11-03-2020, 08:09 AM | #1 |
Rep 108
M2C - 763m 255/285 DOES fit.
For those of you interested these buggers fit with NO rubbing or anything....
I have the following 1. The BMW BBK 6 Pot Kit 2. 763M wheels 3. Stock suspensions 4. Bridgestones RE71RS 35/255 Fronts 5. Bridgestones RE71RS 35/285 Makes a huge difference on track.. and much better than the stock 245/265 Cup 2s that came with the car |
11-03-2020, 08:23 AM | #2 | |
Rep 855
11-03-2020, 10:27 AM | #3 |
6629
Rep 4,145
Drives: '18 M2 6MT
Of course it does, you're +.6" (15mm) on the front and rear, but only 7.5mm on the outside edge, causing no rub.
71R FTW. |
11-06-2020, 01:24 AM | #4 |
Rep 1,336
Curious why not go 275 in the rear to match +1 in front and rear?
infinitekidM2C4205.50 |
11-06-2020, 01:27 AM | #5 |
Rear Admiral
1485
Rep 1,706
Drives: Bavarian Milk Wagon
I'd be more impressed if 265/35 in the front fit with no rubbing.
I'm on 265/35 front, lowered with coilovers, and have shredded my fender liners pretty good after a few track days |
MR RIZK757.50 |
12-20-2020, 08:36 PM | #6 |
Rep 916
12-21-2020, 08:54 AM | #7 | |
Rear Admiral
1485
Rep 1,706
I have the wheels off to install H&R sway bar. |
12-22-2020, 04:10 AM | #9 |
Rear Admiral
1485
Rep 1,706
Drivers side, which is a bit worse than passenger. Majority of this occurred on the track when I had the softer KW V3 progressive springs on (squishy). I've since switched to linear springs which have reduced the rubbing.
