03-07-2021, 09:17 PM | #1 |
Enthusiast
45
Rep 40
Why do people take videos of cold start revs?
Hi guys and gals, I have been looking through different exhaust setups on forums and YouTube and have noticed something peculiar. About 1/3rd of the exhaust videos I find show people starting up their cars and in the middle of the cold start sequence, reviving them. Due to the cold start sequence, the car does not let the engine rev above 3-4k RPM and gives off no burbles, pops, or crackles. I imagine this is not great for the car. So I am convinced I am missing something. Surely the owners notice/realize that their car is not behaving normally. So my question is, what is the actual reason people rev their cars to show the exhausts while the car is in cold start mode?
PS: Please let me know if I'm posting this in the wrong Forum. |
03-07-2021, 09:26 PM | #2 |
Rep 58
On turbo cars like the m2 the cold start sounds better than normal operation. Thus if you want to show off the sound of your car it's best to do it when the engine is cold.
If you're curious why the cold start sounds better on turbo cars it's due to the turbo being bypassed when the car is first started to warm up to catalytic converters faster. |
03-07-2021, 10:43 PM | #3 | |
Enthusiast
45
Rep 40
03-08-2021, 05:47 AM | #4 | ||
Rep 162
Iamlemon44.50 |
03-08-2021, 01:52 PM | #5 |
Rep 692
Never made sense to me.
A. The car sounds worse to me cold. More rasp and more metallic. B. The normal operation of the car is when it is warm. C. 99.9 percent of the time spent driving is when the car is fully warm so why not give sounds clips of what you will hear most of the time
Vic
chris7197368.00 |
03-08-2021, 04:36 PM | #7 | |
In the Details
1812
Rep 867
Drives: Yes
Garage List 2020 AMG GTR [0.00]
2022 R8 Quattro Spyder [0.00] 2023 X5M50 [0.00] 2023 718 Spyder [0.00] 2024 Silverado [0.00] 2024 Civic Type R [0.00] |
Cold start sounds different due to raised RPMs, retarded ignition timing, retarded exhaust valve close event, and retarded end of injection timing (basically delaying combustion in relation to piston location) to allow more (still combustin) fuel into the exhaust system which heats the cats more quickly. To my knowledge there is no such thing as "bypassing the turbos." |
nelsdvn229.00 |
03-08-2021, 06:36 PM | #9 | |
Rep 569
Before the catalytic converter reaches a high enough temperature, it's ability to work and reduce NOx and CO, along with other pollutants, is severely limited. It's a very smart setup, there is no reason to waste the heat energy partially spooling the turbo at idle on cold start when there is no demand for boost at all. The unfortunate side effect is that the car sounds extra loud and tractor-like for the first 30 seconds or so of idling when the car is cold. Especially with high flow cats or catless downpipes, it can be extremely obnoxious at start up. That's why cold start is a very meaningful test of an exhaust. An otherwise great exhaust can be downright anti-social on cold start so it is an important data point for people to examine before purchasing an exhaust, especially if you live near neighbors or park in a communal garage. If you want to hear it for yourself, here's how: next time you start your car in the morning, very lightly apply the throttle while still in park. You should paradoxically see the revs rise, but the exhaust decrease in volume as the wastegate(s) close. The wastegate is only open at base idle, so if you put the car in gear and apply throttle the wastegates will close, at least until the car begins idling again. After roughly 30 seconds the cat will be adequately heated and the exhaust will stay quiet. |
Iamlemon44.50 atruong24732.00 |
03-08-2021, 07:56 PM | #10 |
In the Details
1812
Rep 867
Drives: Yes
Yes you’re both correct that I did not account for opening the waste gate, I guess I was thrown off by the terminology.
Regardless, the volume and tone change at startup is possibly 10% attributed to opening the waste gate and 90% atrributed to the changes I listed above. You can detect the same tone and volume changes in naturally aspirated and supercharged cars as well due to the reasons I listed and there are no wastegstes there. The exhaust sound flaps also play a role in the volume of the exhaust at cold start, keep in mind. |
Iamlemon44.50 |
03-08-2021, 08:56 PM | #11 | |
Rep 6,638
Iamlemon44.50 |
03-09-2021, 02:16 PM | #12 | |
Enthusiast
45
Rep 40
03-10-2021, 01:59 AM | #14 | |
Rep 43
