12-16-2022, 07:16 PM | #1 |
In the garage
390
Rep 211
M2CS Exhaust Valve Operation
Hello,
I've always felt my exhaust valves do not function as expected. In my previous car (Audi RS3) the sound difference between Comfort and Dynamic (aka, Sport) was obvious. In the CS, I don't hear any change in exhaust sound between Efficient and Sport or Sport+ modes, regardless of engine temperature or driving conditions. I've scoured the forums to understand how the exhaust functions and encountered much conflicting information. Some posts indicate the exhaust valves are open during cold start and close when the engine is warm. Others explain how the exhaust valves only open once the engine is warm and in the higher rev range (3800 +). This simply does not appear to be the case for me. Since I couldn't see the exhaust valves with the stock exhaust system, I was unable to confirm anything. However, I installed the AA EL midpipes and axle back tonight and was able to visually confirm the exhaust valves are closed during cold start. Can anyone confirm the expected behavior of the exhaust valves? I'd really appreciate any insight! TYIA! |
12-17-2022, 05:18 PM | #2 |
Rep 3,073
Unlike in the M2C, they seem to do their own thing. Basic rule is if you press the loud pedal regardless of mode things are louder. If you don’t things are fairly quiet. I quite like this.
JD_M2D2390.00 |
12-17-2022, 06:41 PM | #4 |
In the garage
390
Rep 211
Thanks! I will look into a controller next. I did confirm the valves are open at idle, in sport + with engine warm. I was glad to see that
BMW M2CS 6MT
IG/TikTok: jd_m2d2 |
12-17-2022, 08:04 PM | #5 |
Rep 4,685
The stock logic makes the cabin a very pleasant place to be. Valves open is horrific on the highway. The manual control is nice because you can be obnoxious while poking around town. The stock logic makes this difficult to non existent.
12-18-2022, 07:15 AM | #6 | |
Rep 389
It isn't. It's just loud.
2020 M2 CS
1978 911 SC 1988 Landcruiser |
12-18-2022, 07:24 AM | #7 |
Rep 4,685
Depends on your personality. Sometimes I'm just feeling a bit rowdy. Drive a bit more peppy. The extra noise feeds into the pleasure. It's not for everyone else it's for me.
12-18-2022, 02:05 PM | #8 |
Rep 3,843
BM3 flash tune will allow you to have the exhaust valves always open according to sport mode. In efficient mode it is as quiet as a church mouse.
12-18-2022, 02:06 PM | #9 |
In the garage
390
Rep 211
As I understand it, a flash tune would void my factory warranty, correct? If so, that is not an option for me. Either way, I'm not too worried about it... just glad to see the valves do in fact open up at some point.
12-18-2022, 05:59 PM | #11 |
Rep 111
https://www.cgprecision.com/#!/VSC-2...egory=19266005
This is what I run. Not an advertisement but it works well. I prefer the noise with the valves open it’s not too loud most of the time. BMW is a bit behind other makes with the exhaust control. My AMG wagon is night and day with the flick of a switch in terms of exhaust level, pops and bangs etc. |
M3R12173.00 |
12-18-2022, 07:12 PM | #12 | |
Rep 4,685
12-20-2022, 03:53 AM | #13 |
Rep 547
The car is loud on start-up because the turbo wastegates are open. Once the start-up sequence is over the noise quietens down.
When the engine is switched off, the exhaust valves default to open. You can unplug the valves whilst the car is off (and tape up the connectors to protect them) to keep the valves open at all times. I like the sound. I can still hear differences between the engine modes, and it doesn't drone. |
JD_M2D2390.00 |
12-20-2022, 11:57 AM | #14 | |
Rep 2,356
BSM ///M2cs, 6spd
12-20-2022, 12:12 PM | #15 | |
In the garage
390
Rep 211
12-20-2022, 12:49 PM | #16 |
Rep 547
Interesting.
Yes, it does show a soft code on my code reader. Butt dyno would say no power reduction and my times on track have gotten quicker since unplugging the actuators, but too many variables to say for sure. I wouldn't put it past Audi to do something like that. |
12-20-2022, 02:21 PM | #17 |
Rep 72
JD_M2D2 I highly recommend the VSC-2 controller; found its really the only solution to have complete control over your valves. Here's a quick video:
https://www.youtube.com/shorts/rkM4_91y-CY |
JD_M2D2390.00 |
12-29-2022, 12:35 AM | #18 |
Rep 4,088
FWIW I had a CG precision laying around from my prior M5 and put it on my CS, and removed it within a day. The stock actuator tuning is designed to close during low-RPM high-load scenarios which happen a lot in street driving, and with the valves open will result in drone. This is amplified if you have any kind of aftermarket exhaust modifications.
So, my advice is give it a try but with awareness that it may not be your cup of tea depending on your driving habits and preferences. |
12-29-2022, 08:07 PM | #20 |
Rep 4,685
really? I think the drone is horrific with valves open at some rpms. Especially highway cruising. I think it's between 2800 and 3000 on my exhaust. I can easily tolerate around town because the rpms are varying a lot.
12-29-2022, 08:26 PM | #21 |
Rep 4,088
02-08-2023, 05:49 PM | #22 |
Rep 17
I just got a VSC for my CS and it's acting weird. After about 5 minutes the valves close again and pressing the button for the VSC doesn't do anything.
Faulty VSC? Does the VSC need to be on the driver side vs passenger side? Trying to trouble shoot before I reach out to CG. |
