09-17-2018, 09:42 AM | #1 |
Rep 324
Drives: 2018 M2 Black Shadow Edition
DSC OFF
From the manual:
"DSC OFF When DSC OFF is active, driving stability is limited during acceleration and when driving in curves. Engine tuning switches to a sportier setting" I though DSC OFF put throttle into comfort mode so what is this "sportier setting"?
09-17-2018, 10:02 AM | #2 |
Rep 4,551
Drives: 2015 328d xDrive
MDM mode (short press DSC button) puts the throttle into Comfort
DSC OFF (press and hold DSC button) puts the throttle in Sport |
NYC Bimmer259.50 ratedrkstevo28.00 |
09-18-2018, 04:42 AM | #4 |
Rep 137
TBH, I drive between DSC off and sport + exclusively. if you ask me, I think the throttle mapping in DCS off is not as aggressive as sport +. I would say DCS off feels very much like comfort.
09-18-2018, 10:52 AM | #6 | |
Rep 209
Or, you can go the opposite route: Start in DSC off, and hit the mode switch to go back into comfort. The car will feel lazier. |
09-18-2018, 11:23 AM | #7 | |
Rep 6,635
If you are getting comfort throttle response with DSC off your tpms sensors might not be working. |
09-18-2018, 05:33 PM | #8 | |
Rep 209
When autocrossing, TPMS used to get upset with the combination of temps and pressures where the RE71s work best, so I reset TPMS before the start of each run. Works a treat. Other AXers tell me if you use wheels with no TPMS sensors, it's happy to let you choose any mode you want, albeit with the TPMS light staying on. |
09-25-2018, 06:10 AM | #9 | |
Rep 137
I don't drive in comfort, except by accident. but I can say for sure DSC off is less aggressive than Sport +. don't know how to check TPMS sensors. they seem ok to me. last check by a wheel alignment place showed pressures where a little high. |
09-25-2018, 07:46 AM | #11 |
enthusiasm > practicality
4021
Rep 2,247
Drives: 987 CS | G35x
I agree. It's very lax and feels like shitty comfort mode.
09-25-2018, 10:28 AM | #12 | ||
Rep 6,635
09-26-2018, 11:43 AM | #13 |
Rep 328
The reason that the BMW engineers slowed throttle response and DCT shift speed down in "DSC off" mode is to keep the average numbskull from snap spinning in a high speed sweeper when upshifting from say 2nd to 3rd or 3rd to 4th or 4th to 5th (if your car has been tuned to 450+hp) in the middle of said sweeper.
To demonstrate, put your car in Sport+ and go to the twisties and upshift under full throttle in a sweeper and you will instantly feel your car step out and then catch itself (without lifting throttle), this is the DSC saving your backside. Now, imagine that same abrupt shift speed and hyper sensitive throttle response in DSC off mode...your hands better be extremely quick and your brain even quicker to anticipate the impending rotation...this is why the engineers are smarter than the average bear Cleve |
09-26-2018, 12:16 PM | #14 |
Rep 5,369
In DSC Off, you have a more linear throttle rather than the Sport+ throttle which is rapid and has no real point past about 60-70% the pedal travel. The reduced throttle sensitivity helps the driver fine tune and adjust throttle inputs to keep from having a rapid surge of torque that can quickly overwhelm the rear tires. It's most definitely the way to go in track driving or in the hands of a solid driver hammering it on some B roads.
Have you guys actually proven that the N55 M2 has three throttle settings? I could have sworn it only has Sport and Comfort. Comfort, Sport, and Sport+ is something found on the M3, M4, and perhaps the M2C.
09-26-2018, 03:04 PM | #15 | |
Rep 183
You're absolutely right about the DSC Off setting, though. I definitely would not want to have the Sport+throttle setting with DSC off. Too hair-trigger. |
10-06-2018, 08:36 AM | #16 |
Rep 753
I find Sport throttle mapping the most natural feeling and almost feels like a linear map. Sport+ is a bit too trigger happy and it takes a while to get used to it; while, Comfort is just lazy throttle. I also like the steering “feel” in Sport and Sport+; in Comfort mode, it’s just too boosted.
DSC Off is great on track once you get used to the car. Sport map for throttle and steering and nice rotation with the slightest of slip angles on corner exit. Superb! |
ajvdh217.00 |
