03-05-2023, 05:40 AM | #111 | ||
4693
Rep 2,542
Side note on CSF vs d088 - I think they show the pretty much the same results because neither gets the air flow needed to do the job up to their potential. Need to open them up to full air to see which works better but that is a moot point until the fmic is out of the way.
F87source7251.50 |
03-05-2023, 06:10 AM | #112 | |
Rep 7,429
Another option is to just retrofit the s55 intercooler + radiator, but again expensive...
OG Shark4692.50 |
03-05-2023, 10:16 AM | #113 | |
4693
Rep 2,542
Getting ready to start on another cooling project with a company that can make anything & everything in coolers. We talked briefly about the top mount conversion on the N55. We know we can do it but we very much rigged it up just to make it work on our car (tie-down straps anyone ). To do it right and make it look good - we can definitely do it but it is going to require a significant investment and I’m not convinced that there would be enough interest for it too financially make sense. Fresh start with the R&D and then add in the prototyping and testing costs - I’m afraid it would push the sales price of the kits too far to make them appealing to enough people to make it all work. Once we get going on the other stuff going to sit down and dig into it a bit more - the numbers were very very rough so need to narrow that down. I personally want this too but just has to make sense for us to move on it.
03-05-2023, 12:46 PM | #114 |
Rep 3,695
F87source OG Shark
Sounds like we’re back to the shortest/smallest IC possible that’s OK for daily driving and pairing it with WMI for IAT control while under load. |
03-05-2023, 01:05 PM | #115 | |
@lbb_kev
491
Rep 514
OG Shark4692.50 |
03-05-2023, 04:23 PM | #116 | ||
Rep 7,429
Also remember it's not only for the m2 guys, it is for all n55 guys - so hopefully it should be enough of a market to work on.
OG Shark4692.50 |
03-05-2023, 04:27 PM | #117 | |
Rep 7,429
So at this stage you can look at the: BMS intercooler, VRSF intercooler, and even the MAD intercooler (which looks to be the exact same as the BMS intercooler just painted black). I would also look at ducting, if you have some time with some card board and some fiber glass you could do something like this:
OG Shark4692.50 |
03-05-2023, 07:13 PM | #118 |
Rep 4,146
I already suggested the ER intercooler for the same reasons you’re pointing out. The empty space behind it can be used for another aux radiator - but something else:
https://f30.bimmerpost.com/forums/sh...ght=Arm&page=7 I remember this thread from 2 years ago where we discussed shrouding and even coolant temp (see last page) One member noted a decrease in coolant temperature since installing the thin profile intercooler over a Wagner Evo 1, despite it being taller (and allegedly blocking the radiator more) I’m guessing that the thinner profile allows more air to pass through to the radiator behind it. There is also the factor of the bottom portion of the ic is not directly touching the radiator - which means it’s also not transferring heat through conduction. Finally, something like the Evo 3 is 7.5” deep, it could be pushing the puller fan away from the radiator - and it’s depth could be slowing/inhibiting airflow behind it. |
F87source7251.50 |
03-05-2023, 07:40 PM | #119 | |
Rep 7,429
Your idea is great, but I think at the end of the day it would be extremely difficult and cost quite a bit to do as well. Interesting, maybe ZM2 should try an arm or ER intercooler (after going stock + water injection first to make sure air flow is indeed the issue). But technically the intercooler isn't supposed to touch the radiator. There should be a small air gap between the two. Even my BMS intercooler has a small gap.
03-05-2023, 08:18 PM | #120 | |
Rep 4,146
03-05-2023, 09:14 PM | #121 |
Rep 7,429
Ok let me look through it and get back to you guys. But it is a good idea to run something behind the intercooler, only problem is figment as it's quite tight behind the end tanks. Also I haven't seen an aux cooler with inlets and outlets big enough to not be restrictive.
03-05-2023, 09:38 PM | #122 | |
Rep 4,146
03-05-2023, 10:15 PM | #123 |
Rep 7,429
03-06-2023, 09:48 AM | #124 | |
4693
Rep 2,542
Ha yeah still going to vet it thoroughly and see what we can do. At the least I'm going to improve on what we have already done on my car as a part of the build I still want to do with it. Maybe if we don't do a "kit" we can still facilitate the one off bits and a parts list for the other stuff for you guys that want to go that way without having to go into a full blown production mode level.
Once we start getting into again I'll follow up with you guys. I do expect to know in Q2 one way or the other.
F87source7251.50 |
03-06-2023, 03:01 PM | #125 | |
Rep 7,429
03-07-2023, 02:44 PM | #126 |
Rep 10
Drives: F87 m2 lci
Hello guys, i'm running a stage 2 turbo and i'm planning to switch my wagner evo 2 to an evo 3 for some track use
So it could work or not? Reading this discussion it could restrict the flow to the radiator ,i also have the eventuri duct, and i think wouldn't fit without trimming or some modification |
03-07-2023, 03:48 PM | #127 | |
Rep 4,146
Mods: Yes.
Liukk891.50 |
03-07-2023, 03:57 PM | #128 | |
Rep 10
Drives: F87 m2 lci
I was considering evo 3 only for tubefin core and because would be more light |
03-07-2023, 04:11 PM | #129 | |
Rep 4,146
Tube and Fin are inferior to bar and plate intercoolers as well. Have you checked with XPH for their pricing to ship to Europe?
Mods: Yes.
03-08-2023, 01:42 AM | #130 |
Rep 7
I suggest you try wmi before spending on another intercooler. Stage 2 turbo with wmi will be enough to keep iat cool at track. This is the best solution and your radiator will have enough air flow through with evo 2
03-08-2023, 07:27 AM | #131 |
Rep 4,146
I don't think this will be an issue actually.
Mods: Yes.
03-08-2023, 07:44 AM | #132 | |
Rep 4,146
https://f87.bimmerpost.com/forums/sh....php?t=1782572
Mods: Yes.
