12-21-2016, 08:29 PM | #1 |
Rep 103
Problem with m2 1st gear
When starting from rest, even after good engine warm up, the first gear always feel very laggy and jerky if you know what I mean. Once it gets into second/third gear the car behave much better. Anyone experiencing this? Or there is some issues with my transmission?
12-21-2016, 08:53 PM | #2 |
Rep 46
I think I know what you're talking about. I didn't think of it as a "problem", just a quirk. What I do to work around it is not lift at first. I clutch in and then lift the gas. Second gear and up are fine, I don't have to do that, just first gear.
KGun192.00 |
12-21-2016, 08:54 PM | #3 |
Rep 817
Are you simply letting the clutch out too quickly, perhaps?
williewonkerz60.00 |
12-22-2016, 03:07 PM | #7 |
Rep 616
Drives: M2, X2 M35i, X6,328i,230i
Garage List 2017 BMW 230i [0.00]
2022 BMW X2 M35i [0.00] 2015 BMW 328i [0.00] 2008 Jeep Commander ... [0.00] 2017 BMW M2 [0.00] 1997 BMW Z3 1.9 Roa ... [0.00] 2014 BMW X6 xDrive35i [0.00] |
I find 1st gear a little jerky too but this is my first MT in over 10 years so I've just assumed it's driver error. The only way I get a smooth start is to let off the brake and slowly release the clutch without giving it any gas until it starts moving forward on its own and then slowly applying gas. If I try to be quick with engaging the clutch it will jerk.
Whatup30.50 |
12-22-2016, 03:52 PM | #8 | |
Rep 31
12-22-2016, 09:33 PM | #10 | |
7906
Rep 11,785
gearbox 6-speed manual transmission Manual gear ratios I / II / III / IV / V / VI Manual gear ratios 4.11 / 2.32 / 1.54/ 1.18 / 1.00 / 0.85 gearbox- 7 speed M Double Clutch Automatic gear ratios I / II / III / IV / V / VI / VII Automatic gear ratios 4.81 / 2.59 / 1.70 1.28 / 1.00 / 0.84 / 0.67 That first gear in the DCT is a doozy... The shorter the gear ratio (numerically higher) the quicker you will run out of rpm. Winding the transmission out very far with a short gear and not shifting up smoothly/easing back out of the the throttle and slowing will result in a rubber band effect on the chassis via engine braking. I'm very curious as to the Gearing decisions made for this 7 speed DCT box compared to the six speed manual. It doesn't seem to make sense to have an extra cog and have an unusually short first gear .. and at the same time also have an usually tall seventh gear (mega overdrive ) ... while really not taking advantage of spacing the ratios in the middle better ? |
Whatup30.50 |
12-22-2016, 10:03 PM | #11 |
Rep 3,402
In crawling type situations when the car is cold the DCT is trying to find the bite point for the clutch. It is possible this is what your experiencing. You will likely find this to be less of an issue once the car is broken in. I have been pleasantly surprised at how smooth my DCT has been at slow speeds.
12-23-2016, 12:32 AM | #12 | |
Rep 103
12-23-2016, 03:54 AM | #13 | |
Rep 396
12-23-2016, 04:04 AM | #14 |
Rep 2,577
Use your right hand a little bit please, manually shift into 2nd when you know when.
It's going to be as smooth as any auto out there can get.
Lemania 2320
12-23-2016, 09:31 AM | #15 |
Rep 616
12-23-2016, 11:44 AM | #16 |
Rep 41
Short first gear makes sence to spool up booster as quick as possible and to avoid the feeling of lag. Short gearing with DCT in lower gears is the reason why DCT feels faster than manual.
M3 Adjuster7905.50 |
12-23-2016, 01:35 PM | #17 |
Rep 132
I have the BSM w/DCT. I feel like is has to do with the fact that the transmission doesn't "feel" like it is engaged so when you are simply shifting into gear from park or reverse you don't have the "immediate engagement" of the transmission when you hit the gas to pull away. I always feel like the car is still in neutral of an extra second....
12-24-2016, 10:24 PM | #19 | |
Rep 450
'74 2002tii, Sienna Braun Metallic, Manual, Sold; '84 e28 533i, Burgundrot Metallic, Manual, Sold; '95 e36 M3, Avus Blau Metallic, Manual, Sold; '06 e60 M5, Silver Grau Metallic, SMG, Sold; '09 e82 135i MSport, LeMans Blue, Manual, Sold
BMWM5NYC496.00 |
12-26-2016, 10:49 AM | #20 |
Rep 15
It's normal.. I have a same M2 DCT here in Vietnam and still in break-in. Traffic here is terrible, most of the time I drive in 1st 2nd.
I suggest you push the throttle little bit hard to get 1800 to 2000rpm then gently let off the pedal and shift to 2nd. Or you can shift to 2nd from stand still. Don't shift to 2nd when moving and rpm under about 1500. |
12-27-2016, 11:25 AM | #22 |
Rep 3,402
Sure does, by stepping on the throttle it tells the transmission to engage fully so that resolves the bite point issue. The manual even speaks of crawling as something to avoid because DCT's clutch systems struggle a bit in those conditions. For that reason its best to allow some space between you and the car in front of you so you can get a full engagement of the system. Of course this is not easy in some traffic conditions because some will use any inch of space to try and squeeze in. I believe the manual speaks to the issue of crawling.
