View Poll Results: What is your exhaust setup & are you experiencing the raspy "tin can" noise issue? | |||
EL mid pipe (non-res) / stock axleback / no issue | 3 | 5.88% | |
EL mid pipe (non-res) / stock axleback / yes, my car has the same issue! | 16 | 31.37% | |
EL mid pipe (res) / stock axleback / no issue | 5 | 9.80% | |
EL mid pipe (res) / stock axleback / yes, my car has the same issue! | 3 | 5.88% | |
EL mid pipe (non-res) / aftermarket axleback / no issue | 6 | 11.76% | |
EL mid pipe (non-res) / aftermarket axleback / yes, my car has the same issue! | 7 | 13.73% | |
EL mid pipe (res) / aftermarket axleback / no issue | 4 | 7.84% | |
EL mid pipe (res) / aftermarket axleback / yes, my car has the same issue! | 7 | 13.73% | |
Voters: 51. You may not vote on this poll |
07-10-2021, 10:24 AM | #155 | |
Rep 179
-2020 M2Cs
-2020 GLS450 |
07-10-2021, 03:47 PM | #156 | |
~Spyder
638
Rep 870
Drives: '19 M2C Hockenheim 6sp
Any sound-clips? Do you have any raspiness < 2k rpm?
Skål från Sverige...via Texas y-all
07-10-2021, 04:58 PM | #157 | |
Rep 4
Mine exhibits all the same raspiness issues. Also, the polling system here is a bit broken. I mistakenly clicked and can't seem to change my vote. My cold start is embarrassing, especially when starting in a public parking lot. It seems to be ok sometimes after being warmed up, and other times I get that same rasp around 2k rpm. I think it's a misnomer that aftermarket exhaust help quell the rasp. I think folks who have aftermarket exhausts tend to like things louder. I just want a more refined sound. I wanted to get replacement parts to add the resonators to my setup to see if it helps. I've trying contacting AA a few times for this and other issues. My valves exhaust had some brackets that were badly bent and the right side exhaust tips are slightly angled towards each other so large tips touch each other. All that said, it sounds pretty good much of the time. It's just very much not refined and makes it feel a bit cheap. |
Driver87253.00 |
07-10-2021, 08:47 PM | #158 |
Rep 241
EL Non resonated and MPE and now a few weeks installed. no real issues to speak as called out on the forum. Super happy with the sound and have gotten a number of comments / compliments on the sound. last week a couple of guys flagged me down in a parking lot to look at the car etc. They said they heard me coming and thought it sounded GT3 ish coming down the road and surprised it was a S55 bmw etc. ( they were car guys as one had a nice RS3 and said he has a E46 he uses on the track). the sound from approx. 3 k and up is addicting and i spend a lot of time just rowing through the gears to hear the sound.. I dont think the EL and MPE have seen the issues called out and not sure if due to sample size etc. ( could be the $4500 price for the exhaust ) But i love the sound and think some of the best i have heard on Youtube etc. ( the M3 's that i heard with EL and MPE is what got me to change from the Single mid to the EL) i posted a few vids a couple weeks back on the forum and will try to get a few more soon with some open road and getting some higher revs and drive by. For the folks experiencing the sound and melting issues i hope there is a resolution that fixes and or at least mitigates the problem.
HomoPirate84.00 |
07-11-2021, 03:19 PM | #159 |
Rep 214
This is the vibration at 3k rpm, this video is actually from another person who has a similar set up. I guess this is just how it will be with this combo. Not sure if its as clear in this video, but theres a buzzz through the whole car.
https://youtube.com/shorts/Ye7tjpM1_RE?feature=share |
07-11-2021, 04:53 PM | #160 | |
3024
Rep 13,763
~loud noises~
07-11-2021, 05:24 PM | #161 | |
~Spyder
638
Rep 870
However, if purposefully try to rev the motor around 1,5k (and hover around it) I can pretty much reproduce the raspiness. As my mechanic confirmed, it seems to be caused my incompatibility between the now extra flowing midpipe (sans the OEM cats amd constrictors) and the OEM muffler/axle back. Adding some resonators 'should' help… I took a looong as$ video while revving the entire range: there are clear rasps as the RPMs are building up through 1,5-1,8k rpm. I will post it shortly. Please know this: once past 1,8k, the sound is glorious though…so this is definitely an improvement over stock, just want to minimize the low rpm raspiness. Nothing wrong with wanting to the make this as perfect as possible throughout the entire rpm range.
07-11-2021, 05:31 PM | #162 | |
~Spyder
638
Rep 870
Again, if I modulate the throttle and hover around 1,5k, I can reproduce it pretty easily. What is really baffling is that it doesn't happen EVERY time it hits 1,5k - for me it's about 70% of the time. When it doesn't- it sounds perfect all the way to redline. My mechanic thought it was a mechanical vibration whereas 2 pieces were resonating/hitting each other. But nope: nothing seemed loose - all was solid!
07-11-2021, 05:40 PM | #163 |
~Spyder
638
Rep 870
Well, on the fun sides of life: no luck for my nation, Sverige (Sweden) in Euro 2020 but the wife's family is sure happy…la famiglia della moglie è felice!!!
Viva l'Italia…que bella mascalzone! PS sorry for all English fans…I know you waited for a looong time
07-11-2021, 06:22 PM | #164 |
~Spyder
638
Rep 870
07-11-2021, 09:04 PM | #165 |
3024
Rep 13,763
Res with Akra
~loud noises~
07-11-2021, 10:56 PM | #166 | |
Rep 214
07-12-2021, 10:25 AM | #167 | |
24198
Rep 190,805
07-12-2021, 10:55 AM | #168 | |
~Spyder
638
Rep 870
I am going back & forth between ordering the AA valved axle back vs. Remus Sport. Given this thread: https://f87.bimmerpost.com/forums/sh...pe+Remus+SPort, it seems that there isn't any rasp reported with the single AA midpipe + Remus Sport axle back, so I presume that same will be applicable if we combine non-res AA EL + Remus Sport. By the same token, the AA valved exhaust doesn't look like it has any resonators...
