08-02-2022, 07:48 AM | #23 | |
Rep 1,657
1995 LTW: Modified by BMW NA Factory team from new
M2 CS: CF Buckets & more (track toy) |
08-02-2022, 11:29 AM | #24 |
Rep 4,672
I think what's going on is the comp has a computer mounted to the chassis with a hard mount and the CS uses a janky hard foam case that just sits in there wedged between the other hardware. I'm guessing the floor passthrough ports are also in a slightly different spot because the don't seem to match the location on the Akra instructions.
08-02-2022, 09:30 PM | #25 |
Rep 4,672
Success! There are some differences in the underbody heat shielding that mad things a bit confusing. I thought the instructions suggested I should pass the connector plugs down through the hole in the floor. I unplugged everything and fed the wires up because the hole was too small. Wish I had that thought yesterday. I connected it to the stock exhaust. Sound change is significant from valves closed to open.
ptgltw3777.50 |
08-03-2022, 07:54 AM | #26 | |
Rep 1,657
08-03-2022, 08:23 AM | #27 |
Rep 4,672
I'll try to grab a soundclip of stock exhaust with valves open vs closed, and then with akra. I'll record it during the warmup because it's very dramatic. I can't wait for the Akra to be installed. Poking around with the valves open on the stock exhaust has already added to my enjoyment.
08-03-2022, 11:19 AM | #28 |
Rep 4,672
I listened to the soundclip on the Akra website with the catless downpipes. It appears to be the sound I'm ultimately after. Shame it would require a tune to delete CEL.
08-03-2022, 03:38 PM | #29 |
Rep 1,657
Too loud Dave. You and I are old, we don't need that.
08-03-2022, 08:43 PM | #30 |
Rep 4,672
https://photos.app.goo.gl/cNWdS3RNy3MyDihc8
Edit: video no worky This proves to me how nonsensical it is to record exhaust sound. Video presents as very little difference. In person it's a dramatic difference. Makes me even more excited about the exhaust. Last edited by medphysdave; 08-03-2022 at 08:50 PM.. |
08-03-2022, 09:31 PM | #31 | |
Rep 2,203
Drives: G81 M3 Touring (Frozen Black)
08-04-2022, 05:40 AM | #32 | |
Rep 327
I didn't feel like dismantling my entire trunk interior on a brand new car. As previously posted in the thread, this is a 20 minute solution that has worked flawlessly for me so far. It also provides more control. Well worth the money. Review Of CG Precision VSC-2 Variable Sound Controller (Exhaust Valve Controller) https://f80.bimmerpost.com/forums/sh....php?t=1099274 |
08-04-2022, 06:02 AM | #33 | |
Rep 4,672
08-04-2022, 08:14 AM | #34 | |
Rep 77
08-05-2022, 05:51 AM | #36 | |
Rep 327
I can not confirm if the Akrapovic sound kit functions differently than the simplicity of the VSC-2 to provide sound in a different way. These are the directions for the Akrapovic installation. https://www.mtk-tuning.com/media/doc...nd_kit_M2_.pdf These are the directions for the VSC-2 installation. https://speedindustry.com/images/upl...Guide%20v3.pdf The VSC-2 installs entirely underneath the car and receives power through the existing factory valve control harness. You simply mount it and then connect the 4 plugs to intersect the existing harness. Tuck the wires properly and that it. The remote then opens and closes the valves based on your preselected settings prior to the unit shipping. Then as previously posted you can integrate the wireless functionality into the home link system. |
08-05-2022, 07:59 AM | #37 |
Rep 4,672
I was receiving assistance from Turn14 on my installation. I asked about the functionality of the Akra controller. They replied that it is an on/off function. I can't find the reference to what I was mentioning earlier.
08-05-2022, 03:08 PM | #38 |
Rep 327
If this is the case it doesn't seem worth your time to dismantle all of the trim from your trunk versus 20 minutes of working underneath the car with the VSC-2
08-05-2022, 06:25 PM | #39 |
Rep 4,672
The trunk dismantling was super quick and easy. Their instructions were excellent. If you ever need to get deep into the trunk download the link pipe instructions from the Akra website. It includes the soundkit install instructions.
08-16-2022, 07:13 PM | #40 |
Rep 4,672
Holy, the CS exhaust has character, batman. Sport+ hides pops and burbles in that muffler. Akra evo system installed. I'm really impressed. Sounds nothing like any of the videos. Nice rumble down low, and then gets the higher pitch that I've been wanting as it starts going above 4500 rpm. There's a bit of drone, to my ear, right around 2800. It's not unpleasant to my ear. Stock exhaust is waaayyy bassier at idle. Stock you kinda feel rather than hear. Valves open or closed the Akra is super quiet at idle. But give it just a little rpm and it gets much louder very quickly. Warmup idle is much louder than stock.
Akra is funny because they don't seem to let you adjust the exhaust tips in or out. Only the pivot angle. Gotta keep that Akrapovic advertising visible. I would have preferred them tucked a bit more lock stock, but they look really good like this.
F87EVO4033.00 |
08-16-2022, 08:56 PM | #41 |
Rep 1,247
2020 BMW M2CS HS 6MT
2022 Audi RSQ8 |
08-16-2022, 09:08 PM | #42 |
Rep 1,657
Congrats Dave. I pick mine up at the end of the week. I'll give a full report this weekend.
I'm assuming it only enhances the driving experience.
08-17-2022, 12:10 AM | #44 |
Rep 3,072
I'm pretty happy with the sound of the CS stock as long as the windows are open. It's very BMW.
I did just get the secondary cats replaced with Quicksilver de cat pipes on the AMR though. This video is a very accurate recording. So that's how I get my emotional exhaust insanity fix. It's nice to have both options depending on mood. |
