07-16-2021, 01:13 PM | #1 |
Rep 1,609
Steering wheel vibration on braking
Been having some steering wheel vibration when I brake. Car has 16k miles, I got it with 10k mikes a few months ago. Don't remember it doing this when I bought it. Usually I would say the vibration is around 40-60mph and worst on light braking, if I brake hard I don't think its noticeable anymore. Never tracked the car and I have driving it spirited but nothing crazy really, pretty babied.
I need to go get it serviced soon so will bring this up at the dealer but was wondering if anyone had any idea. Its a 2020 m2 comp. Thank you |
07-16-2021, 01:31 PM | #2 |
6634
Rep 4,145
Drives: '18 M2 6MT
Pad deposits. The first owner of my car had the same issue, complained of it at 9,000 miles and the dealer told her it was common (OG M2) and replaced both the pads and rotors.
Slap a set of race pads on for a week and it'll go away, then put your stockers back on (if the dealer doesn't fix it for you). |
MooMooM21817.50 |
07-16-2021, 01:58 PM | #3 | |
Rep 1,609
VisualEcho6633.50 |
07-24-2021, 04:54 PM | #4 |
Rep 1,609
Took it to dealer today. Not going to be warranty replaced but according to them BMW recommends driving it this way for a while longer because it can disappear. Only solution from them is of course put new rotors in which I am not going to do at 16k miles. I do appreciate that they did not say the rotors are warped, they said that there is a pad imprint in the rotor and likely what is causing it, it is weird because I bought the car with 10k miles and pretty sure this was not happening and the car has not sat at all, I drive it every other day and the most it has sat has been like 5 days. But oh well, luckily it is only coming through at 50mph, 40 there is nothing, 60 a tiny bit and over that nothing either. If it does not go away I will get some track pads and see if I can smooth the rotors that way.
07-25-2021, 06:40 AM | #5 |
Rep 1,389
I'm seen pad imprints and have had judder albeit usually briefly then goes away. Can't tell you when or how. Could be after washing my car. Could be driving and braking hard, could be time itself or any other number of variables.
It's not however 'warped rotors' which can go in inverted commas as it is an extremely rare occurrence. |
MooMooM21817.50 |
07-25-2021, 08:42 AM | #6 | |
Rep 1,609
