11-06-2018, 06:30 PM | #1 |
Rep 24
GFB DV+ Install: Options & Opinions
Fellow OG M2'ers,
I've come across the following information pertaining to the installation of the GFB DV+ and wondering who has experimented with the "Main Spring" install. Installing the "Main" spring, I feel should allow the diverter valve to react more fluidly bleeding off positive pressure just enough to equalize rather than the valve over stroking and dumping all boost between gears. I don't think light switch on/off is a good thing over "just enough" modulation. My main concern is: How will the BM3 OTS tune(s) react with the DV installed with the modulation spring!? FYI -My 18' MG LCI is currently FBO on BM3 Stage 2 93 Tune now. Going to Dinan BIG turbo, DV+ and Pure inlet in 2-3 weeks. Cut & Paste Instructions from GFB: The DV+ can be configured in two different ways, depending on your desired outcome. Fitting the DV+ with the main spring installed as shown on the previous page can be thought of as a “Sport” mode, offering the best possible throttle response and boost recovery during on/off throttle applications (i.e. during gearshift with a manual transmission). Using the main spring means the DV+ can open and close progressively in response to how much boost pressure is present, unlike the factory diverter which just opens fully regardless of whether there is boost to vent or not. Because this operation method is different from the factory diverter, it is not unusual or detrimental to hear a different sound from the intake when lifting off the throttle at low RPM, especially if you have an aftermarket intake or a larger turbo installed. Additionally, in some cases this different operating method may be mis-interpreted by the ECU as a faulty diverter valve (it simply sees the diverter doing something different, it doesn’t know the diverter is actually attempting to improve throttle response), resulting in fault code P2261 being recorded. This does not indicate that the DV+ is faulty, nor does it cause any issues to the turbo or engine. If the fault code or different sound occurs and you want to prevent it, or you simply want a direct replacement for the factory diverter that is stronger, holds boost better, and lasts longer, you can choose to install the DV+ WITHOUT the main spring behind the piston. This configuration can be thought of as an improved “Standard” mode, which behaves just like the factory diverter, but with the added benefits of better boost-holding, strength, and reliability. Any real life experience with the above?? Thanks Nitro |
11-12-2018, 07:07 PM | #4 |
24151
Rep 190,721
03-14-2019, 03:40 PM | #10 |
Rep 1,153
I've got a Dinan P2 kit with their piggy. I definitely notice a difference on boost lag between shifts with this unit. But I've got an MT, so that's a different animal from what many on here have...
03-14-2019, 07:16 PM | #11 |
Chuggin' Along
333
Rep 588
I just did a bunch of upgrades and have 6mt too. I was running FBO and VF-E stage 2 tune. I could NOT keep the car in boost unless I shifted above 6k rpm. My pure stage 2 turbo came with the DV+ pre-installed. I have no idea if pure uses the extra spring or not. I primarily waned the DV+ for reliability, but sustained boost between shifts would be a great benefit, along with improved throttle response.
