06-24-2021, 06:15 AM | #1 |
Rep 243
Brake pad imprints and vibrations
Hey guys,
For some time now, I'm experiencing brake vibrations at highway speeds (55 mph++). Since the car is still under warranty, I already went to the dealer with it. They were able to reproduce the error, said to me the rotors were warped and that this isn't covered under warranty. I found this really strange since, to be honest, I don't drive the car that hard and I've never tracked it. When inspecting the rotors, I do see some imprints from my brake pads, so I think it's likely that this has something to do with it. I also don't feel the vibration in my steering wheel. To me, it's even less likely that I've warped the rears. Is there anything I can do to resolve this? I already tried some hard braking (130mph -> 50mph) but this really didn't change much. I've attached two pictures of a rear rotor, others look similar. 2018 M2 LCI (N55) Stock rotors + pads Never tracked |
06-24-2021, 07:03 AM | #2 |
Rep 1,389
There is no spoon aka warped rotors
https://www.google.com/url?sa=t&sour...geQ47I6fsJZy3W I've had periodic judder from drivers side front disc but right now it's gone. No tracking. |
06-24-2021, 08:48 AM | #3 | |
Rep 243
06-24-2021, 09:36 AM | #4 |
Rep 500
From the quoted article:
The obvious question now is "is there a "cure" for discs with uneven friction material deposits?" The answer is a conditional yes. If the vibration has just started, the chances are that the temperature has never reached the point where cementite begins to form. In this case, simply fitting a set of good "semi-metallic" pads and using them hard (after bedding) may well remove the deposits and restore the system to normal operation but with upgraded pads. If only a small amount of material has been transferred i.e. if the vibration is just starting, vigorous scrubbing with garnet paper may remove the deposit. As many deposits are not visible, scrub the entire friction surfaces thoroughly. Do not use regular sand paper or emery cloth as the aluminum oxide abrasive material will permeate the cast iron surface and make the condition worse. Do not bead blast or sand blast the discs for the same reason. |
06-25-2021, 03:39 PM | #5 | |
Rep 243
Thanks!! |
06-25-2021, 07:10 PM | #6 |
Rep 391
I had a similar issue on my disks after I baked them at the track on stock pads. The brakes juttered so bad I thought I had warped them.
Going off what some guys were saying here, I bought some track pads from Ferodo ds1.1 I think. And ran them for a bit and they scraped it all off. Sounded terrible though as the track pads squeal terribly. Sounds like a dump truck! Once the jittering was gone I switched back to more street friendly ferodo ds2500 pads. All was good after that! Can try it to see if it works. Way cheaper than new disks. |
07-07-2021, 10:27 AM | #8 |
1023
Rep 839
Here is a video we produced quite some time ago that shows how to scrub discs using race pads. This shows what Drop The Hammer mentions above. You may find it helpful!
07-08-2021, 09:25 AM | #9 |
Rep 95
Also a tip, if your brakes/discs are hot after a spirited drive, don't engage the parking brake if you stop until the brakes cool. I think that is a top reason why pad material bakes onto the rotor and given your photo, may have been why you can see the outline of the pad on your rotor.
Current: 2020 X3M, 2022 911 GT3
Past: 2020 M2 Competition,2018 X3 M40i,2017 X3,2016 VW ,Golf R,2015 BMW M3,2010 VW GTI,2008 911 GT3,2005 VW GTI,2002 VW GTI 337 |
07-10-2021, 03:29 PM | #10 |
Rep 2,866
Dealership is not being straightforward on this. Discs really won't 'warp' and if they do, then it would be because the expansion pins were defective or some other issue (unless you'd been abusing them, which you say you are not). This should be covered under warranty as it isn't simply wear.
But since they aren't likely to reverse themselves, try this before you spend on special pads and double swapping them. Try washing it to get 'em all 'rusty', then next day go out someplace you can truly bed them properly: warm them, then do multiple 70-5 or 80-5 hard stops right in a row; probably at least 8-10 cycles of stopping. Just a few hard stops won't have the same effect. |
07-11-2021, 04:37 PM | #11 | |
Rep 350
07-16-2021, 12:16 PM | #12 | |
Rep 95
07-17-2021, 03:05 PM | #13 |
Rep 243
I never apply the parking brake on the car actually. Since the imprints are also at the front, I sort of ruled that out already. DoubleJ, I’ll try your suggestion as wel as giving the dealer an additional call.
