02-19-2022, 05:59 AM | #23 | |
Rep 7,470
Now on a side note: Decreasing gap size to stop spark blow out is imo a boot leg ghetto trash solution (to out things as harshly as possible, sorry but this is how I feel) to solving the spark blow out issue. what really should be done is upgrade the coil packs to be able to deliver more spark energy so the gap doesn't have to be closed despite the increase in power. That's the real proper solution, however sometimes this isn't justifiable for the cost vs. gap size requirements. For instance going from stock 0.028' to 0.026" isn't what I would call dire enough to justify upgrading coils but if you want to do it by the book then yes any time gap size needs to go down coils should be upgraded if upgrades exist. Any smaller than 0.026" and I would start considering it mandatory, I would never let the gap get to 0.023" because at that point I would consider it neglecting proper supporting mods.
kthor70348.00 |
02-19-2022, 02:24 PM | #24 | |
Rep 7,470
Ok let me explain it in another way. The ideal gap is to be as large as possible and around 0.028" set by BMW. The fact that the car is turbo charged has little to do with gap size you still want to maximize it. Closing the gap has no real benefits and is only done when you don't have coil upgrades or you're making insane 1k whp and have no choice. So you always want the largest possible gap, regardless of NA or turbo charged. An analogy is you're wearing sun glasses on a bright day allowing to to have your eyes fully open, and it gets brighter youre still able to keep you're eyes wide open. But at some point when it gets too bright you begin to squint (when hp increases eventually you close the gap). Eventually if it gets too bright you squint so much that you can't see anymore. Why would you keep squinting instead of buying darker glasses. Squinting is only a temporary band aide to the real problem. Just like Conti using to gap down is just a band aid, upgrading coils is better.
03-29-2022, 06:40 PM | #25 |
Rep 1,243
Drives: 2017 Big Turbo BMW M2
update : I had a few leaky injectors and just replaced all the injectors to OEM and literally 10 minutes from leaving the shop, the car had a CEL pop up. When it popped up, I was in a middle of a pull and the car dropped its power and RPMs, while foot still on gas and then shot up. (in total 3 times, foot still on gas). Car was fully warmed up, half tank, and half traction on. (maybe that's why?) As well, when warm starting the car there still minor pulsing going on with the idle bobbing up slightly once after startup. After arriving home, I checked for codes and I had was an exhaust valve code that I cannot clear and a non-available code. I went to clear the codes and reset adaptations and notice they didn't select "OEM injectors" on the tune file. I am going to reflash the tune and see if that helps and reset adaptations again. I have now replaced spark plugs, coil ignitions, and now injectors, I'm not sure why the idling still acting funny. If anyone knows how to help please let me know
03-29-2022, 06:47 PM | #26 | |
Rep 7,470
03-29-2022, 06:52 PM | #27 | ||
Rep 1,243
03-29-2022, 07:36 PM | #28 | |
Rep 7,470
I believe you have to register it with the flow ratings on the side of the injectors.
03-29-2022, 08:01 PM | #29 | ||
Rep 1,243
F87source7309.00 |
03-30-2022, 07:27 AM | #30 |
Rep 1,243
cold start this morning was perfect, no misfires or codes, 0 pulsing, and the cold start seems less aggressive on initial start up. car seems fixed now and running perfect
F87source7309.00 |
07-24-2022, 07:06 PM | #31 |
Rep 34
I have a pulsing, choppy idle at the moment. On e85, too. I replaced my cyl 5 injector like the scanner indicated. Only at idle, though. Fbo and gapped to .22. I had the pr ignition coil kit and when I removed it to use the stock coils it pulled much harder up top. Just don’t know if I have another possible bad injector like you?
07-24-2022, 11:08 PM | #32 | |
Rep 1,243
my shop and tuner have been data logging the car and working on small adjustments to the tune. we also recent found out that I had a small leak and a crack on my boost valve so they are currently getting new vacuum lines and replacing my boost valve. as for before, when on 93 and replacing the injectors, the car warm started completely normal. my turner checked all the injectors when data logging and nothing seemed off. I'm hoping the rough startup goes away once picked up but I think it's normal for ethanol (as what I heard) |
08-04-2022, 01:33 AM | #34 |
Rep 1,243
08-04-2022, 02:41 AM | #35 |
Rep 7,470
I'd suspect if the o2 sensors were on its last legs there would be afr flucctuations everywhere in the rpm band along with roughness.
08-04-2022, 03:13 PM | #36 | |
Rep 1,243
08-05-2022, 05:22 AM | #37 |
Rep 3,703
So, I also am now having a pretty rough idle that every now & then throws a mixture too rich code. I assume the code is a by product of the rough idle and either injectors, plugs, O2, etc, could be the issue.
The car runs absolutely phenomenal around town and at WOT. It’s just a new bad idle for some reason. Have reset adaptations several times, tried 93 vs E50, no impact. |
08-05-2022, 05:39 AM | #38 | |
Rep 1,243
08-05-2022, 06:03 AM | #39 | |
Rep 3,703
https://www.bootmod3.net/log?id=62ec...729b2d5d51f8d2 |
08-05-2022, 01:53 PM | #40 | |
Rep 7,470
shaneguags1196.00 |
08-05-2022, 02:20 PM | #41 | ||
Rep 1,243
08-05-2022, 02:40 PM | #42 | ||
Rep 1,243
08-05-2022, 03:06 PM | #43 |
Rep 7,470
If your pi injectors are e85 rated then chances are no, but I'd still run top cylinder lube or run a tank of pump gas between every few tanks of ethanol to clean everything up. Especially if your car sits alot. Fuel system cleaner before every oil change helps too.
shaneguags1196.00 |
08-05-2022, 03:14 PM | #44 | |
Rep 1,243
