06-13-2022, 10:35 PM | #23 |
Rep 2,819
Drives: e82 1M, f87 M2cs
I have a chip or two on each black wheel, seem to notice a new one every couple months. Fortunately the black is easy to touch up, just haven't gotten to it yet. They are very visible due to the white under layer.
06-14-2022, 11:23 AM | #25 |
Rep 901
Drives: 2018 M3 Competition
I have a couple very small dings on my wheels from rocks, but nothing that took the paint off yet.
4,500 miles. Not sure if running PSS tires has helped me avoid anything major. |
06-14-2022, 02:21 PM | #26 |
Rep 1,078
Let me know what you use to touch up!
09-06-2022, 02:36 PM | #28 |
Rep 4,672
Bumping this up. Curbed a rear wheel. Short story is that the curbing is easy to fix. No one wants to touch matching the color. I'm being told that the whole wheel would need to be stripped and redone, but then that wheel would likely not match the others.
My thought is that a close match would be better than leaving exposed curbing, but it's not a super obvious where the curbing is located. I still believe their must be a solution that doesn't include buying a new wheel. At this rate it would have made sense to buy the BMW wheel insurance. My next step is to see what the local bmw dealership's in house wheel guy says.
romes4rs81.00 |
09-06-2022, 03:17 PM | #29 | |
The Seeker
13863
Rep 3,325
Keep in mind that SAI can't even match the finish themselves, evidenced by buying a single new wheel here or there and finding them to be very mis-matched, which is why they make them in huge batches. If someone had been found to be able to match this paint correctly the BMW board would know about it for sure. |
MadBimmeRad7121.50 |
09-06-2022, 10:41 PM | #30 |
Rep 4,672
I've reached out to BMW to float the idea of a factory swap of wheels for a fee. BMW sends the dealership a refreshed wheel. We send damaged wheel back to bme for repair. Eventually the repaired wheels are used for customer swaps. Last thing I want is to collect a 763m wheel because I have to buy a new one each time one is curbed.
chris7197334.00 MadBimmeRad7121.50 |
09-07-2022, 03:44 AM | #31 |
Rep 7,299
I can’t believe they aren’t able to supply a paint code. The E39 M5 Chrome Shadow paint was like this and they eventually revealed the code and the Italian supplier. It’s one reason why I would get black 763M and repaint them because I would rather not deal with this situation. All of Porsche’s satin wheel finishes can be found in the Glasurit catalog so BMW needs to step up their game and provide paint codes or formulations for the critical parts. Eventually a decent sprayer can get it right, but they have to be spraying the same stuff or very very close.
///MPhatic13862.50 JoeMatt160.00 |
09-07-2022, 06:38 AM | #32 | |
The Seeker
13863
Rep 3,325
09-07-2022, 06:45 AM | #33 | |
Rep 4,672
09-07-2022, 07:43 AM | #34 | |
The Seeker
13863
Rep 3,325
Notice the color difference in the first and second pictures I've included. It's the same color, but the first wheel has much more gold on it (it's not just the lighting). If you could view these wheels side by side new you'd see that none of them match unless they were made from the same batch. Even SAI's MATTE BLACK doesn't match! And the last picture illustrates the satin silver base that doesn't even get sprayed in some cases because it's in the corner. This shows how it's not just the color, but the specific angle of the spray that dictates how dark/light the wheel will appear when finished (how much silver is showing through the painted areas, and how much silver is left in the corners). They just have no choice sir. |
09-07-2022, 11:03 AM | #36 | |
Rep 7,299
09-07-2022, 11:15 AM | #37 |
Rep 4,672
My dealership has a person that believes they can get it 90%. Based on what has been posted here I think that's the best anyone could hope for. It is clearly an approach of much more art than science. Also how much prep/testing the artist is willing to do prior to the repair. I'm not looking for perfect because it's a DD. Good enough that it's difficult to spot from 5ft is fine. Going through the dealership gives me a little recourse if it turns out poorly, and I get a loaner while it's in for repair.
$250 for the repair. I'd normally wait for a little more damage, but I'm super curious to know what to expect. 4 repairs = brand new wheel. |
///MPhatic13862.50 JPMD171.00 |
09-07-2022, 11:36 AM | #38 | |
The Seeker
13863
Rep 3,325
I do think that BMW has taken it a step further with the Frozen Gold though. I think Chrome Shadow and High-Power Silver are both nearly solid once finished, but FG isn't at all. It's the silver polishing that sets it apart, then the semi-matte clear final stage too. |
09-07-2022, 08:35 PM | #39 | |
Rep 7,299
///MPhatic13862.50 |
09-08-2022, 07:47 AM | #40 | |
The Seeker
13863
Rep 3,325
The reason I don't want to believe it is that I have quite a bit of experience with painting, and one of the things required is either scratches, or orange-peel, or special primer or something on the surface for the paint to stick to. It's super difficult to get paint to stick to a polished surface. Then again, SAI is a huge wheel company, so I guess they found a way. When these wheels first came out *I believe* there were darker versions, and less gold versions. If I could get the super light gold version I'd get them, but I think they are long gone. |
09-26-2022, 06:43 PM | #41 |
Rep 4,672
Wheel repair completed. In average lighting I think I was able to identify the repair when shining my phone flashlight on the wheel but not sure. I'd say that's a win. I think I noticed a change in gold metal flake in the repairs area. Very subtle. It could look different in direct sunlight. I think I'd wait for a few more blemishes next time before forking over $250, but I was curious. They did a great job
09-27-2022, 07:08 AM | #43 |
Rep 278
I just my first major imperfection show up on my jet black CS front wheel. It's on the driver's side so I stare at it endlessly. I am now between taking the wheels off (getting some Apex VS5-RS's in the new 20" group buy) to run while I own the car and either replace it the one front wheel or refinishing it and having them ready to go back on… Other option is just replacing the driver's wheel and then keeping it going as is. I also do have the notorious caliper wheel scratch in the inner barrel on both front wheels that I'd love to fix at some point, but know it's inevitable.
Hard to pass up getting 2 new front wheels (about $950 each) for eventual install but the Apex 20" group buy could put a new set of 5-RS wheels at $3200 shipped, which is compelling as they are still just a hair lighter than even the 763M's!
2020 M2 CS - Misano Blue, DCT, CCB
09-27-2022, 07:56 AM | #44 |
The Seeker
13863
Rep 3,325
///MPECABL582.50 |
