View Poll Results: What is your exhaust setup & are you experiencing the raspy "tin can" noise issue? | |||
EL mid pipe (non-res) / stock axleback / no issue | 3 | 5.88% | |
EL mid pipe (non-res) / stock axleback / yes, my car has the same issue! | 16 | 31.37% | |
EL mid pipe (res) / stock axleback / no issue | 5 | 9.80% | |
EL mid pipe (res) / stock axleback / yes, my car has the same issue! | 3 | 5.88% | |
EL mid pipe (non-res) / aftermarket axleback / no issue | 6 | 11.76% | |
EL mid pipe (non-res) / aftermarket axleback / yes, my car has the same issue! | 7 | 13.73% | |
EL mid pipe (res) / aftermarket axleback / no issue | 4 | 7.84% | |
EL mid pipe (res) / aftermarket axleback / yes, my car has the same issue! | 7 | 13.73% | |
Voters: 51. You may not vote on this poll |
07-08-2021, 12:36 AM | #133 | ||
Rep 692
Vic
07-08-2021, 12:40 AM | #134 | ||
Rep 692
Vic
07-08-2021, 12:41 AM | #135 | |
Rep 507
07-08-2021, 07:29 AM | #136 | |
IG@i.am.wah
2779
Rep 3,815
Drives: M2 CS
07-08-2021, 11:02 AM | #137 |
///M2
104
Rep 104
Big ups to the guys over at Autocouture w/ the installation of the Remus Race & AA EL non-res midpipes. Install wasn't a simple bolt in and required a small section to be welded in and apparently the same for another M2C that was mating the AA EL w/ Akra exhaust. Anyhow, still early and I haven't really gotten to drive it but I don't think I have that rattle with cold starts but it's been really warm past few days. I've put a quick video recorded with iPhone 12, so quality is meh but not really hearing rattling when free revving. When under load, there is some noise ~ 2.2-2.6k RPM when letting off that is prob similar to what the stock exhaust makes and also when higher in the rpm range and letting off. Will report back after a few more days.
Nicname351.00 |
07-08-2021, 11:48 AM | #139 | |||
Rep 214
Yes, since I have the newest AA EL midpipe batch. Quote:
07-08-2021, 11:53 AM | #140 | |
Rep 214
Drive it more and see if you get any funny noises anywhere. ~2k rpm range is the issue for most. For me that wasn't there. Also what do you think of the volume? I have the same set up as you except resonated, I think the volume is fine. Not too loud at all, just a bit louder than stock. Yours is probably noticeably different because you have non res. |
07-08-2021, 12:28 PM | #141 | |
Rep 89
07-08-2021, 12:37 PM | #142 |
Rep 214
07-08-2021, 12:38 PM | #143 |
Rep 214
Update: shop just called me, the rattle was because the bracket that mounted above midpipe in front that held felt liner in moved and was rattling. As for the valves, they said they just unplugged and replugged and it seems to be working.
I'm going to pick the car up and if all is well, i'll post more sound clips, revs, and drive bys and give my full impressions on the resonated AA EL midpipe (along with remus back box). |
07-08-2021, 12:46 PM | #144 | |
Rep 1,681
Current: ///M2C
G01 X3 xDrive30i Past: ///M2 997.1 Turbo ///M3 E92 |
07-08-2021, 04:00 PM | #145 |
Rep 214
Just got my car back. As they said, valve issue resolved. Big rattle resolved. No tin can sounds at 2k rpm. The only thing I have left now is a vibration when accelerating through ~2800-3100 rpm. I think I’ll live with it. I’m not sure what that can be. It only happens when accelerating through that particular rpm range, in all modes (efficient, sport etc). It’s like Bzzzp through the whole car in the time you pass that rpm range. Oh well.
