10-24-2023, 04:45 PM | #1 |
Rep 28
Engine flutter at track
Was at Chuckwalla Raceway this past weekend. Was super hot, 105f. I can only assume 15-20 degrees hotter on track. Im not sure if the issue I was having has to due with the heat but I’ve seen many people upgrade their intercooler and heat exchanger, claiming this area to be a short coming of the stock S55 platform. Before I make the purchase I’d thought to get your opinions first.
Coming out of a corner on heavy to full throttle, the engine felt and sounded like a flutter or bogging with no increase in power. I’m not sure how else to explain it. I’m not sure if it’s something to due with the heat soak effecting the turbos or maybe possibly a fueling issue. (Never below a 1/2 tank.) Or Maybe a turbo leak? It would happen randomly at different parts of the track but always on heavy throttle at high rpm, 6500 and higher. Sometimes it was short, 1/2 second, others it went as long as 2 seconds, then the power would slowly kick in. No error codes reported. Has any one else experienced anything like this? Engine Mods: BotMod stage 2 tune Eventuri intake and charge pipes Turner oil catch can Pedal Comander Catless down pipes Catless, non-resonated Eisenmann race exhaust |
10-24-2023, 05:40 PM | #2 |
Rep 557
Was it a right hand corner and were you low on fuel? Sounds like it may be breaking up from fuel starve which is a known issue when running with low fuel due to location of pickup.
Also, it’s hilarious you’re using a pedal commander. Aren’t those marketed for V6 Dodge Chargers? |
10-24-2023, 06:18 PM | #3 |
Rep 28
We were going counter clockwise so mostly left handers but, yes I do remember two very distinctive right handers where it happened. I was trying to maintain half a tank through out the day by adding fuel in-between sessions. It may have gotten to 1/4 tank, or maybe a smidge lower. Would that have done it?
Ha, funny you say that about the pedal commander. I had one on my Mustang GT and liked it so much, I put one on the M2C almost 2 years ago. I completely forgot about it until now. |
10-24-2023, 06:35 PM | #4 | |
Rep 5,728
Drives: 2019 M2 Competition
10-24-2023, 06:53 PM | #5 |
Rep 28
10-24-2023, 07:36 PM | #6 | |
Rep 557
If you’re running hard in 100*+ ambient temps an upgraded intercooler is probably welcome. |
10-25-2023, 01:15 AM | #7 |
Rep 1,977
Drives: 2020 M2C HS & Ferrari Roma
I've experienced this at the track when I was low on fuel! especially on a high G corner. Car seems to like it the most at half tank.
2020 M2 Competition | Hockenheim Silver | 437M Wheels / 763M Wheels | RHD | 2NH Brakes OEM M2 CS Steering Wheel | MP Carbon Steering Wheel Trim | MP Pedals | MP Dash | MP Interior Kit OEM M2 CS Bonnet | M Performance Coilovers | MP Rear Spoiler | MP Rear Diffuser| Perl Carbon Front Lip | Remus Race Exhaust |
10-25-2023, 11:00 AM | #8 |
Rep 5,728
10-25-2023, 06:22 PM | #10 |
Rep 28
10-25-2023, 06:24 PM | #11 |
Rep 28
10-25-2023, 11:32 PM | #12 |
Rep 1,335
Neither due to heat nor due to low fuel level, an engine does not flutter, due to excess torque / excess back pressure yes.
10-26-2023, 12:54 AM | #13 |
Rep 699
This sounds like high IATs may be causing misfires and the car is pulling timing/boost. Next time you track get some datalogs.
2021 M2C HS DCT
2007 Wedge 335i E92 FBO, Stage 2 LPFP,VTT STG 2+, VTT Shotgun E50 w/ Inlets MT-SOLD |
11-07-2023, 03:15 PM | #14 |
Rep 22
11-07-2023, 03:42 PM | #15 |
Rep 5,728
Yeah i know, just never did or heard about it there. I think i'd prefer the usual clockwise but i'd have to try it.
11-08-2023, 03:38 PM | #16 |
Rep 407
Had a similar problem with my F80 back in 2017 in the midrange of the RPM on full throttle. I had 2 issues that got fixed at once so unfortunately unsure what the source was but I'll mention both for your consideration.
Issue #1: Charge pipe. I also had an upgraded charge pipe and found it to have a small leak so I reinstalled with new fittings and it better sealed the pipe. Issue #2: Map. I was running an OTS E30 blend map and after discussing with support, came to the conclusion that the map was outdated and inefficient based on my engine, transmission, and location combination. E30 blend is important to note as it leaves room for user error, unrelated to the map itself. Hope this helps. |
11-13-2023, 12:50 PM | #17 |
Rep 139
Drives: '20 BMW F87 M2C
What settings are you using on track? MDM, full nannies off (DSC off, etc.)?
With the nannies on, this car will purposely cut power mid-way through corners if it feels like there's not enough traction, etc. |
11-16-2023, 01:54 PM | #18 |
Rep 1,328
