02-01-2021, 09:55 PM | #1 |
Rep 855
CF Hood Vent Trim
Has anyone been able to tell if this is easily removed? My PPF installer needs to know. I heard it (vent trim) scratches easily and would like it wrapped.
02-02-2021, 12:28 AM | #2 |
Rep 4,008
Drives: M235i, 420i, and now the M2 CS
I've heard the same regarding scratches whereby one forum member has used microfiber cloth and noted scratches.
I'm pretty sure medphysdave and ptgltw have had their hood vents removed You should be able to find references to these in the thread below Gloss Black Hood Vent Scratches Easily https://f87.bimmerpost.com/forums/sh....php?t=1794983
M2CS,
The second coming of ///M! |
02-02-2021, 06:47 AM | #3 |
Rep 1,657
Easily removable but not easily wrapped. Perhaps you can do it in many pieces or just the main areas that get wiped with a cloth. I would remove it, so your PPF under and then coat it with some ceramic coating.
1995 LTW: Modified by BMW NA Factory team from new
M2 CS: CF Buckets & more (track toy) |
MadBimmeRad7121.50 |
02-02-2021, 11:05 PM | #4 |
Rep 405
Yes - a couple of clips. Easily removed and replaced by someone competent.
02-03-2021, 03:39 PM | #5 |
Rep 1,657
A closer view of said part. It's going to very difficult to wrap. We just put some bomb proof ceramic coating on it and did a few hail mary's.
02-03-2021, 04:22 PM | #6 |
Rep 464
And for anyone really paranoid, guess you can buy a replacement and keep somewhere safe.
Should be one of these part numbers: Grate, hood Part Number: 51768081152 $133.52 Screen insert, hood Part Number: 41618081166 $61.40 |
02-04-2021, 06:57 PM | #8 |
Rep 374
Easy to remove, did it 2 days ago. Way easier than the grill.
03-22-2021, 08:13 AM | #9 |
Rep 547
For anyone looking into this, the correct part number is 41618081166 for the glossy black vent trim.
Mine is all scratched up from factory (maybe from dealer prep?), so I'm ordering 2 new replacements. They're on the cheaper side of BMW bits. 'Made in China' too, says mine. |
killerdeck354.50 |
01-11-2022, 08:39 PM | #10 |
Rep 1
Hey Guys,
Just wondering if anyone has purchased the Grate, Hood 51768081152 and/or Screen insert, hood 41618081166 Can you please take a provide me with the dimensions and take a photo of these, it could be of the part that is from your factory CS Hood. I wanted see if it would fit my Aftermarket hood. TIA!! |
12-04-2022, 06:36 AM | #11 |
Rep 858
Drives: F87 M2CS
How can I remove this plastic cover? For the longest time after I installed my exhaust I was getting a nasty rattle. I thought it was the passenger foot well until I got out of the car on startup and realized it's coming from the hood. I put my fingers thru the vent and pressed against the plastic grill and voila no more noise. Soon as I let go it comes back. You can't really see the plastic grill when looking thru the vent from the outside. I didn't wanna pull too hard on the tabs to avoid breaking it but was curious if anyone has suggestions on how to remove it. I want to apply some felt tape all along the edges and see if it fixes the noise.
Also, what's the downside of just leaving this screen off altogether? Is it to prevent water from seeping thru?
MY18 F82 M4
Austin Yellow / Black / DCT / MPE |
