06-05-2019, 08:48 PM | #1 |
Rep 131
18x8 wheels fit on M2C? (for winter)
I'm kicking around the idea of trading in my 17 M2 for a new M2C, but I'm curious whether I'd be able to use the same winter setup: a square setup with 225/45 tires and 18x8 wheels. I'm sort of suspecting that with the bigger brake assembly I'd be out of luck, but anyone know for sure?
06-05-2019, 08:57 PM | #2 |
Rep 392
Drives: 2019 BSM M2C
18” will not fit M2C due to larger brakes. The 19” barely leaves any clearance. It’s so tight in the front, that a small pebble will get lodged and leave a circular streak in the rim. Happened to me in the first 400 miles.
06-05-2019, 09:05 PM | #3 |
Rep 1,017
Have you seen the clearance on your 19inchers ? Lmao pull one of your wheels off and look at the gap between the wheel and the caliper.
I would bet that most 19" wheels won't fit |
06-06-2019, 11:01 AM | #5 |
Rep 2,277
Hey fam, because of the brake package, these are the only wheels i know that fit on a M2C. Good luck.
Present: 2023 M2 BSM W/Carbon everything, 6 Speed
Past:2020 M2C HS Executive, 6 Speed |
06-07-2019, 11:59 AM | #6 |
Rep 74