07-13-2021, 07:16 AM | #169 | |
Rep 214
07-13-2021, 07:47 AM | #170 |
Rep 1,681
Sound really is so subjective. I heard a Remus Race with unresonated pipes this weekend and it is loud but in a good way. The setup belonged to forum member iWayne. A great guy who took the time to let me bother him. To my ears, it is definitely way louder than stock. It would be hard (personally) to use that setup and not code out burbles. Without burbles it has a great, deep sound in efficient but no drone and definitely has a head turning presence in sport/sport+. I think the Remus Race paired with either the resonated or nonresonated midpipe is the way to go if you want a presence in either driving mode. Efficient is mean but not over bearing but you can obviously tell its not stock. But like I said, you really have to like burbles or code them out because it can be too much for some.
I've also heard the AA axle back paired also with the unresonated pipes and it too is noticeably louder than stock but not as loud as the Remus race. In efficient it might be close to stock but in sport and sport+ it really is a different animal and is also capable of turning heads. The setup belonged to forum member AM///M2C who is also a great guy who also took the time to let me bother him a few times. I think this setup or the Remus Sport is the way to go if you want efficient to stay closer to stock and sport/sport+ to be the modes that come alive. Burbles are livable with this setup but I can't comment on this setup without burbles which gives it that extra presence.
Current: ///M2C
G01 X3 xDrive30i Past: ///M2 997.1 Turbo ///M3 E92 Last edited by Nicname; 07-13-2021 at 08:01 AM.. |
07-13-2021, 10:27 AM | #171 |
~Spyder
638
Rep 870
Gang: here is a revving session I took after a long drive
- F87 M2C S55 motor - non resonated AA EL midpipe - OEM downpipes and axle back exhaust - Drive mode Sport+ - coded burbles off (BimmerLink) - valves always open (BimmerCode) Suggest you listen with headphones...
Drew41561.50 |
07-13-2021, 11:13 AM | #172 | |
Rep 692
Vic
07-13-2021, 11:58 AM | #173 | |
Rep 1,681
1. Cold start has a loud "pop" at start up which made me smile but did also catch me by surprise. I can see it startling someone under the right conditions 2. It really does have an amazing sound. I would say borderline too loud for me specifically and my needs (single car for the household). If it was a tad bit quieter I'd feel extremely confident going with that setup. Again, this is just me and my current situation with the car. 3. No rasp that I noticed on either start up or accelerating. Windows up we could easily talk to each other. Even with windows down but I'm just making a point that there is virtually no drone. I believe he did mention some slight drone at a very specific RPM but said there was none on highway driving. I didn't notice. 4. Efficient mode sounds amazing. 5. For me, no burbles would be the way to go with this setup. I can see it being way too much to cruise around a quiet neighborhood.
Current: ///M2C
G01 X3 xDrive30i Past: ///M2 997.1 Turbo ///M3 E92 |
07-13-2021, 12:10 PM | #174 | ||
Rep 692
Vic
07-13-2021, 12:12 PM | #175 | |
~Spyder
638
Rep 870
All this is soo very true! Also wanted to give a HUGE SHOUT-OUT to Mike@x-ph and Andrew@Active: definitely fantastic individuals, representing awesome companies. Cliff notes of our conversations: - none of this 'raspy-issue' was by design, as the M2C test cars didn't exhibit during design and internal UAT testing - it baffles everyone why with the latest batch (June timeframe) all of the sudden this issue started popping up - there was no design or manufacturing change from the earlier batches - what is really even more of a head-scratcher, is that all of these issues: 1. occur at low RPMs, where there shouldn't be sufficient backpressure to create any unwanted internal vibrations 2. with Sport or Sport+ modes only. At least for me, Efficient mode doesn't exhibit this issue...which may lead to an OEM parts or tuning issue. So, yesterday, I ended up ordering a "resonator kit" for my non-resonated AA EL midpipe; I will install that in the next week or so to see if my raspiness/flatulence ~1,5k RPM gets resolved. Regardless, per Andrew & Mike, they both seem to think that the raspiness problem is related to the OEM backbox, so likely I will end up getting the AA valved exhaust and/or AA's upcoming downpipes as well...
07-13-2021, 01:39 PM | #176 | |
///M2
104
Rep 104
1) I'm not a fan of the burbles, so I coded that out w/ BimmerLink, just my personal preference 2) Cold starts - I hate them. When starting from overnight, I do hear that tinny noise other guys are experiences, however it goes away once that cold roar goes away. 3) Once warm, can't say there's that tinny/rasp noise but when you're using more throttle angle then left off or upshift, the brrrap noise you have with the stock system is much accentuated with this one. Some might like it, I don't. Over than that, it really does have a nice smooth sound to it part throttle across the rpm range. 4) Overall volume, windows up it's prob about right. There might be a very slight drone at around 3k rpm but would think most enthusiasts would like it. I mean, I even like hanging out there sometimes just to hear it. Windows down, it's not conservative when WOT. At light part throttle, you can almost make it stock silent. I wouldn't mind trying the resonators but it would require some welding in my application but I don't think it fixes that cold start tinniness. Guess I gotta wait till they crack 2021 DMEs to code that out. Overall, I can live with it but I'm not fully satisfied that that cold start issue however minimal it is. If I can hear a AA single midpipe w/ Remus Race in person, that would be great. |
