09-05-2017, 05:13 PM | #1 |
9575
Rep 10,869
IND | Fall Line Motorsports F87 M2 Rear Upper Control Arm Bearing Kit
Standard rubber bushings found in the F87 M2 rear upper control arms are the last weak link in an otherwise rigid suspension. The original BMW bushings yield to cornering forces applied to the suspension, resulting in camber and toe change that is not ideal for performance driving. The Fall Line Motorsports kit replaces the soft upper control arm bushings with military spec spherical bearings, enabling the rear suspension arms to move smoothly through their travel and giving the rear of the car a more solid, planted feel. The reduced geometry change allows for the vehicle to retain its desired alignment, maintaining better control and predictability of the tires under heavy load. The Fall Line Motorsport F87 M2 Rear Upper Control Arm Bearing Kit is available with the bearings pre-installed into a new OEM set of control arms, or as the bearings alone. The Fall Line Motorsports F87 M2 Rear Upper Control Arm Bearing Kit may be viewed here in our online store: https://ind-distribution.com/product?sku=FLM-F87-1BRUCA Please contact IND by phone or email for more information or to place your order. 866.963.4520 | info@ind-distribution.com
12-18-2018, 11:34 AM | #3 |
Rep 538
I am very interested in these as well as for the front tension arm but these are race spec metal on metal with I assume PTFE inner liner no?
Do they or anyone you know of offer same solution (and for the front tension arm) but more of an oem style which would use a nylon cup and is sealed? Seems like a more middle of the road solution vs full on solid. |
12-18-2018, 05:29 PM | #4 | |
1764
Rep 7,650
Proctor750426.00 |
