09-09-2023, 12:55 PM | #1 |
Rep 103
OG M2 tuning questions
Hi everyone!
Looking to get some information and advice on tuning. I have a 2017 M2 OG completely stock, with an exception of the VRSF chargepipe. Recently upgraded due to burst stock chargepipe. Would like to add a little more power for occasional track use, mostly used as daily. I was thinking to get to BM3 stage 2, and would have to upgrade at least intercooler & downpipe. I’ve had Fabspeed catted downpipe on my list. The only concern I have are those crazy loud “gun shots” , and loud “pops”. Is there a way to get rid off gun shots via BM3? Or maybe someone can recommend different downpipe? Also, in regards to upgrade into cold air intake, I found mixed reviews regarding this upgrade. Had Dinan or Tuner Motorsport. Most say it doesn’t add any noticeable power, except noise. Any suggestions would be appreciated. |
09-09-2023, 01:42 PM | #2 |
Rep 217
Regarding tuning, BM3 is the cheapest and most flexible option. BM3 should let you tone down/remove the burble effect if you load a tune (I think you can also do it with Bimmer code?).
The Fabspeed sport cat is good, and the equivalent is the Remus sport cat (get whichever is cheaper). They should both yield some good power increases regardless of if you tune or not as they both use 200 cell HJS cats. An Intercooler is a good upgrade regardless of tune since the OG M2 will pull power once IATs start to climb. Which Intercooler is kind of dependent on how you plan to use the car going forward, but most people have had success with the Wagner Evo 2 or the CSF. Finally, for intakes, they are more so for sound and convenience. Some intakes may yield a slight increase in horsepower high in the rev range as well as boosting some low down torque, but it’s not too significant (<=10 hp and ft/lbs). I found the bigger value was that some of them allow you wash the filter which cuts down the filter replacement cost (they also make a regular washable filter for the stock air box but I had rough idles with it…so ymmv). |
NJ M3cs29.00 |
09-09-2023, 03:01 PM | #3 |
Rep 587
Skip the intake. It’s not worth the MAF bs and doesn’t provide any performance. Overoctane your OTS BM3 tune as they run hot. Run 93 on the 91 tune, or run the ACN tune with 91.
Plan on data-logging to confirm everything is healthy, don’t just slap a OTS S2 93octane tune on and and go to the track. CSF intercooler is good. I’m perfectly satisfied with mine and it’ll hold IATs within 10* of ambient on the street and works well enough on track. VRSF Race or Wagner Evo3 will out perform it. Skip the Wagner Evo2 it’s overpriced for the performance. Active Autowerke Catted DP as another alternative to Fabspeed that won’t provide a CEL. BM3 allows you to fully adjust burble aggressiveness and where in the RPM range they’re produced. From full off, to complete childish dickhead/idiot. |
NJ M3cs29.00 CalAcacian553.00 |
09-09-2023, 04:57 PM | #4 |
Rep 7,479
I had MHD before and recently moved over to bm3, and I absolutely recommend getting bm3, here's my review: https://f87.bimmerpost.com/forums/sh....php?t=2031816
You can run stage 2 or stage 2+ depending depending on your mods. For downpipe if you want catless get the mad catless downpipe. For intake stock is fine, if you want some more noise I'd recommend: the turner intake (I'm getting one soon and I'll review it), cts turbo intake, and the new infinity design intake (this is crazy expensive but it's top knotch). At this point I'm leaning to the Turner motorsport intake, because that's what I'm getting but I'll have a more conclusive explanation in my final review. Btw none of the intakes I listed above should have cel or maf sensor issues. This is because they have specifically designed maf housings to prevent a CEL.
09-09-2023, 06:23 PM | #5 |
Rep 103
Thanks for all the replies! It is good to know that I can control burbles/aggressiveness of the exhaust with BM3. But it’s not really burbles I was referring to, it’s those crazy pops and what sounds like a gun shots. Is there a way to completely eliminate, and still have stock like burbles with upgraded downpipe? Absolutely love how current stock exhaust/downpipe sounds, though wouldn't mind a little extra aggressiveness.
Didn’t know that I can control burbles via BimmerCode, definitely have to look into that. Anyone have CSF intercooler? Any fitment issues? |
09-09-2023, 06:33 PM | #6 | |
Rep 63
2018 M2 - LBB 6mt
NJ M3cs29.00 |
09-09-2023, 07:29 PM | #7 | |
Rep 7,479
Don't mess with burbles on bimmer code, that is not the correct way to do it and you can end up messing with the car in unexpected ways. For example if you disable ASD via bimmer link's active disabling function then you also disable the exhaust flap. If you mess with active sound tuning on bimmer link then you disable burbles. So imo don't mess with any tune related settings on a coding app.
