07-21-2021, 03:27 PM | #1 |
Rep 22
Clicking from wheel area when turning wheel right due low speed reversing
Hi all,
As title suggests, I've noticed there is a clicking coming from the front axle near the wheels when I'm parking, reversing or doing any sort of manoeuvring at really low speeds <3mph. No noise when driving at normal speeds and no noise/clicking if a turn the wheel really slow in the direction I need to go. Also no noise when front axle is jacked up and on axle stands… Any ideas? Thanks Tim |
07-21-2021, 07:21 PM | #2 | |
Rep 406
Drives: BMW 328xi BMW X5 F15 BMW M2
07-21-2021, 07:34 PM | #3 |
Rep 10
Seems to be a common issue across all M models from what I've heard. I had a similar sound, tightening the pinch bolt that holds the front shock to the front spindle did the trick for me. When I went to turn the nut it moved the bolt with it, so it was definitely loose although its never been touched. Maybe they stretch over time and lose tension? I believe bolt and nut were 16mm, I used a ratchet with a 16mm socket and a 16mm wrench and snugged them up and sound has been gone since. Maybe give it a try and see if any changes.
07-24-2021, 04:23 PM | #4 | |
Rep 22
