06-17-2018, 02:51 PM | #111 | |
Rep 643
with that said, you think my timing drops is acceptable? |
06-17-2018, 03:45 PM | #112 | |
587
Rep 898
But the fact that you need to add 10% ethanol on top of E10 93 octane on a 91 map... it seems... not the best IMO. Do you have some logs on regular pump 91 on the 91 map?
06-17-2018, 04:48 PM | #113 |
Rep 4,203
http://www.bootmod3.net/log?id=5b238975d10b4304d3cede55
http://www.bootmod3.net/log?id=5b238990d10b4304d3cede5c http://www.bootmod3.net/log?id=5b2389bed10b4304d3cede5d Here are couple on straight 93 and stg 2 93 map v5.3. Ambient was 74deg. Did a 3rd, 4th, 5th got screwed up so deleted and a 3/4/5 shift. My IAT's are still high but I didn't find any major issues. These are back to back pulls. I have been running without booster for about 7 tanks now |
06-17-2018, 06:38 PM | #114 |
Rep 2,577
@designatedposter cookiesowns
As for why bigger turbo ignites better, IAT and flow capacity don't really matter. It's the significant lower back pressures that makes a difference. This is how: 1) Freer flow turbine restricts less at any given shaft rpm. 2) Bigger turbo needs less shaft rpm to make any given boost/flow. Some may ask will down pipe help in the same way? Yes it will, just to a way less extent as a component downstream of turbo. Hot half of turbo (turbine + manifold in one piece) play the dominant role dictating back pressure among all that is "engine back". It's easily understood when you imagine exhaust gas flow gets out of cylinders, enters turbine housing and 'hits' turbine directly to drive it. Anything else, including downpipe, is downstream and only gets what turbine filters. Generally, anything lowering turbo shaft speed reduce back pressure, and thus helps ignition. For example - turbo inlet pipe, downpipe & catback exhaust. But they're just too insignificant compared to turbo. No one really gets meaningfully better timing, just because of installing any or all of them. Most guys gets perfect timing on OTS STG2 with bigger intercooler only.
Lemania 2320
cookiesowns587.00 |
06-17-2018, 09:21 PM | #115 | |
587
Rep 898
Yes, better IAT & flow capacity are a by product of a less restrictive turbo design ( compressor/turbine ) Well if you stick within the efficiency range of the turbo and tune for your particular car, mod, and fuel, you can definitely get better timing and "smoother" overall power delivery as I've shown with my new logs on an early revision of my map. 14psi stock turbo stock downpipe is plenty for me. This is the safe spot for lap after lap track days for me.
SeanWRT3179.00 |
06-17-2018, 09:36 PM | #116 |
Rep 2,577
@cookiesowns thank you for the kind words. To me, sharing is a big part of tuning fun.
Lemania 2320
cookiesowns587.00 |
06-17-2018, 10:10 PM | #117 | |
Rep 643
http://www.bootmod3.net/log?id=5b1dc12ad10b437faba93f6e for reference, here is the e20 log once again. same ots tune as above. http://www.bootmod3.net/log?id=5b25db99d10b4304d3cee419 i've a general question, does sport mode change the spool behavior? i notice that sport mode has much less turbo lag as compared to comfort, DTC, or DSC off mode. i've even tried to stomp on the pedal in comfort mode to try to simulate the sport mode throttle mapping, but it still seems that sport mode is much less lag. i recall there were tables for spool parameters.. |
06-18-2018, 11:59 PM | #118 | |
587
Rep 898
Correct in sport mode the WGDC bias is a little bit different. DME will keep WGDC closed at 100% until it needs to bleed off boost. Same goes for sport_. DSC Off should have the same throttle mapping.
06-22-2018, 09:40 AM | #119 |
Rep 643
i've got fresh logs of a different local shell gas station! it's about 30 cents more expensive per gallon, but seems worth it, take a look.
m235i n55 ewg stage 2 91 octane tune shell 93 octane fuel 3rd gear pulls (6mt) log 1: CLEANEST log i have ever had, textbook. this gas station looks really promising http://www.bootmod3.net/log?id=5b2c2bc5d10b430873d738df log 2: taken shortly after log 1, but shows timing drops reminiscent of my typical logs.. knock at 4700 rpm..what's your take on it? insignificant increase in IAT. http://www.bootmod3.net/log?id=5b2c2d8cd10b430873d738e1 i'm going to flash the stage 2 93 tune and test later tonight. Last edited by designatedposter; 06-22-2018 at 09:52 AM.. |
06-23-2018, 03:16 AM | #120 |
Rep 1,466
I might be wrong, but I think you need to get more logs. I've seen some people get logs for 3rd, 4th and 5th gear pulls, which is great for a long hard pull, but it's difficult to repeat because it's so fast.
In the past, I've seen logs from SeanWRT that were multiple third gear pulls back to back. I find it difficult to do straight back to back pulls, but I can get 6 or 7 third gear pulls in about 10 minutes. With that many pulls you can get an idea of consistency. If you look at some of my bad logs earlier in the thread, you'll see that sometimes one of my 6 pulls is perfect, even though later or earlier pulls are a mess. Consistency is important, and you cannot tell that from only two pulls in a session.
