01-31-2024, 09:15 PM | #1 |
Rep 5,623
► Sauna Install
i have an outdoor outlet, similar to pic, near the patio which i think has a conduit underground that leads to the garage where the fuse box is.
question is, can i remove the outlet and hook up the terminals to a 8kW 240vac 1ph sauna? thinking about a barrel sauna and this would be the only power source available at the moment without having to install another line.
Cars: 07 335i ► 08 328i ► 11 328xi ► 13 M3 ► 17 M4 ► 14 M6
02-01-2024, 06:30 AM | #2 |
Recovering Perfectionist
15268
Rep 941
Drives: 2015 BMW i3 BEV
Garage List 2014 Mighty Freight ... [0.00]
2015 BMW i3 BEV [0.00] 2000 Audi TT Quattro [0.00] 1967 Formula Vee [0.00] |
If that is a 120V outlet, the best case is that it is a 20 amp circuit and fed by 12 gauge wire.
If my math is correct, you will need a 240V feed at 40 amps (33 amp load) including the usual safety factor. I will let you Google for the required wire size for the above, and hope that your conduit is both passable and large enough for the new wire. Disclaimer that I'm not an electrician, but had to install a 240V/40A outlet for my 32A EV charger.....
2015 BMW i3 BEV, Giga World (Lodge interior), Tech/Driving Assist Packages, 30K miles
2000cs3502.50 |
02-01-2024, 07:55 AM | #3 | |
Rep 39
Drives: 2023 X3 M40i
vreihen1615268.00 |
02-01-2024, 05:29 PM | #4 |
15268
Rep 941
Size it for 50 amps?????
02-12-2024, 05:13 PM | #5 |
15268
Rep 941