Sound is good. It’s louder on start up, a lot more burbles vs before. Once warmed up it’s not really that much louder, just slightly. Here’s 2 clips. I’ll take driving clips later. Start up in efficient first then sport +: Rev to nearly 6k rpm in efficient, then sport, then sport+: Am I happy with it overall for the $4500? It’s a tough call, on one hand I definitely like the sound more. On the other hand the car as a whole just feels less refined now vs stock due to this bzzz vibration throughout the car as I accelerate through the 2800-3200 is range. And in general I just feel like there’s a lot more sounds I’m hearing. If I had to do it over again, I’d likely save the $4500 and keep it stock….If I could get this sound without any of the vibrations then it would be worth it for me. Note the installers have triple checked the install. They install bmw/Audi/Mercedes exhausts for a living at http://vastperformance.com/ so I don’t think there is anything else that can be done at this point. |
07-08-2021, 06:05 PM | #146 | ||||
Rep 692
Vic
07-08-2021, 07:15 PM | #147 | |
~Spyder
638
Rep 870
Drives: '19 M2C Hockenheim 6sp
Icing on the cake is this sound very impressive now - clearly no raspiness that EL - OEM muffler owners encountered (all jelly).
Skål från Sverige...via Texas y-all
07-08-2021, 08:14 PM | #148 |
~Spyder
638
Rep 870
So…to recap somewhat given the feedback received thus far.
The majority of raspiness reported is for non res AA EL + OEM muffler + Sport/Sport+ drive modes: very common to have raspiness/tinny sounds at startups and revving engine ~ 1.5 -2 k rpm, regardless of engine/cats' temperature To some extent, having resonated AA EL + OEM muffler in Sport/+ seems to help w/ the raspiness (more resonated EL owners need to chime in to rule this as true). Lastly, having an aftermarket axle back paired with either EL type does not seem to exhibit the raspiness. Question: can resonators be added inline to the non-resonated mipipe, or they need to be manufactured that way? Wonder if we could order the resonators on their own… Somehow I am not thrilled in having to spend on an aftermarket axle back exhaust (which typically costs more than non res EL itself) to fix an issue that the EL introduced…
07-08-2021, 11:53 PM | #149 | |
Rep 692
Vic
07-09-2021, 01:30 AM | #150 |
Rep 605
Drives: M2C
Hey so No_curebimmer when you watched my long and boring "driving around with engine warm" video did you hear whatever sounds you're referring to?
Also: goddamn I should have recorded my cold start this morning. It was SOOOO SOOOO SOOOO bad. And my neighbor was outside at the time. So embarrassing lol. I have no clue what causes the cold start to be inconsistent (sometimes terrible sometimes meh sometimes flawless) For me it's not a deal breaker since to my ears the car doesn't have issues once warm (99% of the time at least) So no cure bimmer not to poke at you or keep disagreeing or seem annoying but I'd argue the poll is a bit misleading. Eg I voted "yes I have the issues" but in reality I believe I only have one of the two (cold start only, no issues most of the time once warm) Anyways - I tend to agree that getting AA muffler will likely improve the situation across the board. I sincerely hope it fixes it for you and allows you to enjoy the midpipe as much as I do. And hopefully the muffler improves the sound even more! (rasp fix aside) |
07-09-2021, 10:52 AM | #151 | |
Rep 35
I ordered the EL Resonated and I am hoping and praying this problem isn't present on the res version but I judging from the polls, they're either not checking this thread at all or just not enough res EL out there yet.
07-09-2021, 11:55 PM | #152 |
Rep 179
God damn, I'm glad I decided not to buy mine a few months ago when they called to finalize shipping. Even back then there was enough chirping to get me to back out. Never thought it would be this bad. Rasp, melted rear diffusers, figment issues.
-2020 M2Cs
-2020 GLS450 |
07-10-2021, 06:17 AM | #153 | |
Rep 8
Not all customers give (bad or good) feed-backs. |
07-10-2021, 10:22 AM | #154 |
Rep 110
I just installed the AA axle back added to my EL non res. Awesome. Fitment perfect. The big ass tips don't melt anything. Still not great until it gets warmed up, but well worth it.
Bill
2020 M2C 6MT SO |
