09-16-2015, 03:48 PM | #23 |
is probably out riding.
6058
Rep 2,294
To the thread topic, i like using the 70-200 for auto pictures.
I don't care for wide angle lenses for car shooting, you tend to get some portion of the car OOF because of shallow DOF. And there is typically some type of distorted proportions of the car. Some go for that look and i get the artistic value of it, but i don't prefer it.
"There is no greater tyranny than that which is perpetrated under the shield of the law and in the name of justice. -Charles de Secondat"
09-19-2015, 12:19 AM | #24 | |
Sergeant
790
Rep 2,490
'22 F92 M8 Competition Coupe - Frozen Brilliant White | 8 Speed DCT | Sakhir Orange/Black Full Leather | M Perf CF Exterior Package | M Perf. CF Exhaust | BBS FI-R 21" Wheels | |
09-19-2015, 10:09 PM | #25 | |
6058
Rep 2,294
Lenses are complex and most of the time, if a lens is deemed "cheap" by monetary terms, it's likely cheap in terms of quality as well. There are some exceptions, but for the most part that holds true. In terms of lenses and bodies; a top end camera body with a mediocre lens will produce mediocre images. Where as a top end lens with a mediocre camera body will create high quality images. So my advice to everyone getting into photography is to shoot with the kit lens until you can afford or bring yourself to allocate the funds to purchase a high quality lens. High quality glass holds it's value very well. If you bought a top quality lens today, you'd likely be able to sell it for 80% or more of it's original purchase price even in 5 years or so.
09-21-2015, 01:21 PM | #26 |
Rep 472
Mr. Tonka is correct. I started out with a kit lens but the image quality wasn't meeting my expectations.
I even upgraded my camera body before I realized the problem is always with the glass (lens). The pro lenses provide not just a sharper image but I noticed better color, contrast and overall a better and less distorted image. Also something you have to realize is that most of the magic you see in digital photography is in the editing. You need to become proficient in a good raw editor. Adobe Lightroom is my favorite. Pro lenses are expensive and most of the time heavier than a consumer grade lens but that has to do with the large Apertures and build quality. Most pro lenses have metal cases vs plastic and also have weather sealing to help keep dust and moisture out. Pros shoot in all weather and extreme climates. The gear has to be able to withstand those environments and abuse. |
09-21-2015, 02:20 PM | #27 | |
Rep 7,389
Dave
09-22-2015, 02:11 PM | #28 | |
Rep 1,052
For so-called "Full Frame" or "FX" cameras the size of the digital sensor in the body of the camera is the same exact size as a single frame of 35mm film (hence "Full Frame"). For any lens you put on that body - lets use a standard 50mm prime lens as an example - the focal length (50mm) is exactly what it says on the lens (i.e., 50mm). Examples of "FX" cameras are the Nikon D610, D750, D810, Df and D4s and the Canon 6D, 5D and 1D. The size of the sensor in your D3200, a "DX" body, is smaller than its FX counterparts by a crop factor of 1.5x (or 1.6x for Cannon crop sensor bodies). Cameras like the Nikon D3x00, D5x00 and D7x00 are all "DX" as are the Canon T3i, T4i, T5i (called EOS 550/650D in Europe), 60D and 7D. By now you might be asking how this has anything to do with your original question...let's go back to our 50mm lens example: While the field of view you see through the viewfinder with our 50mm lens attached to an FX body is, wait for it, 50mm, that same exact lens attached to your D3200 will give you a field of view equivalent to 75mm. You still might be wondering how this applies to your original question and its really in some of the first answers you received. The 24-70mm lens recommendation, while not in and of itself a bad recommendation, will yield a field of view on your camera of 36-105mm. Most would argue that probably isnt the most useful range. In fact, the same crop factor applies to the 18-55mm lens that came with your camera and if you apply it to that lens you get 27-82.5mm; it is no accident that the "standard zoom" range the 24-70mm lens is intended to cover is roughly equivalent to the focal length range of the kit lens your camera came with. Now back to your original question. As far as better quality there are a number of options depending on if you want a wide angle or the telephoto end. You are correct that the 18-55 kit lens is not top of the line quality and as others have suggested if you plan to move to an FX body in the future you may want to get a lens now that will work on FX in the future (all Nikon FX lenses will work fine on a DX body, but not the other way around). Wide Angle. Personally, I like the ultra wide angle lenses (10-20ish mm for DX or 14-24ish on FX); I took the photo below (which kind of makes me cringe now) with a 10-24 Tamron wide angle lens on a D3100 (or possibly D90). As one of the posters above mentioned Nikon makes a similar lens as does Sigma. There arent a ton of options in the ultra wide angle range for DX but the Tamron and Sigma can be had for under $500 while the Nikon is closer to $800. Not sure the nikon is worth the difference in this focal length range. I should note that none of these lenses will work on an FX body should you go that route someday. One poster mentioned something about things being out of focus with ultra wide angles. Actually the opposite is true, typically at very wide angles more is in focus because you are usually focusing on a subject closer to the camera and therefore are hitting the hyperfocal distance where nearly everything is in focus. What he may have meant was at the edges on ultra wide angle lens you do tend to get a fair bit of distortion. Its a wide open aperture that creates the sharp transition from in-focus to out-of-focus areas (i.e shallow depth of field). Standard. You should definitely get a 35mm or 50mm prime ASAP! They are cheap and will help you learn a ton about the relationship between ISO/Aperture/Shutter speed. The Nikon 50mm f/1.8D (~$100) is perfectly fine and you have three other options going up in roughly $100 dollar increments (the 50mm f/1.8G, 50mm f/1.4D and 50mm f/1.4G). If you really want the cream of the crop the Sigma Art 50mm f/1.4 is closer to $1,000 but is well worth it. If you only want to get one lens and image quality is the number one priority, there are three lenses that will be extremely flexible covering from fairly wide angle through the normal zoom range and have top notch image quality: 1. The new Nikon 16-80mm f/2.8-4 which isnt cheap at around $1,100 (there is also an old version you might be able to find used, but i hear the new one is much better). 2. The Sigma Art 18-35 f/1.8, also not cheap at around $800 but fantastic for low light. Not too much at the long end of the zoom range and it might be a bit big/heavy on a D3200 body. 3. Nikon 17-55 f/2.8. Even more expensive at around $1,400 (you can find them for half that used), this is the Nikon "professional" grade DX zoom lens. Telephoto. As others have said, stay away from the 55-200 and 55-300 if you care about image quality. I dont shoot too much in the telephoto end so i didnt have much need for a long zoom, but i did just pick up the newer version of the 70-300 for $300(!) refurbished from Nikon which is a ton of bang for the buck and that lens is even better on DX. The old 70-200 f/2.8 VR I can be had used for just over $1,000 and is an amazing lens on DX, but you really have to hold that lens in your hand to appreciate how big and heavy it is - especially on a smaller body like the D3200. Anyway that was long, feel free to PM me if you have any specific questions.
