BMW M2 Forum > BMW M2 Discussions > Launch Control in 6MT
      12-29-2016, 01:39 PM   #1
MR_M2
Drives: 2017 M2 6MT, 2022 X7 M50i
BMW M2  [0.00]
BMW X7 M50i  [0.00]
Is there any reason why BMW omitted launch control in 6MT? Focus RS, Civic Type R and even the Mustang GT has it.
I know it can be done in an old school way, but just curious.
      12-29-2016, 02:33 PM   #2
CommitConfirm
475
Drives: The Bus
Surely every manual has launch control. A left foot and a right foot?
Appreciate 11
SoCalRob281.00
mlust156.50
Whatup30.50
AYurch50.00
Seagull287.50
gmzanatta1823.00
filet.M2c784.00
DrKevM52269.00
ried791.50
      12-30-2016, 11:46 AM   #3
MR_M2
BMW M2  [0.00]
BMW X7 M50i  [0.00]
Has anyone tried launch control in a manual car? Does it offer any benefit over regular "left foot right foot"
      12-30-2016, 12:04 PM   #4
Joaozao
Joaozao's Avatar
189
Drives: 2017 M2
I have in a previous car. It would just hold the revs at 3k or wherever you set it. This way you can floor it and just pop the clutch and go
D CHOI581.00
      12-30-2016, 12:09 PM   #5
Em-Two
3k hmmm. I don't know what the best revs would be for a launch but my previous cars I've launched at 5-5.5k.
      12-30-2016, 12:22 PM   #6
CommitConfirm
475
Drives: The Bus
Every car is different... and there are a lot of variables from tyre grip, road surface, turbo spooling, etc. That's part of the skill of learning to drive. I believe the M2 DCT allows you to set the revs you want it to hold at.
      12-30-2016, 03:00 PM   #7
3Si
3Si's Avatar
217
Drives: 16 M2, 16 Macan S, 08 Elise SC
With DCT, there will be way too much wheel spin with a 5k dump. Around 3-4k should be the sweet spot with PSS on the strip.
D CHOI581.00
      12-30-2016, 06:18 PM   #8
M3 Adjuster
Albania
7905
learning to drive?
skill?
who does that any more!
Additional factors in determining when to shift optimally include gearing and the hp and torque curves of the motor.
      12-31-2016, 12:57 AM   #9
chris719
Drives: '08 M Roadster
BMW's launch control is rather pathetic. Ideally it would be a closed loop system that keeps you right on the edge of wheelspin so you get maximum acceleration for the given surface that you're on.
Why don't they implement it correctly? Not sure, it might put more stress on the drivetrain than they want.
Traction control is the magic of Tesla's 0-60 numbers. You can get into a Model S and slam the pedal to the floor and you get a perfect launch every time. This isn't even about the electric motor; these cars have more than enough power in first gear to spin the tires. Why there isn't a good implementation in most ICE cars I do not know.
      12-31-2016, 12:41 PM   #10
3Si
3Si's Avatar
217
Not quite sure what you mean. I've had launch control in Audis and Porsche, and they are all quite similar. Rev to a certain RPM, and dump the clutch. BMW allows you to adjust the RPM which would help in certain conditions. Most launch control requires you to disengage traction control anyways. As for the Tesla, the one that gave me a perfect launch was the Model X AWD in ludicrous mode. But that's AWD, we can't compete with AWD. When I tried the S in RWD, the launch was still very nice, but you can feel power being cut significantly to avoid wheel spin. They are also much heavier cars with a lot of batteries at the bottom which helps with launch when you have that much torque from the start.
      12-31-2016, 01:43 PM   #11
ajvdh
Drives: 2016 M2
I'd hardly describe it as "pathetic", IME, it's consistent and quick, even with variations in grip. There certainly is a feedback loop: On lower friction surfaces, the clutch never fully engages in first gear, and you can hear and feel it balancing the tires on the hairy edge of adhesion all the way through at least 2nd.
Electric cars have a huge advantage when used in a feedback loop. If you modulate the electricity going in, the output torque from the motor tracks it immediately. In an ICE, there's always going to be a delay between a change in throttle position and a change in output power. Turbo engines are even trickier, as throttle response isn't always linear.
      12-31-2016, 04:41 PM   #12
PackPride85
I have a feeling the 6mt in the M2/M3/M4 is not the most "robust." No launch control and forces you to rev match on downshifts unless traction control is completely off.
      12-31-2016, 05:27 PM   #13
mrcheezle19
Drives: 21 M2C 6MT
Guys are putting over 600whp through this trans.. So umm its robust.
      12-31-2016, 05:28 PM   #14
PackPride85
Maybe the stock clutch? I can't imagine 600whp without an upgrade clutch.
