05-13-2018, 12:08 PM | #1 |
Rep 91
M2C rear suspension: “the Elixir of Motoring” according to Chris Harris
Haven’t seen this discussed much - the direct connection of the rear suspension without bushings is a big deal. Chris Harris called it “the elixir of motoring” when he reviewed the M4. The lack of bushings provided an unprecedented connection between his foot and the rear wheels.
This is a big deal, as is the balljoints in the front suspension. Porsche does that with the GT3 and GT2 cars, over the regular 911s. |
05-13-2018, 02:03 PM | #2 |
Rep 212
Probably because it’s not unique or new to the M2C. The OG M2’s rear suspension is directly bolted to the subframe also (i.e. no bushings).
05-14-2018, 12:08 AM | #4 |
Rep 69
05-14-2018, 12:15 AM | #5 |
Rep 3,622
M3 Adjuster7909.00 |
05-14-2018, 07:15 AM | #6 |
Rep 171
I can't help asking my self enviously what "elixir" might the OP be consuming... I mean, we see people taking BMW koolaid on a regular basis but this got to be much stronger
kfscoll208.50 voyagergab634.00 |
05-14-2018, 03:05 PM | #7 |
Rep 91
I see, thanks.
Then it looks like just the ball joint front suspension (what Porsche does on GT3/2 911s) and the 5mm lower ride height are the suspension differences. |
05-14-2018, 03:09 PM | #8 |
this is the way
18453
Rep 8,588
The new ball joints are in the rear. Where in the rear is still unknown, hope to learn more when reviews come out. The difference in ground clearance is not due to the car sitting lower, it's either the revised front bumper or taller muffler.
flyaway140.50 |
05-15-2018, 06:41 PM | #9 |
Rep 91
Everything I’ve read says the balljoints are in the front. They replace the bushings. Rear has no balljoints.
05-15-2018, 06:47 PM | #10 | |
this is the way
18453
Rep 8,588
Source: 2018 BMW M2 Competition - still want that Audi RS3? Page 20 under chassis Magazine Article |
05-16-2018, 01:25 AM | #12 | |
Rep 69
05-19-2018, 09:46 AM | #14 |
Rep 91
05-19-2018, 09:59 AM | #15 |
Rep 91
Ooh, Chris Harris trashed the M5C:
New M5 Comp has all of the things it doesn’t need (more power, more yob etc) and not what it does need (camber, not looking like a 520d) |
05-19-2018, 11:32 AM | #16 | |
Rep 69
#2. Sound could be completely different and worse #3. No more direct rear bolted frame (his “elixir” haha) So we will see. He can easily neg the C |
05-19-2018, 01:18 PM | #17 |
Rep 497
Rear subframe is still directly bolted.
M2 comp Delivered 8/9, 6spd, Hockenheim Silver, exec, dark wheels, blue stitching, no sunroof.
05-19-2018, 11:27 PM | #18 | |
4143
Rep 6,926
#2) He still talks about his signal green M3, he loved it(aka the S55 driving experience) #3) Wrong...rear subframe is still directly bolted. You know what’s coming in a few months. Chris Harris sliding the crap out of the Competition around a track, revving out the S55. Burning through tires, all while wearing a giant grin on his face. Classic Chris Harris in a rwd BMW with a manual. |
05-22-2018, 08:19 PM | #19 |
Rep 4
From what i've read the only thing the M2C will have over the M4C is the ability to spec the 2NH M-sport brakes (6Pot F/4Pot R with 400mm F/380mm R steel discs) as a relatively low-cost option ($3000 AUD), where as on the M4 the only option is ceramics which add $18,000 AUD to the overall cost.
The M4C has the carbon roof, merino interior and better appointments (ie. HUD) and probably better weight distribution as the chassis and S55 were developed for each other. Last edited by squareznboxez; 05-22-2018 at 08:37 PM.. |
05-22-2018, 08:42 PM | #20 | |
Rep 1,290
Dry sump flat six
05-22-2018, 08:52 PM | #21 | |
Rep 3,660
Drives: 981 Cayman GTS
MSurge83.50 |
05-22-2018, 09:00 PM | #22 |
Rep 4
Ah yes you're right, the other factor despite the close curb-weights is the shorter wheel base of the M2, which i think for most people will more than compensate for the weight disadvantage.
Regarding the weight dist. you also have to consider the center of gravity where i would speculate the M4 would a lower value due to the carbon roof and trunk. Either way it is a very nicely specc'd car on it's own merit when you consider the shorter dimensions and flared body work, S55 motor and improved 6sp manual, suspension and 6/4pot brakes, m3/4 seats. It's probably better value over a base M4 to many fans. Last edited by squareznboxez; 05-22-2018 at 09:07 PM.. |
MSurge83.50 |