Current: 2021 340xi
Retired: 2018 330xi | 2016 340i 6MT | 2013 335i 6MT | 2011 328i 6MT (N52) | 2008 335xi (N54) |
09-22-2015, 02:12 PM | #29 | |
Rep 1,052
Current: 2021 340xi
09-22-2015, 02:28 PM | #30 |
Rep 7,389
FX and DX are Nikon lingo for full-frame and crop-sensor (APS-C ?). Only Nikonistas use those terms. The rest of the world says, "full-frame" or "crop-sensor".
There's some confusion around crop-sensor, in that there's more that one size, so writers will often specify which they are referring to. BTW, I shoot Canon, but fully support Nikon, Sony and other system users. There's no single "best" and the spec wars change constantly. Pick one and stick with it. Dave
09-22-2015, 02:37 PM | #31 | |
Rep 7,389
I don't know why he's saying it's better on DX than FX (crop-sensor than full-frame) since they're known for great IQ and versatiliy. Here's a typical full-frame, 70-200mm shot at 111mm: Lauching by David Stephens, on Flickr It's also a great portrait lens and great for some wildlife.
09-22-2015, 03:21 PM | #32 | |
6058
Rep 2,294
DOF is just a math equation and if you mount a 24mm lens on the OP's camera choose F4 and stand at 5' (likely distance for that focal length) the DOF is going to be shallow at just over 2' leaving much of the car OOF. Same camera, same F4, with a 100mm lens at 50' equals a deeper DOF of just over 12' likely getting the entire car in focus. Even if you double your distance from the subject with the 24mm lens, the DOF is still about 20% shallower than that of the 100mm lens. Distance from the subject is a HUGE factor when calculating DOF. Stand just 40% closer to the subject with the 100mm lens and your DOF will decrease by 60%! Stand 40% closer with the 24 and the DOF drops from 2.1' to 9". Decrease the F value to accommodate lower light and the DOF shrinks again. The difference between the two focal lengths is even when you decrease your distance from the subject by 40% the DOF at 100mm is still about 6x larger than at 24mm. Add a tripod to the 100mm lens, bump to F11 and you're back to a 13' DOF. While the 24mm lens being bumped to F11 will only garner about 3' DOF. So in some instances your bolded statement is true, but when you factor in distance from the subject, a crucial factor, all the numbers change drastically. http://www.dofmaster.com/dofjs.html
09-22-2015, 03:40 PM | #33 | |
Rep 1,052
I guess the exception to this rule with an ultra wide angle might be if you wanted to take a detail shot of say a side view mirror where part of the fender is in the foreground. In that case the near fender will be out of focus but everything beyond the mirror should be in focus.
Current: 2021 340xi
09-22-2015, 03:53 PM | #34 | |
6058
Rep 2,294
09-22-2015, 03:58 PM | #35 | |
Rep 7,389
Even with ultra-wides, f-stop matters. With my 15mm, I can focus from about 12" to infinity at f/16, but at f/2.8, I need to watch both foreground and background for focus and can exercise selective focus by moving fore and back from the subject. I think the confusing language comes from the fact that larger f-numbers are actually smaller apertures in physical area. Another point of confusion is that some people say things like, "great DOF" when they talk about bokeh. Bokeh refers to the character of the OOF areas of a shot. When I talk about deep DOF, I'm talking about sharp focus from foreground to background. In the 21st Century, DOF has become a slang term for bokeh, in some quarters, causing even more confusion. Dave
09-22-2015, 05:22 PM | #36 | |
Rep 1,052
Otherwise agree with everything you said including the third party options. |
09-22-2015, 07:57 PM | #38 |
Rep 1,850
This topic has a lot of really bad advice. Take a photography class, or you'll make a lot of mistakes you won't even know about. You need to learn how to compose and take good pictures or your DSLR will just be making a lot of expensive snapshots. You have to know how to visualize the scene to make all the lines just right, which takes a lot of practice. Extremely minor adjustments to camera position make a huge difference for your composition. Don't fool yourself that you already know about this stuff, because if you did, you wouldn't have made this thread.
As far as what lens(es) you need, it depends on how far away from the car you want to be shooting and how much you want to capture. Keep in mind, though, a pro can crush an amateur with a DSLR using just his iphone, all day long. |