09-09-2023, 08:13 PM | #8 | |
Rep 103
Thanks for letting me know, definitely don’t want to mess with that. |
F87source7316.50 |
09-09-2023, 08:41 PM | #9 |
Rep 1,389
I'd say the gunshots and burbles are not the same. I think he means the 'AK47' antisocial/small penis tunes that make the car sound like firecrackers are going off. That has to be tuned in and you won't be at risk of that with normal settings on BM3 or MHD.
09-09-2023, 08:50 PM | #10 |
Rep 103
Lol. Yes. Exactly what I meant. Thanks
09-10-2023, 01:06 PM | #11 |
Rep 4,185
Intakes will not add any real power without an inlet, something like a CTS will not cause a CEL/MAF issue.
I'd recommend a Race intercooler - VRSF or MAD, but you will need to have a M235i Vbrace installed at the same time. Mine is consistently under 11F during a pull and even as low as 5F. - Side note, use thermal tape to wrap your chargepipe BM3 is going to be the best OTS tune you can get, so don't bother looking elsewhere unless you want a custom tune. Finally, for downpipes only Fabspeed and ActiveAuto offer a no CEL guarantee, so I would stick with them.
Mods: Yes.
NJ M3cs29.00 |
09-11-2023, 05:34 PM | #12 |
Rep 569
Echoing what others have said on here. BM3 is fantastic, safe, and allows full control over pops/burbles (I have them completely turned off and the car still sounds plenty aggressive without being childish). I personally went the CSF intercooler, Fabspeed sport cat, and full Dinan exhaust route. I added the Dinan intake for the noise/ full carbon aesthetics and I enjoy it, but it doesn't make any additional power.
NJ M3cs29.00 |
09-11-2023, 07:01 PM | #13 |
Rep 316
FYI..IF you're tuning the car to not throw codes for the downpipe. it wont show a CEL for it. Mine has the CTS 200 cell and MHD tune...passed inspections here. No CEL no issue. Theres a check box in MHD and BM3 for aftermarket cat...Dont need to pay $1000 for a sport cat. Get the Cheaper ones.
09-12-2023, 07:13 AM | #15 |
The Seeker
14075
Rep 3,376
I was in the same sort of spot, I didn't really want to add much hp, I just wanted to "uncover" what BMW did to stifle the engine in order to preserve M3/M4 sales.
My mod list is (all the most popular stuff): - Fabspeed sport cat (lower tone, no drone, more exhaust artifacts, no CEL) - Mad charge pipe (cheap and effective) - CSF intercooler (top rated) - BM3 (OTS stage 2 91 octane) - MST inlet (PITA) - Turbosmart DV (PITA II) The car feels vastly faster than it was (maybe 430 at the crank now), though it's not any more fun, if I'm honest, and there is absolutely more turbo lag (regardless of what the fanboi's say). I think I'm pretty light on expense for the mods, just $2660 all in (including installation of the inlet and DV), but if I had it to do over I'd skip all of it except for the downpipe. But I'm weird, I don't race my car, it's all about driving fun and aesthetics. |
NJ M3cs29.00 |
09-12-2023, 08:12 AM | #16 | |
Rep 103
I’ve had a 2020 M4 cs, and I gotta tell you, M2 way more fun to drive, even stock exhaust sounds much better than on M4 cs. Charge pipe was a must for me, as my stock pipe burst while I was switching from 1st to 2nd gear, at around 2k rpm. I was always wondering and couldn’t understand how people could blow they charge pipes on their stock cars. And here we go, out of nowhere, not even pushing hard. I would expect it to burst while really pushing on it, I guess it’s the friction, the age of the original stock charge pipe and mileage. I was at 65K with original chargepipe. So, what are you saying that you would only upgrade down pipe without tuning it? That turbo lag you are talking about, it got worse with all of those mods? |
Sungillest101.50 |
09-12-2023, 11:38 AM | #17 |
Rep 587
09-12-2023, 11:58 AM | #18 | |
Rep 217
Regarding lag, the only item in there that I can foresee adding any "noticeable" lag is the CSF intercooler (which is common for larger intercoolers). Everything else in there should actually improve throttle response and reduce turbo lag because it improves flow/efficiency. I do agree though that this will be more or less noticeable dependent on how you drive your car. |
09-12-2023, 12:04 PM | #19 | |||
The Seeker
14075
Rep 3,376
I think a lot of guys just aren't as perceptive as I am, and that's not a slag, it's just the fact. I think if they'd go drive a stock car back to back with their modified car, and forget what happens after 3500K rpm's, they'd notice as well. |
NJ M3cs29.00 |
09-12-2023, 12:38 PM | #20 | |
Rep 217
Stage 1
Stage 2
Stage 3
09-12-2023, 02:14 PM | #22 |
Rep 97
