View Poll Results: Have your M2C rear indicator units failed? | |||
Yes | 136 | 63.85% | |
No | 77 | 36.15% | |
Voters: 213. You may not vote on this poll |
09-03-2020, 01:23 PM | #133 | ||||
Rep 334
Al Bundy's Dodge1640.00 MASHCT624.00 |
09-03-2020, 01:27 PM | #134 | |
756
Rep 2,149
And I've already explained to you how Ohm's law invalidates your position. This is straight from wikipedia, since you (for some reason now) do not trust the very links you provided as proof here. "Ohm's law states that the current through a conductor between two points is directly proportional to the voltage across the two points. Introducing the constant of proportionality, the resistance,[1] one arrives at the usual mathematical equation that describes this relationship:" "More specifically, Ohm's law states that the R in this relation is constant, independent of the current." "Resistors which are in series or in parallel may be grouped together into a single "equivalent resistance" in order to apply Ohm's law in analyzing the circuit." https://en.wikipedia.org/wiki/Ohm%27s_law |
09-03-2020, 01:29 PM | #135 | ||
Rep 7,298
I already asked you: Quote:
Anyway, I am going to put you on ignore now to avoid further polluting this thread. |
Commanderwiggin2050.00 nioh_lbbm21716.50 |
09-03-2020, 01:33 PM | #136 | |
756
Rep 2,149
You are making a definitions argument, based on an analogy I made. You're literally expecting me to pass beans through a resistor. It was a god damn simplified analogy to help Poochie understand. Grasp that shit, please. |
09-03-2020, 01:45 PM | #137 |
Rep 1,200
Guy has: {Click "Appreciate" on my post if I was helpful. Thanks!} as signature...yet does not post helpful information.
I guess that's why Poochie has a higher Rep per Post ratio.
575RWHP F87 M2C - ECUTEK RACEROM with flex fuel tuning by Bend Calibration 1000+RWHP E46 M3, Lab22 Built Turbo S54, Bend Calibration Tuned - BMW Half Mile Record Holder |
09-03-2020, 01:46 PM | #138 | |
Luxury at the redline :)
9105
Rep 7,563
I told you to ignore that guy, I've been down this road with him many times before, it doesn't matter if you're right, he is not going to let a silly thing like facts get into the way of his argument.. He'll continue to make assumptions and tell himself it's facts, to fit his way of thinking.. It's an endless abyss and it serves to help no one but his fragile ego.. I called this two weeks ago, yet he jumped into a new thread and is still going: https://www.bimmerpost.com/forums/sh...php?p=26564658 |
09-03-2020, 01:47 PM | #139 |
Rep 7,298
Yep. It was pretty clear that Poochie meant put a resistor in shunt to increase the current draw and fake out the bulb check. I don't particularly LIKE that solution either, but it works in theory. Then this guy comes in with his crazy statements that make no sense.
09-03-2020, 02:08 PM | #140 | |
756
Rep 2,149
So I argued that adding a resistor doesn't add a potential for fire because energy isn't destroyed when using a properly sized resistor. That adding a properly sized resistor doesn't risk fire damage because a proper resistor would be rated for the case it's being used in. I also stated that it's hypocritical of him to say adding a resistor is bad because of a potential for fire, but doesn't see disabling the bulb check as bad due to it's increased risk of fire. A risk you agreed on. |
09-03-2020, 02:09 PM | #141 |
756
Rep 2,149
So far, both of my concerns on the suggestions Poochie made have been corroborated by another party. So I think I was very much helpful.
09-03-2020, 02:13 PM | #142 |
756
Rep 2,149
Poochie, you're own statement you linked verifies that you have the same understanding of resistors as I do.
"they all have their own individual resistors to regulate the right amount of power.. " Yet you went on and on telling me otherwise. That inert resistors consumer power. You don't get to go both ways. I'm sure if I made a million different arguments and reasons in disagreement with each other, I could call back on whichever one turns out to be correct and go "SEE, I WAS RIGHT ALL ALONG" too. |
09-03-2020, 02:26 PM | #143 | ||
Rep 7,298
Wow, amazing. The check is definitely not overvoltage protection. LEDs are generally regarded as current controlled devices as you mentioned in that thread. Every LED datasheet contains a curve of the forward current vs relative intensity. The forward current is the parameter which is the closest to being linear in relation to the light output. Here is an example of one which happens to be pretty linear over this small range: So, since we need to control the amount of light coming out of the LED, how do we do that? We could just vary a voltage assuming there is a fixed resistance in series with the LED. That varies the current and that is how some more basic systems do it. The catch is that most LEDs are still not that linear in terms of light output vs current. They also can suffer from color shift when varying the forward current. Another potential issue is that you may need voltages below the diode forward voltage to get very low currents at any particular series resistance, which won't work because the diode will no longer be forward biased. To overcome those problems, most LED applications that require good intensity control use PWM. Instead of varying the current, PWM control turns the LED on at a fixed operating point, but for a variable period of time. By adjusting the frequency and duty cycle of the pulses, you end up with more linear control of the brightness, especially at the extremes. Like toggling a light switch on/off rapidly. This is how BMW controls these LEDs I am guessing based on the wires labeled PWM in the harness. |
Commanderwiggin2050.00 MASHCT624.00 |
09-03-2020, 02:31 PM | #144 | |
Rep 7,298
BTW, I don't agree with you. Usually disabling a check like this is the wrong thing to do, but after reviewing this thread and the previous thread, I think it is a safe solution here. |
09-03-2020, 02:40 PM | #145 |
756
Rep 2,149
09-03-2020, 02:41 PM | #146 | |
Rep 7,298
I said I would have to review in this case. I agree that it is normally bad practice to disable safeguards. After review of the info here and in the old M2 thread, I think disabling the bulb check is safe. |
MASHCT624.00 |
09-03-2020, 02:42 PM | #147 | |
756
Rep 2,149
09-03-2020, 02:44 PM | #148 | |
Rep 7,298
09-03-2020, 02:46 PM | #149 | |
756
Rep 2,149
09-03-2020, 03:20 PM | #151 | |
756
Rep 2,149
09-03-2020, 05:38 PM | #152 | |
Rep 7,298
Here is the reasoning: 1. There are reports of it happening at low mileage and/or right off of the lot. If this is because of the resistance of a connection increasing over time due to heating or some other factor, it probably wouldn't happen with <200 miles on the car. 2. BMW instructions are apparently to code the bulb check off when retrofitting LED tails. 3. Several posters have been using it for months so far with no reported ill effects. 4. Replacing the cluster results in the same thing happening again. 5. The warm check failure mode is to continue to drive the LEDs just with a different pattern. This does nothing to prevent any issues. If it were deemed that serious when BMW did their FMEA, the software would disable the indicator. If there is any damage, it is going to happen over time given how long and intermittently this failure presents. It is highly unlikely to be a fire hazard. If I currently owned an M2C I would investigate. If you're such an electronics wizard, ohm out the wiring harness connections and look at the LED drive signal on a scope. Last edited by chris719; 09-03-2020 at 06:01 PM.. |
Poochie9104.50 |
09-03-2020, 07:05 PM | #153 |
756
Rep 2,149
I believe this is not an issue with the LED tails. I might agree with you with the halogen bulbs on 2016-2017 M2s where we have evidence of wiring harness degradation.
