12-11-2022, 04:43 PM | #1 |
Rep 1,340
M2C 6MT 100-200-250km/h measurment
This morning I did a test and some logs since I had never made measurements,
M2C 6MT BM3 Stage2H 91 tune Mods: Hybrid turbos Catless Full exhaust M2 OG Crank hub 100-200km/h 7.5sec 100-250km/h 15.5sec Log if anyone wants to share their measurements, welcome! I would like to see a log of someone stock to compare intake temperature. Last edited by Track/S; 12-11-2022 at 05:19 PM.. |
12-16-2022, 12:07 PM | #2 |
Rep 125
Are you starting from exactly 100kmph? For having hybrid turbos your time does seem a bit slow. I would start at 60-70 km so by the time youre going 100 you are already moving to get an accurate time.
you have an exhaust from OG m2? pics? |
potato13373.00 |
12-16-2022, 03:40 PM | #3 | |
Rep 1,340
I start at 70km/h. The time corresponds to power, stage2h ron95 550hp on dyno. Stage2h ron98 607hp Stage2h racegas 622hp Exhaust: |
Robin_NL8718.50 |
12-16-2022, 06:54 PM | #4 |
Rep 125
Hm, i wonder if that exhaust is hindering your performance considering a stock s55 exhaust is a true dual setup.
I know 7's 100-200 is pretty common on stock turbo 93 octane maps. |
12-17-2022, 12:55 AM | #5 | |
Rep 1,340
91 octane and 93 are not the same, it is possible 7.X with stock turbos 93 octane and DKG, 91octane 6mt it is difficult. |
12-18-2022, 07:51 AM | #7 | |
Rep 1,340
Stage2h ron98 100-200 6.8sec Last edited by Track/S; 12-18-2022 at 12:43 PM.. |
01-06-2023, 12:48 AM | #8 |
S0THPAW
8719
Rep 7,846
Nice.
Mine is Stage 2 MHD tuned 'by phone' LOL and I have the crank hub fix plus 'better' sparkplugs. But no downpipe(yet). Last spring I did a Dragy 100-200kmh time(starting from '80' or whatever) in 7.29s DCT (GTS software) Probably running 540-550BHP crank and 700 ish Nm torque. Normally the 100-200kmh sprints are 7.5-8.0s irl which is still pretty fast. And DCT helps a lot vs manual. Keep up the good work. Cheers Robin |
01-06-2023, 05:48 AM | #9 | |
Rep 1,340
01-22-2023, 03:10 PM | #10 |
Rep 156
Sorry but the numbers are not impressive for a hybrid turbo setup.
I just did a 100-200 test, stock turbo’s BM3 98 Ron STG 2 DCT and did 6.5 This was from 80 in 3rd gear becouse second gear couldn’t get traction on the CUP 2’s I’ll try with my Nankang AR-1 next time. Probably could do a 6.2-6.3 By the way 100-220 I was a car length ahead of a 992 turbo |
01-22-2023, 03:28 PM | #11 |
Rep 1,340
01-22-2023, 04:23 PM | #13 |
Rep 1,340
You should ask protuningfreaks this question, with a custom map you get more than 100hp of difference between stock and hybrids, and the other difference is that stock turbos with stage 2 can die at any time, in my case they were mounted to prevent premature breakage and eliminate excess torque at low revs.
01-22-2023, 06:47 PM | #14 | |
Rep 420
Now running stock turbos on a 2H map where the tuning strategy is geared towards working with hybrid turbos then yeah, you're more on the edge of killing a pair of stock turbos that way. Most important note though I agree with you I don't get hung up on these numbers anymore, the graphs tell a much better picture in how you're getting to whatever number you logged. I'd rather consistency if the hardware doesn't need to push 90% into its efficiency to get there. Glad you're happy with your results that you have, I care not for the numbers just the experience you're having along the way |
01-23-2023, 07:05 AM | #15 | |
Rep 1,340
chris7197336.50 |
09-06-2023, 03:50 PM | #17 | |
Rep 8,972
I can't break traction in 1st let alone 2nd with cup 2s unless deliberate provoking. Pss and ps4s would spin in 3rd, warm cup 2s nothing, solid. |
09-06-2023, 03:53 PM | #18 | |
Rep 8,972
