09-28-2023, 08:20 PM | #1 |
Rep 98
Aftermarket EDC damper / coilover options?
I have an M2 Comp I retrofitted EDC in to and figured this might be the best place to post this question.
The area I live in has extremely crappy roads and the stock M2 Comp suspension is poorly suited to handling even the moderate roads. I'm wanting to replace the OEM dampers with something that in Comfort mode will handle bad roads well, and ideally in Sport+ will be a bit firmer but not by much. The road quality also leads me to want to keep the stock ride height if possible, so most of the coilover options are low on the list. So far what I've turned up from doing some research are the following: -Bilstein B4 Damptronic + Stock Springs -Evolve / Bilstein B6 Damptronic + MSS springs (or stock) -Bilstein B16 Damptronic Coilovers -KW DDC F82 set -KW DDC ECU F87 set (won't work directly with EDC, so I am not wanting to go with this one) Does anyone have experience with most or all of these and can tell me which might best suit what I'm looking for? I'm leaning towards the Evolve setup. Last edited by Aeko; 09-28-2023 at 10:52 PM.. |
09-28-2023, 08:49 PM | #2 |
Rep 2,353
I spoke to Evolve about this kit. I think for a street only car, this it the best set up. I will likely be doing this in the spring. Feel free to be the first so I can be sure though...
BSM ///M2cs, 6spd
09-29-2023, 05:16 PM | #5 |
Rep 2,189
As someone who has spent about $10,000 on suspension modifications on an M2C, I'll admit that the OEM M2 CS setup is more well-rounded. I have the Ohlins TTX dampers with the softest spring rates that the shocks will accommodate. The Ohlins are a bit more capable than the CS OEM suspension, but they also ride harsher and transmit more vibration.
BMW judged the M2 CS EDC suspension correctly for a dual-duty street/track car. If I were to modify my M2C all over again, I would use the M2 CS OEM dampers with camber correction hubs instead of the Ohlins and Vorshlag plates. Have you considered changing the front brakes to AP Racing 5000R (or similar) and swapping out the 19" wheels for 18" wheels? I believe going down 1" in wheel diameter improved the ride a lot more than changing the dampers. |
M3R12168.50 |
09-29-2023, 07:33 PM | #6 |
4693
Rep 2,542
Nitron has their elec-TRON kit that will work with edc coming out very soon and we have one of the first kits heading our way. We are going to dial them in for the F87 like with did with their R1 & R3 kits. With how good the other kits turned out I fully expect these to be phenomenal as well. Not exactly sure how much range to expect from them yet until we get our hands on them - but I do know we will one way or the other we will have something in the street range for sure.
M3R12168.50 |
09-29-2023, 07:53 PM | #7 | |
Rep 98
I haven't just because I really enjoy how the stock brakes perform. Maybe once I wear out these pads and rotors I might consider it! Are you saying you went with different brakes to go 18s? |
09-29-2023, 08:00 PM | #8 | |
Rep 2,189
The ride quality improvement from going from 19" to 18" wheels was more significant than the improvement from switching from M2C OEM dampers to Ohlins TTX coilovers. If you want to improve the ride without sacrificing performance, you could leave the suspension alone and reduce the wheel diameter. If the wheel diameter reduction is not enough, then you could modify the suspension. If you want to improve the ride and are willing to sacrifice performance, put non-performance tires on the 19" wheels. This is by far the cheapest way to improve ride comfort. |
M3R12168.50 |
09-29-2023, 08:14 PM | #9 | |
Rep 98
One of my planned changes was ditching the PSS for PS4S as I've heard from some that it does improve ride quality slightly without sacrificing performance for street use. The hardest I'm going to ever drive this car is occasional AutoX but that's an in the future thing and I don't plan on going crazy with mods. |
09-30-2023, 07:00 AM | #10 |
Rep 4,672
Some disagree with this approach, but... 18" 2nh. Not costly.
AlpinewhiteM2C121.00 M3R12168.50 |
09-30-2023, 04:30 PM | #13 |
Rep 98
09-30-2023, 06:32 PM | #14 |
Rep 4,672
10-12-2023, 11:24 PM | #15 |
Rep 98
I did a little research on these: Are you also running the spacers and lots of negative camber? I'm reading those are two things that the M2 CSR has with the CSR 513M because of the 10" width. Do you know if the F8x 513M set would also fit over the 2NH? I'd prefer that one because of the color, I don't like solid black wheels. I am assuming it would since the wheel diameter is the same.
10-13-2023, 05:43 AM | #16 | |
Rep 4,672
10-13-2023, 11:17 AM | #17 | |
Rep 98
10-13-2023, 11:45 AM | #18 | |
Rep 4,672
A positive of this setup was that I experienced zero pad knockback at my recent event.
10-13-2023, 03:41 PM | #20 | |
Rep 98
I'm really confused why BMW chose such a high offset unless it's for adjustability when running such wide tires with square wheels in the front? Even the rears on the 513M CSR run a pretty significant amount of spacer. |