2018 ///M2 LCI, LBB, 6MT...
06-23-2018, 05:52 AM | #121 | |
Rep 4,203
Example when I dyno'd my car suffered low power due to heating up. So when doing 3rd gear pulls the temp would actually drop then barely return to where it started by the time the run was over and that is great for vendors to advertise this but in the real world you really don't use that. when you get deep in a 4th run is when the load is long enough to test damage control of the support parts FMIC/HPFP and by the time your in 5th this is where most failures are in my opinion. That is why I always post 3/4/5 independent runs then a 3/4/5 shift to see component recovery. That is just my experience from the past 3 cars, not to argue any other opinions. The last 3 BMW's I have had that were piggybacked or tuned always had issues in 5th. mainly do thirds to get the component heating process going to really see what is going to happen on the 4th 7 5ths |
06-23-2018, 08:37 AM | #122 | |
Rep 2,577
IAT and ignition would suffer more as gear goes up. Boost curve would be a little different too.
Though HPFP stress would be the same if not lower due to thinner air out of higher IAT. Quote:
Lemania 2320
06-23-2018, 08:43 AM | #123 |
Rep 1,466
I think you both (SeanWRT & m2ruder) missed my point. I wasn't being critical of 3rd, 4th and 5th gear pulls, on the contrary, I think they provide additional information that 3rd gear only pulls may not provide. I'm therefore basically in agreement with you both.
My point was simply that one or two logs only may be missing something, particularly if your two logs aren't identical. If you get one good and one bad, how do you know what's going on? You need to get several logs in similar conditions to get a sense of what's 'normal' behaviour for your engine in those same conditions (ambient temp, map, fuel etc.), and two logs may not be enough to do that.
06-23-2018, 01:49 PM | #124 | |
Rep 4,203
07-02-2018, 09:10 AM | #125 |
Rep 643
I finally confirmed that i have an octane issue, and not a hardware issue.
Whilst investigating this octane issue with local fuel in central Connecticut, i still had some concern that it could also be hardware issue since i exhibited similar timing pull with new jersey fuel. I had the chance to fill up with Mobil 93 in northeast Pennsylvania and the logs show it all. Perfect timing. This confirms that my local fuel is not up to snuff and even the so called 93 octane does not exceed 91.. logs of stage 2 91 octane tune n55 ewg m235i 93 octane Mobil fuel from northeast PA http://www.bootmod3.net/log?id=5b38d5ced10b437334792d1e http://www.bootmod3.net/log?id=5b38f27ed10b437334792d38 http://www.bootmod3.net/log?id=5b38f3aed10b437334792d3c http://www.bootmod3.net/log?id=5b396bd9d10b437334792dc5 so... who has heard any updates on the ACN 91 tune from PTF? This is a tune specific to the low quality fuel such as california |
08-06-2018, 02:20 PM | #126 |
Rep 643
Looking for feedback on this HPFP crash at 4800 rpm. I just switched to the M2 stage 0+ map and have been liking is so far, but on a 3rd gear pull I felt like I hit a wall and car was burble’ing whilst WOT. The log shows HPFP issue at 4800rpm. What do you guys think? is this a fluke or do i have a hpfp issue? running shell 93 octane, no additional ethanol.
also, stage 2 91 octane maxed at 14.7 psi, this m2 map is quite a bit higher at 17.. is this normal? http://www.bootmod3.net/log?id=5b670cccd10b431620dbbe6c m235i catless DP FMIC HPFP: crashing at 4800rpm Timing: terrible Boost: 17 psi max |
08-06-2018, 03:11 PM | #127 |
Rep 244
Here is a 3-5 gear log on Bm3 stg2 ots tune. Timing seems to be all over the place.
http://www.bootmod3.net/log?id=5b33c40dd10b4310d12e1420 Here is similiar log with Enzo tune http://www.bootmod3.net/log?id=5b4460bad10b437911b1c9e6 If anyone here is interested to look at these, what do you think? With Enzo timing atleast seems to be much cleaner. |
08-07-2018, 01:29 AM | #128 |
Rep 931
Your BM3 log looks good to me but Enzo one seems pretty bad. You have boost overshooting target and your throttle closing quite a bit in the Enzo one. You don’t have these happen in the BM3 log. Maybe try a different gas station next time but to be honest from all I’ve seen its just inevitable on just pump gas to have timing move like that here and there.
08-07-2018, 02:45 AM | #129 | |
587
Rep 898
Run the 91 stage 2 OTS.
SeanWRT3179.00 designatedposter175.00 |
08-07-2018, 02:48 AM | #130 | |
587
Rep 898
However the ENZO tune is simply too aggressive for the guys car in that climate.
SeanWRT3179.00 |
08-07-2018, 05:39 AM | #131 | ||
Rep 643
M235i rwd 6mt
08-07-2018, 10:49 AM | #132 | |
Rep 244
By "that climate" you mean it *could be better if it was colder? Those temps are very rare here where i live. |
