06-03-2020, 12:50 AM | #133 | |
Rep 7,429
Yeah it is the new design since you can see the lip on the flange area. This is why I hate the factory plastic charge pipe, they're so fricken weak and proned to failure. The weird part is the TMAP sensor area is supposed to be reinforced for the sensor mounting and yet it still failed just like how the end of the PCV hose connection on the turbo intake pipe would fail. Typical plastic pipes. But overall good catch, this will show proof that the newly designed pipe is not 100% fail proof, and is not worth the price to buy new as an "upgrade" for the factory pipe instead of just opting for an aluminium pipe in the first place.
06-14-2020, 01:30 PM | #134 |
Rep 339
Fwiw, my 2018 has 60K miles on it - 56.5K by me.
Almost every mile in the (sometimes) God awful heat of North and South Carolina. I don't track the car nor drive it like a grandma and have the Dinan Stage 1 tune. No problems with the stock CP. |
07-14-2020, 03:17 AM | #135 |
Luxury at the redline :)
9105
Rep 7,563
Well, it finally happen, I got that blasphemous stock, plastic chargepipe to pop - racing a menstrual red, grocery-getter minivan, at 3am, none the less.. 🙃
Anyways, I like the Evolution Raceworks chargepipe but I think I'll let the dealer just replace it with the revised stock piece and get a free loaner car. I would have to be a masochist to want to deal with replacing that piece, on a 90 degree day, when I can get someone else to do it.. If it pops again, then I'll certainly go aluminum with some headers heat wrap.. Last edited by Poochie; 07-14-2020 at 03:39 AM.. |
07-14-2020, 03:41 AM | #136 | |
Rep 339
I asked my Indy shop - the owner said - 100% change it - saw too many blow. So I did at 61K miles - $585 parts, labor out the door - went with VSRF - piece of mind I guess. |
Poochie9104.50 |
07-14-2020, 03:49 AM | #137 | |
Rep 7,429
If you do a metal cp, aluminium gold reflective tape is what you should use, because header wrap is more designed to keep heat in and there is a pretty big air gap around the pipe for insulation so I would be more worried about reflecting radiant heat. A better option could be what DEI sells to wrap intake pipes it is made of a thick insulating material with a heat reflective exterior.
https://f87.bimmerpost.com/forums/sh...2#post30368242 Last edited by F87source; 07-14-2020 at 04:14 AM.. Reason: Correcting my really confusing writing. |
Poochie9104.50 |
07-14-2020, 04:14 AM | #138 | ||
9105
Rep 7,563
BMW recently revised the OEM pipe, with a slightly larger lip.. I'm curious to see how it holds up.. And beside, all the Indy shops around here are so bombarded with work now, they kind of give you the bum rush when you need something done. Like leave your car, we'll get to it when we get to it.. The dealer kisses your ass, gives you a new loaner car and gets it done to spec. If it pops again, I'll get the ER piece. It looks pretty plus robust and then make the proper arrangements to have the right shop do it right. So you guys can say I told you so but the original pipe did hold up to a lot, I guess that fresh, new Dinan air filter I put in today, really sent it into a peppy boast mode. |
07-14-2020, 04:31 AM | #139 | |
Rep 7,429
Wait are dinan filters not washable?
Poochie9104.50 |
07-14-2020, 04:47 AM | #140 | ||
9105
Rep 7,563
I believe the Dinan piggyback I have, pushed the pipe to pop sooner but whatever, it's kind of a relief that it happen now, so I kind of get it out the way.. It sucks that the revised version has its own inherent flaw but I'll roll the dice, for now.. I much rather this, than the S55 crank hub issue. This is just an inconvenience, in comparison to that of a anal probe, with a low viscosity lube. |
F87source7251.50 |
07-14-2020, 05:00 AM | #141 | |
Rep 7,429
Oh yes charge pipe issues are a trillion times better than the S55 spun hub issue which would drive me insane. Because the charge pipe issue is easily fixed permanently for a really low cost compared to the spun hub issue which would cost alot to permanently fix.
tranck500.50 |
07-16-2020, 12:53 PM | #142 | |
Rep 6,635
Also vrsf charge pipe is like 150 right now. However the cap for the meth bung came loose and was making some noise and probably some loss of power. I took it back to the place that did the install and they said the tightened it and put locktight on it. You get what you pay for? |
07-16-2020, 01:00 PM | #143 |
Rep 3,696
I just donated my OE charge pipe to the local BMW HPDE crew so they have one on hand b/c inevitably one blows at each track event.
