #38 |
Rep 7,888
I got my setup on.Replika 8.5 x 19 @25P with Khumo 245/35 19's.My 255/35 19's Bridgestone LM001's would not clear the inner fender liners on the front.
11-12-2018, 09:07 PM | #39 |
Rep 900
245/35/19 Michelin alpine 4a is rubbing at full turn
N that is stock size Never had that problem on the og m2
2019 M2 HS 10000km and counting
11-12-2018, 10:37 PM | #40 |
Rep 7,888
11-12-2018, 10:41 PM | #41 |
Rep 308
Running
245/45/18 michelin xice. Side profile is a bit tall. It should have been 35 or 40 profile. Anyway, it does rub on outer edge of tire on inner fender liner on the front when full lock. Took out a heatgun and heated the area to push in and no more rubbing. Good thing is it fills up the wheel gap nicely |
11-13-2018, 07:12 AM | #44 |
Rep 900
35 PSI
only rubs on full turn I double checked the front and rear wheels to make sure they are not swapped by accident. lol
