12-28-2016, 08:43 PM | #1 |
Rep 72
Damaged During Transport to Dealer
Whelp my Mineral Grey M2 arrived at the dealer but apparently it was damaged along the way. They say there's damage on the passenger side along the roof and the metal trim section above the door that's not part of the main roof. I wasn't too shocked because this stuff happens and the universe generally doesn't want me to have nice things. They explained repairs will be done to my satisfaction, etc, etc, and I'm mostly wondering what I should be looking for before accepting the car. Any tips and suggestions to find flaws in the workmanship and paint would be appreciated. I didn't ask for any pics or detailed info up front but I'll request it when I get the car.
12-28-2016, 08:50 PM | #2 | |
Rep 445
M3 Adjuster7905.50 |
12-28-2016, 08:52 PM | #3 |
Rep 1,345
Most damage happens on the car when it gets to PDC, where they quite often repair cars. If they need to paint the car, frankly, I wouldn't take it. They'll need to spray and blend paint and it will meter that it's been resprayed, which could effect your resale value. Oh, I would only accept this if I saw the damage BEFORE they worked on it.
Totally sucks. I'd see if you could take their next allocation. Not the end of the world, just a bit longer wait. Get it the way you expect it. |
12-28-2016, 09:04 PM | #4 |
Rep 72
Getting another allocation will probably take over a year so that's out. Also I need a another car now since my old DD is dismantled and I hate using my truck as a DD.
12-28-2016, 09:12 PM | #5 |
Rep 1,345
Don't be so sure. The dealer owes you. You can get the next allocation from their list most likely. If they dented a fender, it would be a lot easier. Replace the fender and paint it. The roof area is very difficult. Hope you can work something out.
12-29-2016, 06:19 AM | #6 | |
Rep 3,402
12-29-2016, 08:09 AM | #7 | |
7906
Rep 11,785
This is really poor advice in my opinion. While it may be the best choice for you , it's not the best choice for most people on a vehicle that clearly has production limitations. This isn't like just going over to find another car on the lot or waiting a week or so. If OP passes and has to wait 3-6 months or a year for another car .. heck the minute he gets that second one, someone would probably back into it in a parking lot the third day he owns it. OP Did say the universe doesn't want me to have nice things ... In addition, i would much rather have a body panel REPAIRED than REPLACED, especially if the panel has any factory welds. Would you rather have BMW ROBOT welds or ones done from the guy at the local body shop? Not saying welding can't be done well but why destroy more of the original craftsmanship in attempting to make a repair? Why have a shop remove a panel (that doesn't need to be removed to be repaired) and have to paint MORE of the vehicle by having to blend onto more adjacent panels ? Your comment about a paint gauge and paint thickness makes no sense with your remove and replace approach. . If the shop replaces a front fender with a new one then they will have to blend onto the hood and also onto the door to make it match. That's making the paint thicker on TWO panels, (assuming the fender just gets the proper original thickness of paint- If not then you have three panels ) , as opposed to just a repair to the fender with a slight amount of blending within the single panel and only one panel has thicker paint. Work on a roof panel is a lot easier than say, a quarter panel... and certainly isn't like it's impossible. Finally... what do you think the lost value is on a 1M that had to have minor paintwork ?? Probably close to zero because the cars are hard to find. The M2 production has been at the same rate as the 1M with an additional year of production so far. Ever see a classic car show or auction ? Which car will fetch more value .. a car with all original paint and a few blemishes or touch ups or the car that's had a full respray? The approach should be to do the minimal and best quality repair or touch up possible, while leaving the original vehicle intact as much as possible. Repaired or not, Any M2 will be a *very * Desirable car for quite some time. Well until LCI. ( joking !! ) @skwinglos. Let the dealer do what they need to do. Inspect the car closely as @Txsurfer suggested. Perhaps they will compensate you additionally with some swag, or a slight discount. Then take your brand new , 14 mile , M2 home and ENJOY it . Well , at least until the roundel falls off and the diff starts crunching |
Destroya371.00 |
12-29-2016, 09:16 AM | #8 | |
Rep 1,345
The above is a perfect example. Others may not find it a big deal, but I'm not looking for over spray on a new car. All said, ANY new bmw could have had very minor repair at the PDC. However, that repair would be far superior to the repair done by a dealer. Granted, the m2 is hard to get. Agree that this repair may not effect the value. If you lease the car, I wouldn't worry about it for a minute. If you own and plan to sell within 2 years, probably wouldn't be a big deal either. Not to create any ire here, OP just wanted views on what to do. |
12-29-2016, 09:24 AM | #9 |
Rep 1,345
How could it be easier to work on a roof panel than a quarter panel? For the quarter panel you need to remove part of the interior panel in the trunk. For the roof, you'll need to pull out the headliner, wouldn't you? If repaired,I'd check to see that the headliner is perfect afterwards.
12-29-2016, 09:31 AM | #10 | |
Rep 445
Destroya371.00 |
12-29-2016, 10:02 AM | #11 | |
Rep 1,345
12-29-2016, 10:15 AM | #12 | ||
Rep 445
12-29-2016, 02:16 PM | #13 | |
7906
Rep 11,785
http://www.***********.com/showthrea...f-Install-Pics If you have followed any threads regarding an aftermarket CF roof install, you may have seen that entire replacement of the roof skin can be done quite competently. http://ind-distribution.com/ind/bran...ber-roof-panel To repair the quarter panel one must remove the interior door pillar trim and also the interior rear seat trim. The quarter panel consists of both an inner panel and an outer panel. There is usually *not full access to all of the outer panel from the inside. Access also may be blocked from an inner wheelhouse panel. http://www.bing.com/images/search?q=...co0&ajaxhist=0 There's a lot of space inside those beautiful haunches .. and multiple panels of metal as well. Last edited by M3 Adjuster; 12-29-2016 at 02:24 PM.. |
12-30-2016, 01:14 AM | #14 | |
Rep 72
Also, about that mileage. I'll definitely pass on the car if it has anything above 20 miles. At that point I'll have a repaired and joy-ridden car and I'll be super, duper, upset about that. |
gds52886.00 |
12-30-2016, 02:33 AM | #15 |
Rep 886
Before any decisions are made I'd go and look and/or get pictures of the extent of the damage.
It may well be superficial stuff in which case a repair to your satisfaction may suffice or it could be worse,for example,if the roof is creased I personally wouldn't bother with a repair regardless how rare they are over your way. |
12-30-2016, 05:01 AM | #16 |
Rep 2,856
Ask them to fit a carbon roof
Just kidding, just pay attention to anything. Take your time to look at it all, and watch out for a dealer person pointing you at things and letting you focus on things that are not of importance or do not show the complete deal! MR |
12-30-2016, 03:17 PM | #17 |
Rep 156
Drives: 1995 M3 coupe; 2017 M2
We picked up a new 3-series wagon in Munich some years ago. My wife's car, to tote our not yet two year old daughter and her playmates. I badly rashed both of the passenger side wheels before we got five miles from the visitor center. I was beside myself. The spouse calmly said 'it's properly broken in now, and I'm sure glad it was you and not me.'
Things happen. |
Destroya371.00 |
12-30-2016, 07:45 PM | #18 | ||
Rep 445
