04-09-2018, 03:38 AM | #1 |
Rep 42
Tire pressure on track
***this needs to be moved section. apologies
Hello, wanted to have a discussion with the ones taking your cars on track about your tire pressure, before and after. I start my morning sessions at : 2.0 bars in front (cold) 2.1 bars at the rear (Cold) Once warm i try to not run anything above 2.5 bars (outside temp is approx 15 C currently) My last trackday i had to start with the front with 1.8 cold and it got to 2.6 warm, thats almost 1KG diff. between cold and warm tire, never had such a shift with other cars i take on track. What are you guys running when on track? Last edited by Alessandr0; 04-09-2018 at 04:11 AM.. Reason: change in section, thread posted in wrong section |
04-09-2018, 04:26 AM | #2 |
Rep 124
Copied this from this forum. I forget the original poster. Has done me well
M2 tire pressures good values from the german Sportauto test (translated by me, so pls. be patient): "Instead of the recommended warm tire pressure of 2,2 bar for all wheels for Hockenheim the recommended tire pressure for the Nordschleife is 2,5 bar warm for front tires and 2,0 bar warm for rear tires" For the non Europeans : - Hockenheim : GP track with perfect surfac - Nordschleife : well, you should now that - 2,0 bar ~ 29 psi - 2,2 bar ~ 32 psi - 2,5 bar ~ 36 psi |
Alessandr051.50 eatingpizzainthef87rules253.00 |
04-09-2018, 10:37 AM | #3 | |
Rep 34
Alessandr051.50 |
04-11-2018, 07:21 AM | #4 |
Rep 1,124
I would think 36 front 34 rear would be ideal. Just enough diff front to rear to take the edge off of understeer and create a bit of rotation into turns.
Alessandr051.50 |
04-13-2018, 02:08 AM | #7 |
Rep 1,124
No - he means 32 psi cold since the tires pick up 6-10 psi on the track.
10-01-2018, 02:12 PM | #8 | |
Rep 665
I assume these are for tires with softer sidewall construction like the Cup2's? I run slightly lower with RE71R's on my M2. |
10-01-2018, 03:46 PM | #9 |
Rep 3,402
With Cup 2 I start off at about 30 PSI and generally get to 36-37 by the end of the first session which seems to be the sweet spot for my car with those tires. I am in AZ so track temps tend to be higher than most areas
10-04-2018, 04:52 PM | #10 | ||
Rep 1,124
