03-24-2022, 12:00 PM | #1 |
Rep 855
M Performance HAS or H&R
Would like to lower the CS a bit and would love thoughts from anyone who may have experience with the M Performance or other HAS kits on our cars with EDC suspension. I track 1-2 times a year so not a huge factor. I prefer not to lose EDC function so not really considering coilovers. Lucky enough to have TC Kline’s shop in my backyard so if I were, I’d probably use his.
TC can order the H&R HAS kit which apparently is made for EDC F8X cars. Similar price to M Performance. Details on changes to ride quality, handling, etc would be much appreciated! |
03-24-2022, 12:45 PM | #2 |
3024
Rep 13,763
I have MP HAS and comfort is a bit more compliant, but still enjoy it on a regular basis while I've used Sport+ on the track and felt it was more than capable to handle the task at hand. Can't say more than that since I'm no technical wizard when it comes to suspension, but I also didn't want to lose EDC and don't regret going with MP HAS
~loud noises~
Got f1?681.00 |
03-24-2022, 02:15 PM | #3 |
Rep 901
Drives: 2018 M3 Competition
The owner of my shop which has no less than a dozen Porsches and 3-4 full track cars on any given day talked me into going with the regular H&R sport springs. He said if I'm not tracking the car regularly I'll never notice the difference on the road.
Very happy with the result and the stance is great. The handling feels like stock, I remember thinking it felt a bit more stiff initially but now it just feels normal. I'm sure both HAS kits are great as well, and the cost over the sport springs is not significant especially once you factor in install labor and alignment. They only reason to go with coilovers is if it's going to be tracked a lot or if you are going for a super aggressive stance. Going too low will likely actually negatively affect handling, then you need to go with camber plates and leads to more issues. Been there, done that. Good luck and keep us posted with the results. |
03-24-2022, 06:23 PM | #4 |
IG@i.am.wah
2779
Rep 3,815
Drives: M2 CS
I've read on the M3/M4 forums that even H&R recommends the MP HAS kit if track is not your primary focus. I pulled my MP HAS kit from my M4 and installed it on my M2cs so it was an easy decision for me.
03-24-2022, 09:46 PM | #5 | |
Rep 332
Drives: 2018 BMW M2
03-24-2022, 10:18 PM | #6 | ||
BMW Enthusiast
440
Rep 258
Got f1?681.00 |
03-25-2022, 07:18 AM | #7 |
Rep 855
Found this comment on the thread below:
“Both are made by KW. The difference is in the engineering - people rave about the MP HAS kit because it's very clear it was designed and engineered specifically for the car and transforms the adaptive suspension to something it should have been from the factory. The KW HAS kit is good too, but it seems to be a bit more harsh and less refined, which is likely due to far less attention to suspension engineering and more towards getting the car lower.” https://f80.bimmerpost.com/forums/sh...erformance+HAS |
03-26-2022, 06:55 PM | #8 |
Rep 115
I'm on H&R adjustable springs.
If you have good roads, the ride is similar to OEM. My biggest issue with the springs is that they don't handle dips well (especially at high speed). My guess is that the OEM dampers don't have enough travel with the car being lowered. I will probably go full coil over soon. |
03-27-2022, 04:25 PM | #10 |
Rep 375
03-27-2022, 07:29 PM | #11 |
Rep 855
03-30-2022, 01:12 PM | #12 |
Rep 3,604
My $0.02 (skip to last sentence for the direct answer to your question ): having lowered my last F82 w/ adaptive dampers on springs (MP HAS) I won't be doing it again. The OE shocks just can't cope with it over time. Sure it will feel great right away on a young car, but your ride & damping quality will degrade quicker over time. Keep in mind, these dampers are nearly a 10 year old design at this point - M2CS doesn't have anything proprietary from a suspension hardware perspective. The whole point of the CS is that it is the most optimized all rounder from a suspension perspective, and suspension travel has a lot to do with it. If I am to lower again it will be on a proper coil over setup with a shock that's designed to operated at lower ride heights. I'd also consider a diff mount and adjustable arms as when you lower with only springs, you are changing the suspension geometry (for better or worse).
That said, if you really want to pursue springs, then MP HAS would be the way to go given it is approved by BMW using BMW specific spring rates.
Current: F80
Prior: F82, F32 |
03-30-2022, 05:41 PM | #13 | |
Rep 901
Race springs available for other cars that drop it 5-7cm is another story. You can tell when a dropped car is bouncing down the road it's too much for the suspension to handle. The only 2 things visually I don't love on the stock CS is the saggy exhaust and the wheel gap. The exhaust doesn't bother me enough to change it out since it's under the car. The wheel gap is an easy solution. Just personal preference. I agree if you want it lower and are going to be tracking it, go with coilovers. |
04-13-2022, 03:28 PM | #14 | |
Rep 27
04-27-2022, 12:02 PM | #15 | |
Rep 888
Instagram : @gc.g80brg
2023 M3C Xdrive British Racing Green 2009 M3 Alpine white DCT 2001 M3 Laguna seca 6 speed |
04-27-2022, 01:08 PM | #16 |
3024
Rep 13,763
So far so good. With weights close enough to an F80/F82, I don't think it's going to be drastically bad on the CS. Probably a solid 10k miles on them.
~loud noises~
06-14-2022, 02:04 AM | #17 |
Rep 77
Can someone help me out here. I'm currently looking at MP HAS system (I have H&R lowering springs on, but would like to go OEM due to warranty and resale). Does anyone have the part number for MP HAS system which fits the M2CS?
08-15-2022, 02:14 PM | #18 |
Rep 296
08-15-2022, 02:29 PM | #19 | |
BMW Enthusiast
440
Rep 258
https://ind-distribution.com/product...-m4-suspension Get the hardware kit as well. I installed it and love it You can find it cheaper: https://www.bmwpartshub.com/oem-part...on-33502414216 |
08-15-2022, 02:32 PM | #20 | |
BMW Enthusiast
440
Rep 258
frostyrides311.00 |
08-15-2022, 03:03 PM | #21 |
Rep 858
Drives: F87 M2CS
Anyone getting clicking noises in the front wheel when turning in parking lots after lowering? Mine came with kw has and on the test drive I didn't notice it but now it's annoying. The Bilstein on my m4 did it too but not to this degree
MY18 F82 M4
Austin Yellow / Black / DCT / MPE |
08-15-2022, 06:12 PM | #22 |
Rep 3,806
Reddevils7981.00 |
