01-29-2021, 02:19 PM | #419 |
Rep 2,526
Tuning for flex fuel, They're tuning with E85 right now.
01-29-2021, 02:20 PM | #420 | |
Rep 2,526
Now I'm on a mission to find an upgraded EKP module.. Seems EOS are the only players in the game, and $700 is a lot to stomach. |
01-29-2021, 03:27 PM | #421 | |
Rep 7,429
Yeah you're going to need the EOS EKP, BMS was working on a secondary LPFP trigger that might have load splitting capabilities to help boost the factory EKP, but I do not know their progress on that. Maybe you can reach out to Terry and see if you can help on development.
detroitm22428.50 |
01-29-2021, 06:18 PM | #422 |
Rep 2,526
So we put a super conservative tune on the car. I plan to go back at a later date for another map and juice it up a bit. But here's the dyno Graph from this week. Taken at 93 octane BM3 Stage 2, Ecutek 93 octane, and Ecutek E77.
I'll have some data logs and such later when they send them over to me. |
01-29-2021, 06:29 PM | #423 | |
Rep 7,429
01-29-2021, 06:43 PM | #424 | ||
Rep 2,526
01-29-2021, 06:54 PM | #425 | ||
Rep 2,526
01-29-2021, 08:26 PM | #426 |
587
Rep 898
stock LPFP can actually flow a good amount on ethanol blend.., definitely enough to max out stock turbo..
01-30-2021, 01:33 AM | #427 |
Rep 677
I'm running the stock turbo, stock LPFP with a Dorch Stage 2 HPFP and E85. I haven't had any issues, but it's hard to know how much our LPFP's are struggling as we don't have LPFP pressure sensors.
I'm thinking I'll end up upgrading my LPFP just to be safe. |
01-30-2021, 02:03 AM | #428 | |
@lbb_kev
491
Rep 514
Photos on Injector Dynamic's site:
Full E85 DI-Only 717WHP Flex Fuel tuned by BendCalibration (ECUTek) | Built by SD Garage Last edited by -Eidos; 01-30-2021 at 02:08 AM.. |
01-30-2021, 03:09 AM | #429 |
Rep 7,429
Motivs reflex canbus box has an input for an lpfp sensor with fittings that they also make for these bmws. so you could always go that route, and I heard that motiv was working with ecutek too so that's good.
01-31-2021, 09:32 PM | #430 |
587
Rep 898
Yup. But it’s honestly overkill unless you’re doing PI. PI is kind of a no brainer with the reflex.
01-31-2021, 10:34 PM | #431 | |
Rep 7,429
Plus it doesn't utilize the ugly and cluttered obd2 cable that goes into the cabin that the zeritronix unit has to use, if I recall correctly.
02-04-2021, 01:45 PM | #432 |
Rep 259
question for you gurus:
in what circumstances will the stock hpfp crash? the reason i ask is because i was on the dyno yesterday to baseline my car on stage 1 91 oct tune. i live in vancouver and im running our crappy chevron 94 plus e15 blend (which is about equivalent to US 92 in washington). no problems with the run and car made only 350 whp and 402 wtq which is i guess is ok but the car ran smooth so im sorta happy. so i decided to flash stage 2 91 and try it. Now, at this time i only had a catless dp installed. I didnt have the requisite intercooler upgrade but i figured its just one run and we were gonna let the car cool down before the run. however, before the actual power run, the tuner ran the car to redline to let the ecu adapt to the stage 2 tune and then ran it for the actual power run right after. at about 5500 rpms, it was pretty obvious the car pulled timing. so i checked the logs and my timing advance in cylinder 4 dropped to 0 and hpfp wasnt reaching target pressure, so im assuming this is what youd call hpfp crashing? anyways, ive attached a couple logs. id appreciate it if anyone can shed some light into this. im wondering if this is an IAT or fueling issue? or if something else is going on? run 1 stage 2 91 https://www.bootmod3.net/log?id=601a...90c662d69cf0b4 run2 stage 2 91 https://www.bootmod3.net/log?id=601a...729b5687b69830 the 1st and 2nd runs were stage 1 91, last run was stage 2 91 |
02-04-2021, 03:10 PM | #433 |
Rep 643
hpfp 'crashes' when it cannot output as much as the car is requesting. if the differential is great enough, the car has safeguards to protect the motor from running lean. in your first log, the worst case was at 5400rpm, where the car requested 2500psi, but the hpfp could only keep up 1500psi. i don't think this triggered any safeguards, but you are getting close.
the hpfp is mechicanically driven, so it is RPM dependent and there are efficiency zones. unfortunately, this car is known for having hpfp issues at this power level, but i think yours might be a little weaker than normal. how many miles?
M235i rwd 6mt
02-04-2021, 03:36 PM | #434 | |
Rep 1,115
02-04-2021, 03:47 PM | #435 | |
Rep 259
02-04-2021, 03:49 PM | #436 | |
Rep 259
In regards to the the ethanol, the e85 i put in there was about a month old. Could it have degraded and not perform as fresh ethabol wouldve? |
02-04-2021, 03:58 PM | #437 | |
Rep 7,429
02-04-2021, 04:06 PM | #438 |
Rep 259
I know this because inactually lived in alberta for many years where i was using husky. But ive since moved to vancouver and the “best” they have out here is chev 94 so ive been blending that with e85. So from your responses it is likely a fuel issue? And not heat?
02-04-2021, 04:38 PM | #439 | ||
Rep 2,526
(though it does need to be in the cabin) |
02-04-2021, 04:40 PM | #440 | ||
Rep 2,526