Better than needing a tow or zip ties & tape to get home! |
Bavarienne6.00 |
07-16-2020, 01:25 PM | #144 | |
9105
Rep 7,563
I was obviously winning, prior to the what felt like the gas pedal going dead but it was just an apparent loss of boost pressure. What happens was, I was moseying down the highway and for some reason, I assume is because how the car sounds, no joke; everyone attempts to challenge you, by either riding your ass or constantly pacing your speed. I absolutely hate it!! So this guy was on my bumper and so I just stepped on and passed him, at wide berth and every time he would try to get closer again, I speed up and pass him in an embarrassing distance, just to hopefully show him that his little engine that could, needs to fall back and literally or figuratively stay in his lane.. When I realized I was losing power, I got off the first exit, popped the hood and instantly saw the broken pipe and reflected back to this thread. I have an appointment at the dealer tomorrow, I'll let them replace it, hopefully, under the warranty. What really bugs be about the aftermarket pipes, is no main-stream manufactures products one. I wish a company like Dinan offered an aluminum pipe but for some strange reason, only some fringe companies products some, on the market. : I know when a reputable manufacture puts their name on a product, it follows a certain of standards, in fit and finish. Denzel said it best: |
07-16-2020, 01:36 PM | #145 |
9105
Rep 7,563
That's nice of you, they go for like $400 OEM, you could of sold it back on eBay for half that amount..
07-16-2020, 06:47 PM | #146 | |
Rep 1,644
07-17-2020, 01:21 AM | #148 | ||
Rep 6,635
07-17-2020, 02:54 PM | #149 | ||
9105
Rep 7,563
That is why, when I can't do it myself and even if it cost more, I only use shops that stand by their work; humans make mistake, how they handle the errors of their way, makes a world of difference. Anyways, I just dropped my car off to have the stock pipe replaced. I asked them if it's a common issue, they didn't even know what it was, so I had the service advisor write down the defect as "turbo pipe exploded." I'll post a photo of the updated pipe (I hope), when they're are done, which they told me, might be awhile.. |
07-17-2020, 04:43 PM | #150 | |
Rep 6,635
Well hopefully you get that new version that's more stout. |
Poochie9104.50 |
07-27-2020, 06:11 PM | #152 |
9105
Rep 7,563
So to update this thread; my charge pipe cracked from the TB, the dealer replaced it with a revised version and Geico paid the bill.
For the record, I left my Stage 1 Dinantronics piggyback installed but neither did my dealer nor did my insurance company care or gave me a hassle. 🤷🏻 Hopefully, the revised plastic pipe holds up, for the remaining duration of my ownership and I won't have to go aluminum.. 🤞🏼 Original cracked pipe on the top, new, enhanced pipe on the bottom. Last edited by Poochie; 07-27-2020 at 06:18 PM.. |
07-27-2020, 08:03 PM | #153 |
Rep 1,644
Maybe its just the pics, but the distance between the clip and the end of the pipe looks to be greater on the new version. Not really sure how that's even possible since it has to align with the slot on the TB and the original pipe was already pushed up against the TB lip.
07-27-2020, 08:25 PM | #154 | |
9105
Rep 7,563
So, I'm assuming this new piece would hold stronger, since that's usually where the older pipe usually snapped from, that area seems to be it's Achilles Heel's.. The length of arrow below illustrates the larger lip VS the original pipe with a thinner, almost non-existent lip. |