LED tail lights have this issue, so saying it's not an issue with the tail lights... I don't get. Unless you're trying to say it's an issue upstream of the tail lights. I also have no idea where you're getting that there is evidence of wiring harness degradation. Please link a source to that. Because all I've ever seen was someone say their was corrosion on the bulb socket from condensation. Here is the reasoning: 1. There are reports of it happening at low mileage and/or right off of the lot. If this is because of the resistance of a connection increasing over time due to heating or some other factor, it probably wouldn't happen with <200 miles on the car. #1 and #4 are contradicting observations. You can't say "Why are people experiencing this immediately after purchase", while also saying "it happens over time after replacing the parts." You can draw an opinion based on one or the other, not both. 2. BMW instructions are apparently to code the bulb check off when retrofitting LED tails. "apparently" but I believe that is an incorrect comprehension of the documentation referenced. The document Poochie was reading was from a 2007-2009 3 series which also required a FRM module replacement when retrofitting LED bulbs sans coding. Which, we don't know the differences between these vehicles and their LED tail lights from 10 years ago. So I wouldn't base giving advise off of documents so old. But also it states nothing about disabling the cold and warm bulb check, that is an assumption Poochie made. And goes on to say if the FRM module isn't replaced, the tail lights would flicker. Which is not the symptom of the M2. I assume this is the old documentation he was reading that also said BMW pulses LEDs with extra current to check their status. Because that would cause flickering. However, that is not a symptom of our M2, so seems totally unreliable for him to take advice based off of that 10+ year old writing. He also provided another image in that post, but hasn't responded to me when I asked for a source of it so I could research further. https://f87.bimmerpost.com/forums/sh...4&postcount=76 3. Several posters have been using it for months so far with no reported ill effects. anecdotal evidence is not sound evidence 4. Replacing the cluster results in the same thing happening again. again, contradicting your previous claim. 5. The warm check failure mode is to continue to drive the LEDs just with a different pattern. This does nothing to prevent any issues. If it were deemed that serious when BMW did their FMEA, the software would disable the indicator. my statement of the rapid flashing is that it does do something to prevent issues. The rapid flashing is an indicator telling the driver to turn off the blinkers to prevent damage. If there is any damage, it is going to happen over time given how long and intermittently this failure presents. It is highly unlikely to be a fire hazard. Well, that's another thing to take into consideration. The people who have disabled their bulb checks and haven't reported issues, were they also ones who had parts previously replaced by BMW? If so, we won't see affects for a little bit. And this is why I have such a problem with the gaslighting and you guys taking my words out of context. NOT ONCE DID I SAID IT WILL CATCH YOUR CAR ON FIRE. I SAID THERE WAS A RISK TO MELTING WIRES. When people take what I say and exaggerate it to make me look like an idiot, it further muddies the conversation, because the lie about what I actually said is repeated so much that people believe it. If I currently owned an M2C I would investigate. If you're such an electronics wizard, ohm out the wiring harness connections and look at the LED drive signal on a scope not once did I say I was an electronics wizard or have the skills to figure out the root causes of this. I've shied away from looking into this myself because of that and have instead opted to work with dealerships to get a TSB created for everyone to benefit from. Unlike Poochie, who has been recommending solutions for a car configuration he doesn't even have nor can test because of his extensive lighting modifications. I've just been looking up and correcting poochie when he said questionable things, because there is a risk he is aware of and isn't disclosing when he recommends solutions on this. Everything I've stated to correct him still has been correct and you haven't proven otherwise. Last edited by Anthony1s; 09-03-2020 at 07:34 PM.. |
09-25-2020, 02:20 PM | #154 |
Rep 906
Decided to resurrect this fun thread...
Anyway, was due for an oil change so I decided to undo the coding to turn back on the rear signal warming check. Naturally both sides failed before taking her in for an oil change. Anyway, they are replacing the REM claiming the fault was found there. Will post updates
2009 328i xDrive 6MT (Retired and I miss her)
2015 335i xDrive 6MT (Retired and I dont miss her) 2018 M2 6MT (Never retiring) |
