11-15-2018, 03:38 PM | #45 | |
Rep 3,714
What does the switch do? Is there a function of the euro light that acts like a fog light (F1 rain light etc)? Are the tail lights plug and play or do they require coding if you don't care about the fog light switch? |
11-16-2018, 02:13 AM | #46 |
I INDIC8
612
Rep 1,286
Drives: 2018 LBB M2, 6MT
Euro tail lights work identical to US-spec (just with orange indicators), plug and play nothing else needed (Assuming you're going like year to like year, so LCI to LCI is a direct swap).
If you want to use the rear fogs, you need to code to enable them. Then you either need a European switch (with the dedicated button for the rear fog light, which also needs its own coding to not throw an error in the FEM), or you can physically remove your stock US-spec light switch, open it up, and cut some plastic away. All of the actual "switch" components already exist inside the US-spec switch, they are just blocked with plastic. If you've coded the car so the rear fogs "Exist" as a function, then you can hack the plastic off the switch, and the US-spec switch can toggle the rear fogs. The only thing you miss out by going this route is having the little icon on the button and the backlighting behind that button. So if you don't care about that stuff, save yourself ~$160 and just mod your stock switch instead of replacing it. Part numbers and other info on the rear fog stuff here... I think the euro tail lights are in another thread in this section if you search.
I'm an IT guy by trade and tech nerd by choice. I like HPDEs, parts of US Hwy 129, NC 28, and the Cherohala Skyway. I'm also a fan of aural pleasure. Last edited by ZPrime; 11-16-2018 at 02:21 AM.. |
CosmosMpower2050.50 |
11-20-2018, 11:48 AM | #47 | |
Rep 3,714
11-20-2018, 12:32 PM | #48 | ||
Luxury at the redline :)
9105
Rep 7,563
11-20-2018, 09:59 PM | #50 | |
I INDIC8
612
Rep 1,286
I'm guessing they actually aren't even orange - I suspect the indicator LEDs are straight up yellow, and they just blend through the red housing to create orange. But that's just a guess and would need to tear apart the light to know for sure.
11-21-2018, 11:13 PM | #51 | ||
9105
Rep 7,563
Inside the turn signal portion of the European taillight is a combination of [COLOR="DarkRed"]red[/COLOR] LED lights, a [COLOR="DarkGreen"]green[/COLOR] optical filter and the [COLOR="DarkRed"]red[/COLOR] diffuser (exterior plastic taillight cover) which creates an amber color turn signal. On the US unit, it's [COLOR="DarkRed"]red[/COLOR] LED lights, a [COLOR="DarkRed"]red[/COLOR] optical filter, combined with the [COLOR="DarkRed"]red[/COLOR] diffuser; which emits the [COLOR="DarkRed"]red[/COLOR] color turn signal. All BMWs with LED turn signals, [COLOR="DarkOrange"]amber[/COLOR] or [COLOR="DarkRed"]red[/COLOR], uses this hybrid light combination. |
ZPrime611.50 |
12-06-2018, 10:54 AM | #52 | |
Rep 183
12-06-2018, 12:53 PM | #53 | ||
9105
Rep 7,563
Some folks on the 2 series forum tried this experiment way before the Euro LCI was announced but was unsuccessful in making it look right.. I've notice the price of the Euro taillight slightly dropping.. They go for $225 each on eBay now, so that's better options IMO.. I paid almost $600 for everything when they now came out in the end of 2017, so you might currently be able to get a better deal. |
mssVT98141.50 |
