08-01-2020, 10:46 PM | #23 | |||||
Rep 2,672
08-02-2020, 03:25 AM | #24 | |
Rep 1,759
cptobvious2531.50 |
08-02-2020, 06:25 AM | #25 |
Rep 3,337
cptobvious - there's a term tire engineers refer to as "mixability." Every tire design obviously has its own range of performance metrics, and a few of those can be very important to the stability of the car such as ultimate grip (clearly) but also as important is the cornering force versus slip angle response of the tire. Without reasonable balance, front to rear, of that tire response equation, transient inputs (turning into curves, making quick corrections, etc) can seriously be degraded even to the point of serious instability.
Taken to an extreme to illustrate -- put a PS4S on the front and the cheapest possible all-season junk tire on the rear; you can fill in the blanks = massive oversteer at steady state limit, plus huge gooey oversteer response to transient steering inputs, etc, etc. Anyway, just wanted to point out "mixability" -- tire engineers have a database for their company's tire's performance envelopes to be able to quickly tell if they can be "mixed" on the front and rear of a vehicle, reasonably. As to mixing brands of tires, they wouldn't yield an opinion as it would just be educated speculation, but the general reply would be to put the junk tire up front (just to keep the average person clearly in the understeering regime no matter what).
Current Stable:
2024 G20 M340i Melbourne Red/Cognac 2019 F87 M2 Competition 6MT, LBB, slicktop, exec pkg 2007 E91 328i Silver, slushbox, Eibach fr/E93 M3 rear sway bars, ARC-8 Last edited by CSBM5; 08-02-2020 at 06:33 AM.. |
4
08-02-2020, 09:35 AM | #26 | |
Rep 825
You know, this makes perfect sense, and seems to mirror my exact experience. Per omasou and VisualEcho, getting the larger rear tires resulted in rake, which then threw off the DSC. I mean, right out the gates, the car just felt totally off - weird jitteriness. And I realize it now, it's the exact same feeling as when the nannies kick in. But, now, after several days of lots and lots of driving, the car seems to be back to totally normal. Now, I wouldn't be able to tell the difference if you had me drive the two "setups" back to back. Learn something new everyday! |
///AVM2529.50 VisualEcho6636.50 |
08-02-2020, 09:55 AM | #27 | |
Rep 3,006
Which them confuses me as to why everyone get so stressed out about front to rear ratios every time there's a tire discussion? Also do you know why this doesn't this help w/all-wheel drive systems? I forget the situation but I needed some new tires on the E70. The rep told me for the all wheel drive (not the OPs situation) that I could only have a certain difference between front and rear or that I could break the drive train. Though he was BSing me until I researched it a bit. https://www.tirerack.com/tires/tiret....jsp?techid=18 Which of course raises the question. How do high performance cars, Porsche and now BMW M cars w/all wheel drive not have problems? One would think the rears on these cars are worn significantly more than the fronts and exceeding the limits discussed in the article? |
08-02-2020, 12:35 PM | #28 | |
6637
Rep 4,145
Drives: '18 M2 6MT
I know on the Lotus, if the OD of the rear is too big, or the rake is negated with a larger front OD, the car can go into limp mode pretty easily. And as far as the ECU learning, that happens as well. Let's say you add a Cup car airbox and decat. Without a professional tune to tell it otherwise, the ECU will negate the hp gain. Crap, but true. I think some guys have experienced issues and word gets around, and without proper knowledge of what caused those issues, many are left just guessing as to what caused them. From what I've seen, the M2 is quite tolerant of width and OD differences. |
08-02-2020, 02:31 PM | #29 | |
this is the way
18149
Rep 8,527
2. I've played with dropping PSI, never increasing it. Depending on how low you go you can get ever so slightly more comfort, but it's not day and night. With lower pressure you will lose some handling. 3. I think it's more or less how quickly it looses pressure rather than just +/- a few PSI. You can easily go +5 PSi or more just from warmer temps and aggressive driving. |
///AVM2529.50 |
08-02-2020, 02:37 PM | #30 | |
Rep 3,006
08-02-2020, 02:38 PM | #31 | |
this is the way
18149
Rep 8,527
Made this post a while back, but think it's worth repeating in this thread. It was part of another thread cptobvious made. He also made the mistake of referring to us as "Esteemed colleagues" in that thread instead of just opening with, "Hey, aholes".
08-13-2020, 12:44 PM | #32 | |
Rep 151
I'm going to try to have coilovers, camber and track wheel/tires done over the winter. I am hoping to move up to 265f/285r with that set up on some stickier tires. I think this car is under-tired stock, so I am anxious to try this setup. Does anyone's PSS's squeal when they lose traction? Mine are silent when the rear end steps out. |
cptobvious2531.50 |
