04-05-2022, 08:40 AM | #1 |
Rep 1,611
Change brake pads on 2nh
Since I will be tracking the m2 comp I know I will need to do brake pads rather soon, still on stock pads and going to kill them before going to something else. Will go ferrodo DS2500 next because I am a noob and they will most likely be enough for me for a bit.
I want to do this myself and been looking at how to do it. There is always the excellent video from Farkle! but also ran into this video They differ a bit as in this video they just remove the 2 bolts and take the caliper out and change the pads but on the Farkle video he removes the whole caliper from the knuckle because there is no posted torque value for the caliper bolts. So how are you all doing this? It would be much easier to just remove the caliper bolts but if that is not how it is suppose to be done the other way is not much harder. Also was reading about having to replace bolts, not sure if they were talking about the caliper bolts. |
04-05-2022, 09:18 AM | #2 |
Rep 438
Farkle is great to have in this community.
04-05-2022, 09:26 AM | #3 |
Rep 429
He removes the wrong screw though, there are 2 screws at the back of the caliper which are meant to be used/removed and replaced when you do put it back.
You wont find the correct torque to tight these long screws as per the video, the 2 screws I mentioned are 110 Nm. Edit: you got it right here man: |
04-05-2022, 10:34 AM | #4 |
Rep 3,644
BMW also explicitly states not to remove the bolts holding the caliper to the bracket in their documentation (same for M3/4 CCB caliper, and X5M). Although if the caliper bracket has an integrated stud and there's a nut holding the caliper to it (M5) they have a spec for that.
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. Last edited by FaRKle!; 04-05-2022 at 10:43 AM.. |
04-05-2022, 10:47 AM | #5 |
Rep 1,611
That settles it then, specially if they specifically say to not remove those (I wonder why the reason is but better to just follow as removing the ones in the back is not much harder).
And the bolts should be replace right? Does anyone have a part number for those? (there was a thread recently with it I am pretty sure but I cannot find it for the life of me). Thank so much @Ratcher and @FaRKle! |
04-05-2022, 11:22 AM | #6 |
Rep 3,644
BMW recommends replacement, but if you look at the thread size (M12x1.5), bolt class (10.9), and torque spec (110Nm) it's not stretching the bolt to the yield point and is just in the normal fastening torque range, so I don't personally think replacement is necessary.
PN for the torx version of the bolt is 34106864424.
///MPhatic14956.50 No_curebimmer653.00 |
04-05-2022, 11:27 AM | #7 | |
Rep 1,611
So maybe the case of replacement for safety every few times or obviously if the bolt looks damaged. |
04-05-2022, 11:51 AM | #8 | |
The Seeker
14957
Rep 3,685
04-05-2022, 04:23 PM | #9 |
Rep 812
Crap. Just saw this. I've changed my pads numerous times by removing the 2 larger bolts. Never thought anything of it. Any advice? Should I replace the bolts? Is there a known torque for these bolts?
04-05-2022, 06:21 PM | #10 |
Rep 129
When deciding which bolts to remove, I checked the OEM procedure in ISTA+.
First under F87 type codes, which only had the blue brakes and these are lug mount without a bracket. So then went to F80 looking for the CCB option, and while there was a heap of interesting reading about the rotors and how to check and weight them, allowable damage limits etc., the actual caliper procedure looked to be copy-paste from the blue brakes still, complete with incorrect 4 piston calipers in the illustrations. Finally tried the F10 M5 type codes (same caliper), and that had correct caliper illustrations, and clearly said to remove the radial caliper to bracket bolts. But in retrospect this was flawed, as the F10 M5 has integral radial mounts on the hub carrier, so no option to remove the axial bracket to carrier bolts because there aren't any. Still, I will continue to remove mine from the radial bolts, but will preventively heli-coil or timesert the threaded holes in the bracket next time. (the bracket to carrier bolts go into a threaded steel insert already, which kinda suggests that is where we should be unbolting them) |
04-06-2022, 03:05 AM | #11 | |
Rep 429
It's still holding after many trackdays and around 25.000 km |
tropicatango460.50 |
04-06-2022, 03:09 AM | #12 | ||
Rep 812
04-06-2022, 03:11 AM | #13 |
Rep 429
04-06-2022, 03:20 AM | #14 |
Rep 812
Out of interest, where are people finding the recommended torque settings for certain bolts? Is there some kind of documentation for this?
04-06-2022, 05:50 AM | #16 | |
Rep 812
04-06-2022, 08:19 AM | #17 | |
Rep 429
https://f80.bimmerpost.com/forums/sh....php?t=1272952 The CCB from the F80 has the same specs as the 2NH from the F87 |
04-06-2022, 08:42 AM | #18 |
Rep 1,611
and with all this I kind of wished we would have got the blue brakes instead of the BBK. Not that I am there but changing pads at the track if necessary on the BBK would be such a pain in the ass
04-06-2022, 09:10 AM | #20 | |
Rep 429
The closed calipers are indeed a PIA, but better for brake performance (see Porsche and co, same construction). The 2NH brakes were an option on most markets |
04-06-2022, 10:04 AM | #21 |
The Seeker
14957
Rep 3,685
04-06-2022, 10:14 AM | #22 |
Rep 2,783
very good discussion!
go to 8:30 … he says the two knuckle bolts should be replaced because of the locking washers |
MooMooM21876.50 ///MPhatic14956.50 |
