12-12-2022, 03:41 AM | #1 |
Rep 617
WTF is causing this crazy wheel hop
I tried launching my car for the first time albeit in not the best conditions (wet roads, it rained all day today) and it the car was shaking like it was in an earthquake while trying to gain traction then went on fine. I checked codes and nothing out of the ordinary popped up. Is this really because the car was struggling for traction or is this a sign of a bigger problem?
Here's a video from my dashcam of the incident. I remember this happened with my 330i too when trying to launch in subpar conditions although not to this extent. Here's a video of that: Please relieve my fears :'( My new tires (rears) just finished break in (drove 500 miles with them) and they're Michelin Pilot Sport 4S tires Scared to even push the car now Edit: car is DCT, had DSC off, LC was at around 2700rpm, sport+ mode, transmission in S3 mode, when I tried to launch with D3, it just fell on its face then tried to do a burnout with slight hop at the end Last edited by turnsignalslol; 12-12-2022 at 04:24 AM.. |
12-12-2022, 04:50 AM | #2 | |
Rep 7,429
The fix to this is to use a dual mount diff bracket to secure it properly for example this: https://www.turnermotorsport.com/p-5...on-oe-bushing/ With this kit from turner it allows the diff to be mounted using both OEM mounting locations - which bmw should have used/done from the start but for some reason did not.
12-12-2022, 06:24 AM | #3 |
Primo Generalissimo
4672
Rep 4,023
Drives: All of them
Garage List 2017 Porsche 911 Ca ... [10.00]
2023 BMW M2 [9.00] 2023 Porsche Macan GTS [10.00] 2022 Ford F-250 Tremor [8.50] |
Have you modified the suspension?
12-12-2022, 04:26 PM | #5 | |
Rep 391
Drives: F87 M2C
Past: 2011 Acqua Minerale Blue Hyundai Genesis Coupe 3.8 Past: 2017 Alpine White 440i F32 Current: 2020 Long Beach Blue M2 Competition PC Build: 5950x/6900xt |
12-12-2022, 04:33 PM | #6 |
Rep 7,429
This should be ok, I haven't heard of any issues with this upgrade. Also the upgraded bushings should be strong enough to accommodate any increased load from being braced vs. free to rotate slightly. So get the complete kit from turner with the bolts and bushings.
12-12-2022, 05:05 PM | #7 |
Rep 617
Am I forced to just live with this if I am keeping the car stock? It still has a warranty for over a year so I don't want to mess with any serious components if I can help it.
This f-ing sucks maaaaaaaaaaaaan |
12-12-2022, 05:15 PM | #8 |
Rep 7,429
Yeah if you don't want to mod it then you'll have to just deal with it.
12-12-2022, 05:16 PM | #9 |
Rep 617
12-13-2022, 12:58 AM | #10 |
Rep 617
Tried launching the car today since it wasn’t raining, two times at 2700 rpm’s and 2 times at 3000 rpm’s, car seemed to have less earthquake noises but ambient temperature was around 44-46 degrees fahrenheit and the tires were at around 66-68 degrees. Probably going to stop pushing my luck and just not launch until it gets warmer, but even then, I’m just not having it with this shit man ahhhhhhhhhhhh
12-18-2022, 06:12 AM | #11 |
Rep 1,074
You could create a warranty claim, Show the video and does this happen everytime? If so they may just say fuck it and replace your diff under warranty. What i mean is if it happens all the time then when they test drive it and it happens to them it will be confirmed. Try going to BMW. May just replace your diff bushings and bolt and retorque
Instagram: M2_Medusa
F87source7251.50 |
12-18-2022, 11:55 AM | #12 | |
Rep 617
Probably not going to launch it today, may just have to wait for warmer weather and more miles on my tires
Current: 2024 G87 M2 (ZF8)
Past: 2022 330i RWD 2020 M2 Competition DCT Last edited by turnsignalslol; 12-18-2022 at 12:02 PM.. |
12-18-2022, 01:03 PM | #13 | |
Rep 7,429
But this is so common on the m2 that I'm not sure.
12-18-2022, 01:14 PM | #14 |
Rep 1,074
Its momentary relief, the research I've done I believe its the bushings that go out giving more play.
12-18-2022, 01:31 PM | #15 | |
Rep 1,074
12-18-2022, 02:20 PM | #16 |
Rep 617
Approaching 17k miles, I’ve had the car since 15800
Past: 2022 330i RWD 2020 M2 Competition DCT |
12-18-2022, 02:23 PM | #17 |
Rep 1,074
This is definitely pre mature wear, Never heard of it happening this fast. Take it to the dealer. Its a common issue unfortunely on this car and even if they fix it then it may happen again. I haven't experienced this issue yet. Keep us updated but you can buy a diff brace online and its helped others
12-18-2022, 06:53 PM | #18 | |
Rep 617
12-19-2022, 11:31 AM | #19 |
Rep 391
Drives: F87 M2C
Been raining quite a bit this recently. On my way to work the road was deserted so I tried it. Wasn't really trying to "launch" just get the wheels to spin for a little and then let off. Got a bit of wheel hop myself.
12-19-2022, 12:57 PM | #20 |
The Seeker
13863
Rep 3,323
1. It's super common. People will try to tell you it's not, so don't listen to them because they're clueless.
2. The problem is that it's caused by a balance of many things; the temperature of the tire, the surface, the wear on the tire, etc. 3. This is going to come and go, don't try to "fix" it, just change surfaces/temps. My car didn't do this bone stock with new stock tires, but then started to, and then it went away again. I'm a details type of guy and I can tell you that I can't figure it out, all I know is that you don't have to do anything, just give it a bit of time and it'll go away. At present my car breaks away fantastically even with stickier tires (in warm temps, not in Winter), but there are still times that, depending on the surface I'm on or the temp or how wet the surface is it'll do it a bit. My advice to you is to GET OUT OF IT when it happens. That is all. |
chris7197334.00 |
12-19-2022, 01:57 PM | #21 | |
Rep 7,429
chris7197334.00 ///MPhatic13862.50 |
12-19-2022, 06:38 PM | #22 | |
The Seeker
13863
Rep 3,323
